What kind of paint for metal threshold? - AVS Forum | Home Theater Discussions And Reviews
Old 09-19-2012, 06:45 PM - Thread Starter
Unacceptable's Avatar
Long story but my custom door was supposed to have a black threshold which I found out after it was installed that it is actually silver. Anyway, I'm needing to paint it black and figured before I spray it with Rustoleum, maybe someone here has some advice for something that will look perfect and not require much talent as I'm in short supply of that in the painting department.
Also, it'll obviously need to be durable and withstand being walked on.
Unacceptable is offline
Old 09-19-2012, 07:24 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
That's a tough one. The black thresholds are usually anodized. Paint won't hold up for long. If you can remove the threshold I'd suggest either powder coating it or get an anodized threshold from your door supplier. Most likely the door frame has to come out to remove the threshold. Sucks.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
Old 09-20-2012, 07:53 AM
advertguy2's Avatar
What about a dye of some sort? Probably test beforehand on a scrap piece of aluminum.
http://www.leevalley.com/en/wood/page.aspx?p=20081&cat=1,190,42942
advertguy2 is offline
Old 09-20-2012, 03:16 PM - Thread Starter
Had a crazy idea this morning... what about truck bed liner? Stuff is pretty durable and has a matte black finish. Not sure how easy it is to mask off and cleanup overspray but I'm thinking something like this maybe...
Dupli-Color TR250 Truck Bed Coating Aerosol - 16.5 oz.
Old 09-20-2012, 08:29 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Not crazy! That's a great idea.
petew is offline
Old 09-20-2012, 09:00 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
How about the back no slip tread stuff you put on steps you you don't slip. No painting needed... something like this.
http://www.amazon.com/dp/B005BNYV2Y/?tag=hyprod-20&hvadid=19398563976&hvpos=1o2&hvexid=&hvnetw=g&hvrand=53133013809957278&hvpone=&hvptwo=&hvqmt=&ref=asc_df_B005BNYV2Y
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 09-21-2012, 08:42 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
Have you contacted the manufacturer? Sounds like their problem if you ask me mad.gif
NickTheGreat is offline
Old 09-23-2012, 07:46 PM
bobs77vet's Avatar
why not scuff it up and then use a self etching primer followed by a top coat of your choice?
bobs77vet is offline
Old 09-23-2012, 07:56 PM - Thread Starter
Ha. And now were full circle. My original plan was to do just that and hit it with Rustoleum which would look perfect at first but I'm assuming the foot traffic would wear it out. Could be wrong? It's probably like everything else in this project and Im over complicating/thinking it.
