The Coffin Build - Page 41 - AVS | Home Theater Discussions And Reviews
Old 07-13-2014, 08:24 AM - Thread Starter
doublewing11's Avatar
Quoted: 145 Post(s)
Liked: 458
Originally Posted by Nightlord View Post
Very interesting
Nordic women ages like good wines.
I'll say.......seriously, my mother-in-law is first generation and is 87 years old but she looks barely 60!
Definitely an understatement!
doublewing11 is offline
Old 07-13-2014, 08:27 AM
TMcG's Avatar
Quoted: 676 Post(s)
Liked: 493
Originally Posted by doublewing11 View Post
I like the idea......
But without TMcGoogle......it's tough to get a visual! Are you referring to flipping the crown downward to reflect off vertical piece? Was planning on crown being down at bottom of vert with reveal.
OK. Hopefully this TcMGoogle Sketchup helps you visualize what I meant in my post. Remember, the software is currently incapable of accurate scale, which is no matter since accuracy in engineering drawings is an overrated feature.
I believe you were looking for triad to make a surface mount speaker that has a very low profile that you could use for your ceiling Atmos speakers. Knowing Triad, I would assume their design would be in the 4" range, similar to their in-walls. You were also looking to place acoustic treatments on the ceiling and cover with acoustic fabric while still finding a way to light everything up with indirect cove light of some sort. So my proposal is creating a functional inset within the inner portion of each coffer that can conceal the speakers and treatment while providing a spot for indirect rope lighting, similar to the Burj Khalifa picture above, that simply shines against the inside portion of your coffer. Make sense?
How much is a license for TMcGoogleSketchup ? I might need to use it.
Product information was posted in The Plains Theater at THIS post. Pricing fluctuates, but is closely tied to the wholesale market pricing for dehydrated chicken livers.
I was hoping software comes in 3D version along with being Atmos compliant!
BTW, what's up with all of us having younger wives? My wife is 6 years younger than me..........
If it's any consolation, my second wife hasn't even been born yet....
Mfusick and doublewing11 like this.
TMcG is offline
Old 07-13-2014, 08:37 AM
ellisr63's Avatar
Quoted: 324 Post(s)
Liked: 279
Well my wife is 20 years younger than me...
Sent from my SGH-T879 using Tapatalk
Denon 4520ci, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, (3) MiniDSP 2x4s, (4) Klipsch HIPs,  PS3, XBox 360, (3) Intel NUCs, Redmere, Monster HTPS7000, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diagonal) scope screen, Darbee Darcet, Yamaha P7000s, (2) Yamaha P2500s, & (3) Topping 25wpch T chip amps.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
Old 07-13-2014, 09:13 AM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
I like it!!! You just cost me more material!
What a great idea! One of a kind......different......
Applying TMcGoogle now makes perfect sense..........what would this world do with out it!
Concept is out now let's build it! Triad's getting back to me.....thought was to use either in ceiling Silver Sats, Bronze LCR's, or custom build Silver LCR's in an angled baffle. Minimum of 6" is required which is doable.
If Triad's conversation with Dolby suggests getting away without angled baffle, standard 4" in-wall Silver LCR's could be modified for ceiling.
Will figure logistics out on how to build with what material......glad someone has a creative mind since it's not me!
Old 07-13-2014, 09:56 AM
Nightlord's Avatar
Quoted: 510 Post(s)
Liked: 186
Lightbulb
Well, if I told the truth, no one would believe me, so...
Under construction: the Larch theater
Nightlord is online now
Old 07-13-2014, 12:45 PM
TMcG's Avatar
Quoted: 676 Post(s)
Liked: 493
Glad you like the idea and think it will suit your needs. I'm just throwing this out there, but this inset will also allow you to add low-profile lights in the inset vs. inside the coffer. Or you could do both. But your fixture is shallow enough that it should work with a little proper planning you could install recessed task lighting directly above the seats and general lighting for the room itself....a 'clean-up' scene, if you will.
TMcG is offline
Old 07-13-2014, 10:25 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
Glad you like the idea and think it will suit your needs. I'm just throwing this out there, but this inset will also allow you to add low-profile lights in the inset vs. in inside the coffer. Or you could do both. But your fixture is shallow enough that it should work with a little proper planning and if you'd like to install recessed task lighting directly above the seats or simply general lighting for the room itself....a 'clean-up' scene, if you will.
Thanks for the creativity..............lots of flexibility with this style, more so if I had gone the traditional route of checkerboards.
Creativity is not my strong suit........I'm a numbers guy!
Old 07-13-2014, 10:54 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
After church started in room again fixing little odds and ends which I've been procrastinating all year to get to. Since my ceiling is at a standstill until I hear from Triad, I decided to pull front column by screen because last year I was in such a rush to finish room for home show, column was not plumb by 3/4 ". All year that column has drove me crazy but its perfect now.
JPA, if your reading post.......this column is on 10ft wall underneath soffit so it's actually 9 ft.....since KA 3/4 plywood is only 96" had to develop system to float column between top and bottom. Column is actually three separate pieces but design ended up helping dampen column.......no rattles whatsoever.
Here is photo of blocking system used top and bottom:
Column is attached with two screws on top and two on bottom plate......two blocks are screwed into wall/channels. Neopream sits between 3/4 plate and column.
On another note, I started in running cove moulding to hide transition from fabric channels to soffit bottom.
And I also played around with JPA' box-X design
ID:	160097   Click image for larger version
ID:	160105   Click image for larger version
ID:	160113   Click image for larger version
Old 07-14-2014, 08:35 AM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
Well.......it can't be fish since both wife and mother-in-law hate the critters.
Luffsa? I know I butchered that spelling!
Old 07-14-2014, 02:50 PM
J_P_A's Avatar
Quoted: 377 Post(s)
Liked: 307
So what's the word on ATMOS? The suspense, man. I can't take it.
The Plains Theater Has Begun
J_P_A is online now
Old 07-14-2014, 06:13 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
I'm as antsy as you!
Did receive an email from Steve Colburn at Triad and he requested a little more time due to wanting further clarification from Dolby. Evidently significant issues are still being worked out still such as finalizing fine technical details. So I've been promised a phone call when specifics are clarified and certain. As soon as I have information will post with Triads blessing. Gotta love a company going the extra mile for their customer base.
On a side note, received other information concerning Atmos but can not/ will not diverge info unless I have the messengers permission.
Old 07-14-2014, 06:16 PM
HopefulFred's Avatar
Quoted: 290 Post(s)
Liked: 267
HopefulFred is online now
Old 07-14-2014, 07:21 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
^tease
One would think huh?
Na, it's respect for someone's private conversation and information. I suspect I will have permission to post since information could help others to mimic. It 's not my place to make judgement on passing private info.
Old 07-15-2014, 04:23 AM
JRock3x8's Avatar
Quoted: 230 Post(s)
Liked: 56
Applause for respect for private conversations.
doublewing11 likes this.
JRock3x8 is offline
Old 07-16-2014, 07:21 AM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
Well, I have permission from Roger to post information. Roger has posted similar information from another link here on AVS but from my understanding I believe updated version was emailed to me.
Format of attachment is in pdf and for some reason my computer vurus software wont let be get access to my email account. Was hoping to use snipet and post illustrations on what Roger is doing in his room. It was helpful for me to actually see someones plans to implement Dolby Atmos.
Hopefully, if for some reason I can't get access to files Roger sent and post in this thread, Roger could post illustrations for his room rendition for Dolby Atmos and reasoning behind it.
On Triad front, I'm still waiting for Triad to get back to me with further information. Depending on what is recommended by Triad will dictate how this coffered/ceiling cloud is constructed.
Old 07-16-2014, 07:29 AM
J_P_A's Avatar
Quoted: 377 Post(s)
Liked: 307
I'll be interested to see what it looks like. Have you seen BrolicBeast's layout? Here's a link to the first post where he has it posted. It will be interesting to compare two ATMOS home layouts to see if they are similar or not.
J_P_A is online now
Old 07-16-2014, 08:01 AM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
Yeah, I took a look......,how big is that guys room? Holy cow.......that guy isn't messing around.
Roger is implementing four "VOG" speakers which I plan to follow suit. I'm getting real antsy to let wood fly!
My ceiling cloud design hinges on what Triad comes up with..........at least speaker locations. Roger validated angled baffle of speaker is desirable so I'm feeling more comfortable with decision to implement DOLBY Atmos.........it will be interesting to see what Triad recommends.
Old 07-16-2014, 10:25 AM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
Updated my opening page.......room is actually starting to look like a theater. Can't wait to get started on ceiling cloud project!
ID:	164577   Click image for larger version
ID:	164585   Click image for larger version
ID:	164593   Click image for larger version
ID:	164601   Click image for larger version
Bigham16 and BllDo like this.
Old 07-16-2014, 11:35 AM
Robert Jones II's Avatar
Quoted: 93 Post(s)
Liked: 55
Looks phenomenal
Robert Jones II is offline
Old 07-16-2014, 12:06 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
Originally Posted by Robert Jones II View Post
Looks phenomenal
Thanks for complement......it's been a labor of love.
Old 07-16-2014, 12:10 PM
Mfusick's Avatar
Quoted: 359 Post(s)
Liked: 1492
You need a flash
But looks great anyways!
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is online now
Old 07-16-2014, 12:20 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
You need a flash
What, don't like my photography skills?
I turned lights down to 30% so rope lights could be seen. What's really cool, the Knotty Alder gives off a red-ish bronze tone which is hard to capture. My iPhone takes better pictures, but used my Sony Tablet to take these.
But I do see what you are saying, . BTW, took these pics specifically for you.
Old 07-16-2014, 01:46 PM
TMcG's Avatar
Quoted: 676 Post(s)
Liked: 493
Care to share what angles? I assume it varies based on which set of ceiling speakers - first row, second row, etc.
TMcG is offline
Old 07-16-2014, 02:16 PM
Quoted: 41 Post(s)
Liked: 6
Wow, truly beautiful, you should be proud!
______________________________
DIY Expert / HT Noobie
My Build Thread
DougUSMC is offline
Old 07-16-2014, 02:27 PM
Mfusick's Avatar
Quoted: 359 Post(s)
Liked: 1492
I like your progress and theater better than your photo skills
Old 07-16-2014, 04:34 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
Hey, new emoticon.........had to try it!
Old 07-16-2014, 04:38 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
The easy part is done.......the hard part will be the ceiling cloud and one legged coffer!
Old 07-16-2014, 04:45 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
T,
I have PDF along with angles.......problem is, my computer won't let me get to my email account so I could use snipet tool. Can't save or copy PDF from my phone or tablet. I'm trying to find a way to format on phone.
I'm working on it....
Here is a link to info Roger emailed me........I believe info is similar.
The official Dolby Atmos thread (home theater version)
Old 07-16-2014, 05:44 PM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
Rogers explanation:
My current rear surrounds are elevated 20 deg, and with the rear heights at 50, there's a 30 deg vertical spread, which I think is good. In the front the spread is 40 deg even though they are 10 lower on an absolute basis (the front L/R are at 0 deg elevation).
I do have the option of shifting the front heights forward, thus also giving me a 30-deg spread. To the rear seats, the elevation difference is almost nil, 17 vs 15 deg, so I only need think about the MLP here.
One thing I like about the original 40-deg position is that the ceiling cloud will reduce SBIR, whereas the 30-deg position has bare ceiling (and can floods) with about 1 ms extra path length, making a null at 500 Hz or thereabouts. Dolby (thru Denon) suggests they should be 30-55 deg elevation, so 40 seems the better option for that reason, too. I'll start there.
Hope this helps TMcGoogle.
Old 07-17-2014, 07:16 AM - Thread Starter
Quoted: 145 Post(s)
Liked: 458
Yesterday, emailed my design plans from Erskine Group to Steve Colburn at Triad. We can all assume recommendations and placement will be based on current speaker locations and set up. Until then, have to find things to keep me busy in room.
Well, its back to sanding, pre-stain wood conditioner, sanding, staining, sanding, and finally shooting four coats of satin lacquer. Here is inventory being used for ceiling cloud:
60 LF 1 X 8. Knotty Alder
60 LF 1 X 6 Knotty Alder
60 LF 9/16 X 5-1/4 OG base
60 LF 9/16 X 3-1\4 OG base
60 LF 4-1/4 Crown
50 LF 1-1/4 X 1-1/4 cove
For now, at least I can have Knotty Alder ready for constuction while I wait for Triad. My design all depends on outcome from their recommendations, yet ultimately decision is mine.
Here is a mock up of light tray. Very similar to mock up you guys preferred yet now has 5-1/4" OG base which is not stained.
Sony Vpl Vw1000es Projector , Marantz Av8801 , Peavey Ipr2 7500 Power Amplifier 7500 Watts
