The Coffin Build Goes Dolby Atmos - Page 45 - AVS Forum | Home Theater Discussions And Reviews
 689Likes
post #1321 of 2870 Old 07-26-2014, 04:51 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
I don't follow. What's the thickness of space allowed for the treatments? It's not much different to fill the allowed space vs. half-fill with air-gap, so the cost savings for less fiber is a reasonable move in those cases. The plastic should be at least 2" from the ceiling - never against it (or the wall).
I think I missed some details in your plan - can you lay it out, inch by inch?
HopefulFred is offline
post #1322 of 2870 Old 07-26-2014, 05:57 PM - Thread Starter
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 942
Out at ranch's shop getting ready to cut 1/2" AC-U plywood into 7-1/2" strips for inside verts for coffer ceiling cloud.
Since 1 X 8 Knotty Alder is actually 7-1/4" and will be used for outside verticals with 1/8-1/4 reveal with base 1 X 6, these plywood pieces will be flush with base and will add appropriate trim piece to top of plywood to get depth needed for fabric channel.
MOAR wood cutting..........
doublewing11 is offline
post #1323 of 2870 Old 07-26-2014, 06:03 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
Sure........I'm hoping to have 8 " depth for ceiling cloud.......we shall see.
Plan for absorption is the following starting from the ceiling:
3-4 inches air gap
2" Owens Corning 703
Spray adhesive
6 mil poly
Spray adhesive
Fabric.....
There might be a space between fabric and absorption material but that is of no concern. I will hang treatment with eyelets and wire.
post #1324 of 2870 Old 07-26-2014, 06:30 PM
Quoted: 490 Post(s)
Liked: 422
Good. Thanks for clarifying. I approve (not that my approval is terribly meaningful, but that's what I hoped you were planning).
doublewing11 likes this.
post #1325 of 2870 Old 07-26-2014, 07:24 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Moar!
HopefulFred and doublewing11 like this.
Mfusick is offline
post #1326 of 2870 Old 07-26-2014, 08:53 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
Moar!
MOAR Cutting done!!!
JRock3x8 likes this.
post #1327 of 2870 Old 07-26-2014, 10:05 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
Thanks Fred for the help........this build is moving fast so I don't want to make a mistake.
post #1328 of 2870 Old 07-27-2014, 05:38 AM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 444
Did your theater design call for acoustic treatments on the ceiling?
J_P_A is offline
post #1329 of 2870 Old 07-27-2014, 07:35 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
No.....
Actually, when I called Gary Lemay at Quest, he thought too much of the expensive Perfsorber was spec'd and felt I could get away with less but just went with Erskine Group plan as is................I'll just leave it at that.
When Roger Dressler came over he detected two major issues which one has not been addressed yet and will soon be tackled.
First issue earlier noted in thread was 300 Hz problem from front and immediately I knew what the problem was. In haste getting room ready for tour, I didn't line facade screen wall ceiling with poly sandwiched between layers of Linacoustic RC. Since then, have fixed issue but still exists slightly........most likely 1st reflection issue from mains is my best guess.
Second issue noticed was infamous 60 Hz buzz coming from my 6 surrounds which is related to Graffikeye. Lights on, buzz.......lights off, no buzz. When I change out to Krell amp which has balanced connects, no issue. ATI 1807 which has RCA connects is issue. I'll be addressing this issue when I have electrician the whole day and find origin of loop problem along with troubleshooting dimmer issue with noise.
I thought about contacting Nyal........may still.........but if I was told to completely change my treatment plan once implemented......I wont be a happy camper. What I don't know can't hurt me..................besides, I have alternatives to problem solve.
Room sounds great to my ears........and there's always room to improve. Jeff Meyer will be coming in June of next year.......hopefully, I'll have new processor, eq, and speakers ready.
post #1330 of 2870 Old 07-27-2014, 07:48 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Have you measure your room or room gain yet for bass ?
If you can measure there is a fairly simple way to measure your rooms gain. ( transfer function ) You need a sealed sub and the ability to EQ it flat. You do this outside. As in measure and EQ it outside in big open area. You don't have to be loud either; What you need to be is louder than the rooms basic noise level. Fairly easy. Then just play the same signal inside and measure the difference. If you are using REW it will be fairly easy to see the difference using a multiple response curve graph. Give you an idea of how your room performs. I was originally going to ask Fred this in his thread, but your thread lives near the top of the forum more often (kudos for that and progress!)
Now back to our regularly scheduled program: MOAR CUTTING!
Mfusick is offline
post #1331 of 2870 Old 07-27-2014, 07:56 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
Major issue!
No room in garage..........three bays.......no room!
All Knotty Alder has four coats of satin lacquer and has sat for a couple of days. Tomorrow MOAR cutting since trim finally is ready for last stage of build.
I'm really beating myself up on how to install.......thought I would build each side of cloud on ground and hoist up glue and nail. My concern is, my wife is only helper and she is not a very big/strong person........tough, yes since she was raised on ranch.......but heavy beams overhead might be an issue. If my Son was available he could help..........I'd love to have that 6' 4" 230 chiseled guy around but he has grad school to attend too.
I'll be building rear leg for projector and rear beam today after church........
ID:	182434   Click image for larger version
ID:	182442   Click image for larger version
post #1332 of 2870 Old 07-27-2014, 08:17 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
No I haven't........
With room length probably not as much as I would hope for. In modeling with Winsd and comparing with my real world measurements in REW, I'm fairly close with exception of low end frequencies which are 4-5 db's greater in SPL real world compared to model............amazing what eq does. 4300cf isn't small.........
When I change out processors, eq and possible amps.......could easily be done then.
Back to:
MOAR CHURCH, then cutting!
post #1333 of 2870 Old 07-27-2014, 09:18 AM
JRock3x8's Avatar
Quoted: 649 Post(s)
Liked: 163
i love the aggro tone of this build all of a sudden.
JRock3x8 is offline
post #1334 of 2870 Old 07-27-2014, 10:03 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
Boy, I haven't heard the word "aggro" since I was a little nipper!
Yeah, these blokes are quite barmy to say the least......seems a few of them have been on a bender per say. It's not like we're going to bite our arms off, rather a few of us are buggered and blasted how quickly this project has come together.
Won't bodge this blooming project since I'm not blinkered as I've had help from me mates chin wagging.........sure made this project a doodle!
I'm one who will not fanny around......definitely going full Monty on this project!
Still have to give Roger Dressler the bell........but have been knackered by my own accord.
British and Americans............we're separated by more than an Atlantic Ocean........do we really have a common language?
post #1335 of 2870 Old 07-27-2014, 02:54 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
Constructing one leg which attaches to ceiling cloud. Because I have to have access to compartment, I'm building a a simple drop down door which will be screwed from bottom so four screws will be seen. I pondered many ways to build this but I want to be able to have leverage when pulling cables/wires so access panel on bottom. Some may cringe due to being able to see outline of door but my decision to build this way has benefits.
My trade off is simple, no cutting into ceiling for speaker wires........I will be using projector conduit and pull three 4 conductor in-wall 12 AWG wire since I'll have access to ceiling cloud via projector box........obviously conduit for projector goes to rack.
So far in 2-1/2" electrical conduit, I have two HDMI , Cat 6, and now three speaker cables........tube is getting busy!!!!!!!!
Here are pictures of leg construction..........there are three pieces.......longest piece will be trap door not nailed to vertical 1 X 8's. It will be screwed in 1 X 2 blocking inside of leg because of two things........need a stop to set piece flush with other parts of leg, second if screw holes become stripped out or won't hold access door then I can replace with no problems. Will use the smallest black or antique bronze screws I can find ie #6 or less.
Currently waiting for stain to set, Will put a layer of polyurethane on 2-1/8" keyhole and edges of all pieces.
ID:	182858   Click image for larger version
ID:	182866   Click image for larger version
ID:	182874   Click image for larger version
ID:	182882   Click image for larger version
post #1336 of 2870 Old 07-27-2014, 07:35 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
Done for the day..........boy, am I tuckered out! Getting up at 5 AM is taking it's toll.....
Here is what I accomplished to day............have projector leg built and is hung. Leg will serve as a chase for speaker wire for ceiling speakers.
Goal was to finish rear soffit and finish transition to leg......but fell short due to saw problems. Getting tired of saw getting out of square after thirty or so cuts!!
So I returned the darn thing.....
Have finally figured out what I'm going to do with two different crown levels.......will document with photos.
Speaking of photos.......here are a few on today's progress. Still missing three trim pieces but at least leg frame is done!
ID:	183194   Click image for larger version
ID:	183202   Click image for larger version
ID:	183210   Click image for larger version
ID:	183218   Click image for larger version
ID:	183234   Click image for larger version
post #1337 of 2870 Old 07-27-2014, 07:47 PM
Maklar's Avatar
Quoted: 42 Post(s)
How do you apply your stain/lacquer? Do you do it by hand or spray it? Looks good either way but hoping you do it by hand so I don't have to buy a sprayer
Maklar is offline
post #1338 of 2870 Old 07-27-2014, 09:32 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
How could I forget grand finale'......
post #1339 of 2870 Old 07-28-2014, 08:39 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
New day, new chop saw.............was tired having to re-calibrate saw and having safety guard constantly fall off. In addition, all purpose blade wasn't cutting it..........picked up 90 toothed carbide blade and makes a whole
lot of difference. I need someone to smack me across my head..........willing to pay big bucks for premium wood but too cheap on where it really counts.....a good blade.
post #1340 of 2870 Old 07-28-2014, 10:49 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Bravo!
is that one of those Home Depot Diablo blades. I like them. They work great, I have on on the full size and table top table saw, and I just grabbed one for the chop saw too. Quiter, and buttery smooth cuts (until you cut 50 sheets of MDF then they are toast)
Is that a new chop saw too? Again ?
Mfusick is offline
post #1341 of 2870 Old 07-28-2014, 11:17 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
Bravo!
Yup, New saw...........I was going to get a Dewalt but didn't have model in stock I wanted. Just decided to exchange since stock was on hand. Diablo blade is cutting like a Sharp Wusthof knife!!!
post #1342 of 2870 Old 07-28-2014, 11:54 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
What did you go exchange the RYOBI saw you bought for an upgrade? What did you get?
Mfusick is offline
post #1343 of 2870 Old 07-28-2014, 02:14 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
Exchanged for same saw........I was in a hurry to get back and meet my goal but was too rummy and called it a day.
Trying to finish up back so I can hang projector up.............my wife wants to watch the bachelorette tonight.
post #1344 of 2870 Old 07-28-2014, 02:23 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
Believe I've worked out a solution for transition for two crown levels.
Here is start of that transition.......5-1/4 OG base to 3-1/4 OG base. Strange that profile would be different between these pieces.......didn't make my life easy anyhow.
post #1345 of 2870 Old 07-28-2014, 02:24 PM
TMcG's Avatar
Quoted: 1074 Post(s)
Liked: 876
UGH! What a waste of precious bulb hours....
The things we do for our better half!
TMcG is offline
post #1346 of 2870 Old 07-28-2014, 02:37 PM
Nightlord's Avatar
Quoted: 712 Post(s)
Liked: 238
Isn't that why they invented the economy mode?
Under construction: the Larch theater
Nightlord is offline
post #1347 of 2870 Old 07-28-2014, 02:44 PM
TMcG's Avatar
Liked: 876
No, that' why they invented the 'OFF' button!
TMcG is offline
post #1348 of 2870 Old 07-28-2014, 03:44 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Lol. I thought I was the only one that broke tools withing the return policy. Harbor freight knows my by first name, but all their crap breaks lol.
Mfusick is offline
post #1349 of 2870 Old 07-28-2014, 07:32 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
Yeah, I'd do anything for my better half........after 28 years she still is the HOTTEST woman alive!
She has great Norwegian genes!
post #1350 of 2870 Old 07-28-2014, 07:37 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 942
The worst part of it all..........I have to record the episode for my big, strapping son so he can watch with his girl friend!
Where's the finger in mouth emoticon?
Sony Vpl Vw1000es Projector , Marantz Av8801 , Peavey Ipr2 7500 Power Amplifier 7500 Watts
