Installing hdmi provision - AVS Forum | Home Theater Discussions And Reviews
Old 10-15-2012, 05:07 AM - Thread Starter
fekish's Avatar
Hello
We are building our home now. Is there a way to put through hdmi wire at a later stage, as we do with audio wire? I mean just to install plastic provisional pipes at this time.
i am thinking that because of its thickness we won't be able to do it, and also i dont know even if is possible to connect the hdmi connector at corners of wire, since the wire wont go through the pipe if is not just wire.
Sent from my XT910 using Tapatalk 2
fekish is offline
Old 10-15-2012, 06:05 AM
Quoted: 3265 Post(s)
Liked: 2751
Use 1 1/2 to 2 inch diameter electrical conduit. Either rigid PVC (Gray) or flexible (Orange). You install a run from where you equipment will be located to the projector location. It is done all the time.
Old 10-15-2012, 10:07 AM - Thread Starter
fekish's Avatar
Cool thanks,
And i would be able to put later normal hdmi cable? Or hdmi cable without the heads on each side and then bring a pro to connect?
Sent from my NookColor using Tapatalk
fekish is offline
Old 10-15-2012, 10:24 AM
Liked: 2751
normal HDMI cable, be sure to use the sweeping curves they sell with the conduit.
Old 10-15-2012, 10:01 PM - Thread Starter
fekish's Avatar
Thanks! This literally made my day! So important thing is for the cable to turn at corners without a problem... got it.
2 inch would take too much space from a wall? Would builders have a problem with it?
fekish is offline
Old 10-15-2012, 10:32 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Shouldn't be a problem. They put 1.5" and 2" drain pipes in walls all the time.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Old 10-16-2012, 06:04 AM
Liked: 2751
Just be sure they don't use corner fittings intended for plumbing pipe.
If they use rigid conduit you want a fitting from this picture:
E_RigidConduit_Fittings.jpg?n=3943
Old 10-16-2012, 08:49 AM - Thread Starter
fekish's Avatar
Great thanks
fekish is offline
