1 or 2 seating rows in a 14' long room - AVS Forum | Home Theater Discussions And Reviews
Old 10-19-2012, 09:19 AM - Thread Starter
Jimbo2012's Avatar
Not sure if I have the room length to plan two seating rows,
there would be a 100" screen and I have 10 foot high ceiling.
Jimbo2012 is offline
Old 10-19-2012, 09:22 AM
AaronN's Avatar
Two rows of recliners would push the front row way too close to the screen. If you use heater seats in the back row you may be able to get away with recliners in the front, it's going to be a personal preference type of thing. Test out sitting 9' from a 100" screen.
__________________________________________________ ______
http://www.avsforum.com/t/1415464/aa...sement-theater
AaronN is offline
Old 10-19-2012, 09:24 AM
design1stcode2nd's Avatar
Quoted: 31 Post(s)
Liked: 44
If you are looking at recliners then I’d say no. My room is only 15’ 3” and the back row can’t recline fully without feet hitting the first row. I’d say 16’-17’ would be the minimum but I’ll let the experts chime in.
If you are doing a sofa tight to the back wall it would work.
Play like a Raven
design1stcode2nd is offline
Old 10-19-2012, 09:34 AM - Thread Starter
Jimbo2012's Avatar
Maybe a sofa on the back wall at say 14" riser then recliners in front on 7"
That work?
or just one riser for couch and the recliners at floor level?
how deep would a couch riser be?
Old 10-19-2012, 09:35 AM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 41
How wide is the room? My room is 15ft long ad really too short for comfortably using two rows. I have 14 ft of width so I decided to go with spacesaver seating (row of 5). Lane, Palliser, and Roman's lines all have narrow seating available.
My Theater Room JVC RS4910, Panamorph UH480, 148 in. 2.40:1 Dalite HD Pro 1.3, Klipsch THX Ultra II's x 7, Quad JTR Captivator S1 subs
My Previous Non-Dedicated space
RobZ is offline
Old 10-19-2012, 09:38 AM - Thread Starter
Jimbo2012's Avatar
that's only 10' 7"
So I'm trying to get some how 4 seats in here
Just searched "narrow seating" they make them to to fit
so that could work on one row.
with 10' ceiling how high of a platform would look good, I think I'm going raise the screen to about 30"
Old 10-19-2012, 09:47 AM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 41
A row of 4 Jives (Rtheaters.com) in IOIOOIOI configuration is 9 ft 1 in.
IOIOIOIOI is 6 in wider
RobZ is offline
