The Coffin Build - Page 53 - AVS | Home Theater Discussions And Reviews
post #1561 of 2103 Old 08-11-2014, 04:48 PM - Thread Starter
doublewing11's Avatar
Quoted: 137 Post(s)
Liked: 429
Originally Posted by jbrown15 View Post
If its an open invite to stop in if we head down to see the Ducks play hell yeah I'd love to stop by and check it out!....lol
I'm not really a ducks fan, just thought it would be cool to go see a game....lol
Hey,
BTW JB,
You can pick up that roll of Linacoustic RC if you want..........it's down to about 35-45% of roll.
doublewing11 is offline
post #1562 of 2103 Old 08-11-2014, 05:10 PM
jbrown15's Avatar
Quoted: 1823 Post(s)
Liked: 1441
Originally Posted by doublewing11 View Post
Be prepared......
You're probably going to unload your JTR's in near future if you stop by...........
Fair warning!
Probably not....lol
But I might try to steal your projector on the way out!...lol
jbrown15 is offline
post #1563 of 2103 Old 08-11-2014, 05:16 PM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Probably not....lol
Wow......
My speakers are better than my projector!
post #1564 of 2103 Old 08-11-2014, 08:38 PM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
I forgot to post what my Son gave me for my birthday......
Guess I'll join the masses.......would have never purchased myself.
What's more important to me is device on left!!
post #1565 of 2103 Old 08-11-2014, 11:50 PM
Nightlord's Avatar
Quoted: 495 Post(s)
Liked: 177
The toothbrush?
Under construction: the Larch theater
Nightlord is offline
post #1566 of 2103 Old 08-12-2014, 04:57 AM
J_P_A's Avatar
Quoted: 366 Post(s)
Liked: 294
Originally Posted by Nightlord View Post
The toothbrush?
Haha! He got you on that one, DW
The Plains Theater Has Begun
J_P_A is online now
post #1567 of 2103 Old 08-12-2014, 05:42 AM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
The toothbrush?
Too funny! I'll bet there might be a toothbrush in that mess.....I used it to clean adhesive between layers of wood.
NO!! The COFFEE POT!
post #1568 of 2103 Old 08-12-2014, 05:48 AM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Yup!
I took over my wife' kitchen for while........even a Minwax Friutwood #3 crayon in next to toothbrush. And no.....that's not my toothpaste!
That's also the bill pile......want to relieve us of some burdens?
post #1569 of 2103 Old 08-12-2014, 02:11 PM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Confirmation eight 2" OC 703 panels arrive Thursday along with Sensa acoustic fabric. I'm painting the inside bay's flat black and will spray paint 703 flat black. In picture I've marked location of channels due to not wanting to put another screw into them.....channels have received enough abuse already!
Plan is to use spray adhesive to sandwich 6 mil poly between two layers. Will hang 4" total absorption panel using picture frame wire to fender washers and eye screws to ceiling. Hoping broadband absorption down to 150-200 Hz.
Front bay will be done Thursday with treatments and fabric. Second row bay will wait until I receive diffusers from Acoustic Frontiers.......hopefully by end of next week.
post #1570 of 2103 Old 08-12-2014, 02:22 PM
HopefulFred's Avatar
Quoted: 272 Post(s)
Liked: 256
Am I reading right that you are planning to paint the fabric? Not recommended.
HopefulFred is offline
post #1571 of 2103 Old 08-12-2014, 02:36 PM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
lol Where does it say that? I'm painting Owens Corning 703 rigid fiberglass panels black. Sensa will be in fabric track......and it's black already.
Fred, you had me scared......yup, says 703 gets painted black.
post #1572 of 2103 Old 08-12-2014, 07:28 PM
BllDo's Avatar
Quoted: 196 Post(s)
Liked: 143
Painting the OC703 will affect the acoustical properties of the insulation. It will reduce the absorption of the high to mid frequencies by reflecting them back to the room. This might be part of the goal here, but should be noted for others. General, I believe this is not recommended.
doublewing11 likes this.
Is it solipsistic in here, or is it just me?
BllDo is offline
post #1573 of 2103 Old 08-12-2014, 08:25 PM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Though it makes sense ie painting would affect properties, but I've read the opposite. Not saying you are wrong, just might be my resource is incorrect.
Purpose is to absorb high/mids for smoother response. Plan was to lightly spray with rattle can in flat black so treatments won't be seen.
Sensa fabric is really thin and transparent like GOM 701........if I don't lightly spray treatments I suspect rigid 703 will be seen.
Hopefully, I have enough black Anchorage around to wrap if what you suggest is the case.
Edit:
Blldo, you are correct.......don't know what or where I received my info. Maybe that is what Fred was referring to.
post #1574 of 2103 Old 08-12-2014, 08:26 PM
J_P_A's Avatar
Quoted: 366 Post(s)
Liked: 294
Since there's a question, why not try the fabric on the unpainted OC703 and see if you can, well, see it. If you can, then you can worry about painting or otherwise covering it.
J_P_A is online now
post #1575 of 2103 Old 08-12-2014, 08:51 PM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Yeah, doing a search here at AVS it's highly recommended NOT to paint 703.
I'll try your suggestion first.......worst case scenario, I can get black muslin at Joanh's and wrap panels, then Sensa into fabric track.
Trying to figure out where I read spaying flat black was ok.........I'm usually pretty anal retentive with planning. Well, mistake averted thanks to Fred and Blldo! Thanks guys......:
post #1576 of 2103 Old 08-13-2014, 07:47 AM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Starting to get rack space challenged.......so I've been looking/researching for compact amps that will use minimal rack space.
With addition of possibly 6 more channels to provide power, a traditional amp would require 5-6 more rack units which creates huge problems for me with my 32 ru enclosure.......yeah, should have gone 36-40 ru!
Came across theses amps........
Art SLA2 two channel amp amp provides 300w rms per channel @ 4 ohms......uses 1 ru
Art SLA4 four channel amp provides 140w rms per channel @ 4 ohms.......uses 1 ru
http://artproaudio.com/art_products/studio_amplifiers/
These products sure eliminate a lot of problems.........does anyone have experience or knowledge of these products?
post #1577 of 2103 Old 08-13-2014, 08:03 AM
raczkri's Avatar
Liked: 2
How about a Lab Gruppen C 20:8X ? 8x250w @ 8ohms - 2ru.. and each channel pair is bridgable to 500w if needed, have peak limiter (and gain) per channel, remote power on, etc
seems like a good option for future larger atmos installs also (24-32 channels)
raczkri is online now
post #1578 of 2103 Old 08-13-2014, 08:51 AM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Thanks for the heads up! Fore-mentioned solution was three ru's........the Lab Gruppen could cut down ru's to two with a lot more options, besides powers speakers perfectly. Will pay a premium, but am willing to go that route if it simplifies my rack situation. In reality, two would be perfect.......giving me 16 possible channels.
Going into this project, knew I'd have to change my amp situation......
Thanks again......definitely going to consider two of these units.
post #1579 of 2103 Old 08-13-2014, 12:39 PM
Nightlord's Avatar
Quoted: 495 Post(s)
Liked: 177
Nice to see someone mention Swedish amps around here.
"Lab gruppen" Lab is lab. Grupp is group. -en is the. Thus "The lab group".
(So you shoudn't say "The lab gruppen" any more than you'd say "CD disc" )
Afaik they make quite decent PA amps.
post #1580 of 2103 Old 08-13-2014, 12:59 PM
Mfusick's Avatar
Quoted: 334 Post(s)
Liked: 1402
How about expand your amp rack and get an Earthquake Cinenova Grande ? MOAR?
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is online now
post #1581 of 2103 Old 08-13-2014, 01:15 PM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Jahl,
Ich sprechen wenig Deusche......Swedish nicht!
Yup, Lab Gruppens are great amps!
post #1582 of 2103 Old 08-13-2014, 01:31 PM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
I already have a Krell Evo 403, S-1507..........along with ATI 1807 and Halo by Parasound A-31.
If I could sell the pseudo-futuristic habachi microwave oven ie. Evo 403, I could upgrade to my hearts desire. The Krell S-1507 is a great amp and matches Triads real well, but it's silver in color.
I'm definitely not amp challenged.
As far as expanding rack, I could go up but that means opening up a new can of worms. Two Lab Gruppen amps powering 16 speakers while taking up 4 ru's rather than 14 ru's is really enticing don't you think?
post #1583 of 2103 Old 08-13-2014, 02:47 PM
raczkri's Avatar
Liked: 2
imagine all the new gear that you could get to fill in the space saved!
post #1584 of 2103 Old 08-13-2014, 04:13 PM
TMcG's Avatar
Quoted: 627 Post(s)
Liked: 464
Scope creep.......SCOPE CREEEEEEP!!!!
TMcG is offline
post #1585 of 2103 Old 08-13-2014, 05:18 PM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
I call it a deep, dark, and foreboding place.......
post #1586 of 2103 Old 08-13-2014, 05:22 PM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Thanks.........rack space is saved........something else is lost.
post #1587 of 2103 Old 08-14-2014, 08:46 AM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Project Battle wounds!
Hopefully, this can be helpful to those who want to clean stains on screen.
Day two back in late June when I was trimming out soffit face, At end of day I notice a small 1" spot on screen......upon further inspection I realized it was pneumatic oil on screen. That morning, I oiled up my 16 gauge finish nailer and didn't realize I had not cleaned off excess in one location. Thought venting was going away from screen.......evidently not!
So the battle begins........screen is off wall, fabric is on dining room table and here are my weapons of choice:
Wife being the fabric expert and have contacted Chris at Seymour-SE.........strategy for combat is prepared!
Using fabric fray glue on edges........dry time is 15-20 minutes so this will be a looooong process. Chris stated fabric will fray.......definitely an understatement!
When all edges are glued.........Will soak Dawn dish soap on stain and will let soak for 20 minutes and then wash fabric in hot water on delicate cycle. When done, will spread screen material to dry naturally. When dry, wrinkles will be clearly visable but tension from installation will eliminate any of those wrinkles.......Chris' own words!
If I loose this battle....$500+ for fabric material is literally down the drain!
ID:	211809   Click image for larger version
ID:	211817   Click image for larger version
post #1588 of 2103 Old 08-14-2014, 09:26 AM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Major surgery..........
3/16 th's layer of fray check around perimeter.
post #1589 of 2103 Old 08-14-2014, 11:19 AM
Mfusick's Avatar
Quoted: 334 Post(s)
Liked: 1402
Ouch! Good luck. You are just cleaning the stain with what? Dish soap ?
post #1590 of 2103 Old 08-14-2014, 11:33 AM - Thread Starter
Quoted: 137 Post(s)
Liked: 429
Is been agreed upon, Dawn is weapon of choice.
You have another idea other than Dawn?
Sony Vpl Vw1000es Projector , Marantz Av8801 , Peavey Ipr2 7500 Power Amplifier 7500 Watts
