Replacement speakers for an older set of sony towers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-17-2012, 08:31 AM - Thread Starter
dabsac's Avatar
Quoted: 29 Post(s)
Liked: 24
So for the past two days I've been looking to replace my 10" woofers in my Sony towers. The foam on both speakers has dry rotted and fell off. The problem I'm having is finding a good set of replacements. It seems everywhere I look I'm finding lots of car audio subs, but I'm worried about them producing the same range of sound the Sony's produced. Is there any website that specializes in home theater speakers? Can I use just any pioneer or Sony Xplode sub to replace these?
For the time being I ordered a pair of these, but after some additional research I don't have much hope for them. Since it seems pyramid is known for poor quality products.
http://www.amazon.com/gp/product/B000WEO9TC/ref=oh_details_o01_s00_i00
If anyone can give me some advice it would be much appreciated. Thanks
dabsac is offline
post #2 of 5 Old 09-17-2012, 10:26 AM
Quoted: 3255 Post(s)
Liked: 2743
You are really headed down a fruitless path. Woofer speakers are VERY finicky. The size of the speaker cabinet and port are engineered to compliment the performance of a particular driver which were all known at the time the speaker was designed. Grabbing an aftermarket driver and screwing it in your cabinet will be a crap shoot. Another issue is that the crossover may have included some compensation for the particular driver that was used.
one good source for drivers is Parts Express.
You might take this question up to the DIY speaker building section of the forum where there are some guys who know how to select a driver if you tell them the interior cabinet volume, port length and diameter.
post #3 of 5 Old 09-17-2012, 12:02 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Another alternative would be to have parts-express.com refoam your existing drivers. $37.75 each plus shipping.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #4 of 5 Old 09-17-2012, 03:50 PM
vzphoneman's Avatar
Quoted: 82 Post(s)
Liked: 78
If your wallet permits it my be a good time for you to upgrade to new tower speakers.
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is offline
post #5 of 5 Old 09-17-2012, 11:09 PM - Thread Starter
dabsac's Avatar
Quoted: 29 Post(s)
Liked: 24
Thanks for the replys. I think I'm just going to go the refoaming route, since that seems like the easiest and best possible way to fix this system.
dabsac is offline
