The Coffin Build Goes Dolby Atmos - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 689Likes
post #1621 of 2869 Old 08-16-2014, 04:58 PM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
Originally Posted by BllDo View Post
Have to second the bigger rack ( ).
are we still talking about home theater here?
JRock3x8 is offline
post #1622 of 2869 Old 08-16-2014, 06:28 PM - Thread Starter
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
Speaking of racks......
If you're referring to other kind of racks......wouldn't know anything about that.
doublewing11 is offline
post #1623 of 2869 Old 08-16-2014, 06:33 PM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
JRock3x8 is offline
post #1624 of 2869 Old 08-16-2014, 09:26 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
Screen dilemma is over.......
Last night watched "All is lost" and the oil spot was clearly visable and drove me CRAZY! So took down screen once again and gave it one more try before purchasing replacement screen material.
So here is THE plan of action which solved problem.
1) Toothbrush plus Dawn dishwasher scrub. Both sides of screen scrubbed vigorously with toothbrush then sprayed/soaked Resolve stain remover and proceeded to scrub again.........15 minute scrub!
2) Heck with the delicate cycle.........went all out using ALLERGIENE cycle with extra hot water and heavy soil level. Used regular detergent too....
3) Prayed a lot!
4) Pulled out of washer and table dried!
5) Put up screen, voila'! No stain! It's gone!
Now this episode is done..........Monday begins rear bay finishing with diffusers!
Wow.......got lucky on this one! Pneumatic oil on screen is a bugger!
post #1625 of 2869 Old 08-17-2014, 07:57 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
Atmos Speakers for ceiling
After much thought, and with consultation..........leading speaker to go into ceiling for Atmos implementation is Tannoy iw 6TDC.
Sensitivity of speaker is 91db/w/m which matches my Triads.......any issues with timbre can be eq'ed away.
What speaker does is disperse 90 degrees conical which will place all seating in sweet spot so rear compromise with coffer cloud is no longer a problem, can build my own backer boxes to meet my specific baffle angles required for ideal installation, and eliminates a few issues due to boundary location in ceiling.
I'm considering attending CEDIA in Denver this year to sort out direction I'll take for Atmos. Nothing is set in stone........who knows, Triad may have a new product which meets my needs but I highly doubt it. Placing custom Triad Silver LCR's in ceiling is not going to help meet specific requirements for Atmos ie dispersion and also adds significant other issues/problems to installation.
Here's info on Tannoy iw 6TDC speaker......
http://www.tannoypro.com/#!Page=Product&Id=5.60
post #1626 of 2869 Old 08-17-2014, 08:51 AM
raczkri's Avatar
Quoted: 14 Post(s)
Liked: 2
What is the problem with these triads?
http://www.triadspeakers.com/products/iws4mon.html
http://www.triadspeakers.com/products/ics6mon.html
http://www.triadspeakers.com/products/iwg6mon.html
The frequency range, power handling seems to be ideal for this application. not to mention these would match your LCR triads nicely I assume and they could be installed in your cloud easily also.
I can't find the dispersion pattern of these in the specifications but as they use traditional tweeters they should be very wide. If not, you could easily angle them properly inside your cloud given their shallow profile.
oh yes, and in contrast to the tannoy above, the triads are already boxed so you can be sure that you have the exact intended performance that match the crossovers' design. while with the tannoy you need to build a 20L box for them and hope its shape and rigidness will result the sound they intended to produce..
do I miss something obvious drawback? (aside from maybe price on which I have no info)
doublewing11 likes this.
raczkri is offline
post #1627 of 2869 Old 08-17-2014, 09:46 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
You have mentioned some fine speakers..........
If I could go back in time.......which I can't........I would have used Triad Gold Monitors with Silver Monitors for surround instead of current speakers. I was told on numerous occasions Gold Monitors would not work in my room. At time, I wanted Triad Plats but never had a chance to hear them, not to mention telling room designer I wanted Plats but room was spec-ed with Triad Golds. Since acoustic design was based on using Gold LCR, decided in end to go that way.
In reality, at my current listening levels ie -8 to -10 on Marantz 8801, I could have easily used Gold Monitors.........and never deal with that voice in my head stating, " What if........."
With ceiling speakers being so close to boundary, along with dispersion needing to be 90 degrees conical to encompass all seats in cone, essentially coaxials are best solution to problem. Because of driver alignment, lobing issues as in destructive energy at crossover frequencies would be issue with all mentioned Triad products.........though Silver Monitors would be less of an issue.
Fore-mentioned Tannoy in-walls require 0.7 cf internal volume as noted by manufacturer............I have no issue and actually prefer building my own baffle for speakers. Internal volume needed would be approximately 18-20 inches long which is certainly doable. Internals of said speaker is approximately 3-1/2 " deep so plenty of room to build backer box which is restricted by 8-1/4 " depth of my coffer cloud. As for Tannoy's super tweeter.......it's crossed over at 16 kHz so destructive issues near boundary are minimal.
It's still a wait and see situation........attending CEDIA and seeing what solutions are out there might be helpful especially with my preference to use Triad speakers. Wife gave me permission to attend CEDIA so it looks like I'm good to go........but a quick flight turnaround has me wondering if I'm taking on too much ie have to fly into Boston immediately after CEDIA to see Daughter.
post #1628 of 2869 Old 08-17-2014, 11:26 AM
wse
wse's Avatar
Quoted: 1977 Post(s)
Liked: 741
Theater room is off to the left of kitchen/dining area.............A huge bonus!!
17 ft Throw on the Sony 1100ES on a 12 ft 2.37 Seymour-Screen Excellence 4k Screen. Bright and throws a gorgeous picture!!
Gorgeous room and kitchen!
wse is offline
post #1629 of 2869 Old 08-17-2014, 11:33 AM
Nightlord's Avatar
Quoted: 712 Post(s)
Liked: 237
Not so long run to save falling plates.
J_P_A and doublewing11 like this.
Under construction: the Larch theater
Nightlord is offline
post #1630 of 2869 Old 08-17-2014, 01:45 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
Thanks for the kind complements!
Those pictures were before I started cloud.....room has really changed!
I'll pass on complements to my wife about her kitchen. Since I designed home I just gave her her space to work with. She spent months on CAD designing kitchen and picking appliances, granite, tile ect. I kept my nose out of it except I told her I wanted a grill for steaks. Glad she honored my request since barbecue steaks in Winter is great!
post #1631 of 2869 Old 08-17-2014, 01:49 PM
Nightlord's Avatar
Quoted: 712 Post(s)
Liked: 237
Did she know CAD from before, or did she take the time to learn to get the kitchen done? If the latter - I'm very impressed.
post #1632 of 2869 Old 08-17-2014, 01:56 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
Funny you mentioned that!
I warned my wife about getting something, anything to keep plate in cubby from moving......she didn't listen to me, but in essence it doesn't matter. The plate just leans against adjacent wall to theater.
The theater room is so well engineered, dampen.......that shared wall is silent as a church mouse!
Four layers of 5/8" Rock with multiple layers of GG, R-24 insulation and 2 x 6 construction with clips and channels......well, sound proofing and isolation is a success!! That 700 lb frig/freezer doesn't vibrate one bit!
Playing WOTW at reference makes theater room a trampoline! But my wife's kitchen is dead silent except for some low rumbling sounds every once in a while.
post #1633 of 2869 Old 08-17-2014, 02:04 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
The later......she learned how to use software on her own! That woman is extremely intelligent......she keeps me on my toes, besides, she married me!
BTW, it does help being isolated for 8 months since we lived at family ranch while home was under construction......she had nothing else better to do!
post #1634 of 2869 Old 08-17-2014, 02:49 PM
wse
wse's Avatar
Liked: 741
Thanks for the kind complements!Those pictures were before I started cloud.....room has really changed! I'll pass on complements to my wife about her kitchen. Since I designed home I just gave her her space to work with. She spent months on CAD designing kitchen and picking appliances, granite, tile ect. I kept my nose out of it except I told her I wanted a grill for steaks. Glad she honored my request since barbecue steaks in Winter is great!
New room pictures please. Yes I love barbecue steaks all year round
wse is offline
post #1635 of 2869 Old 08-17-2014, 03:03 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
By this Monday or Tuesday I'll be done with room aesthetically....ie no more room changing. When specifics are configured for Atmos, then I'll be officially done!
Roger Dressler has been invaluable pushing me in right direction.......more of a confidence issue......he has given me sound advice.
Plan is to hire a photographer skilled in HD. Plan to post those pictures as soon as they are available......Lord knows I have NO skills in that department.....my skill set lies elsewhere!
post #1636 of 2869 Old 08-17-2014, 03:31 PM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
Do you have any lights directly over your seating? I thought you did, but I don't see them your pics.
The Plains Theater Has Begun
J_P_A is offline
post #1637 of 2869 Old 08-17-2014, 05:21 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
Electrician comes Wednesday......we will discuss our options. I was going to wire all four cans, two in rear, two in middle using 12-2.....but couldn't decide exactly what to do.
As room sits, sconces light up room like a Roman candle.......no reason to add more lights. My wife uses room for reading and in her opinion she felt there was no need for added cans too. At this time will wait on our electrician and discuss options with him........he has done well for us so far......besides, he played football for me and is classically conditioned to do as I say!
post #1638 of 2869 Old 08-18-2014, 10:24 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
All six Atmos speaker locations are wired in.......now to figure out which speakers to use .
Cut 10 inch wide, three foot long Linacoustic strips which lines projector leg.
Will button up shortly....
post #1639 of 2869 Old 08-18-2014, 10:29 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
Don't be too quick on getting the speakers. You should see speakers for that purpose which 'exactly' match your current speakers at Expo in Denver. Just saying.
Mfusick likes this.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #1640 of 2869 Old 08-18-2014, 10:54 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I think he said he is using triad, and had a contact there.
Mfusick is offline
post #1641 of 2869 Old 08-18-2014, 11:23 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
Thanks.......
Nothing impulsive ........taking a wait and see approach....but at least I'm ready.
I'd prefer Triad coming up with a solution.......but with my conversations with Triad nothing was mentioned coming down pipeline. I suspect word "exactly" refers to Triad announcing something at CEDIA?
post #1642 of 2869 Old 08-18-2014, 11:28 AM
BrolicBeast's Avatar
Quoted: 1088 Post(s)
Liked: 1131
As a Triad CinemaPlus Platinum & Gold user, I'm REALLY hoping Triad brings some dedicated Atmos ceiling speaker-surprises of similar caliber to this year's CEDIA Expo. The "Atmos enabled" speakers just won't cut it for me.
BrolicBeast is offline
post #1643 of 2869 Old 08-18-2014, 11:57 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
The specs on how atmos works, and is matrixed from the existing surround channels suggests you don't need a speaker that digs down much lower than 180hz, so nothing crazy should be required for a speaker.
Mfusick is offline
post #1644 of 2869 Old 08-18-2014, 11:59 AM
Quoted: 64 Post(s)
Liked: 100
Dispersion will be very important.
post #1645 of 2869 Old 08-18-2014, 12:03 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I would assume so, especially considering ceiling height / distance to LP. Do you happen to know if there is a specific recommended dispersion spec for atmos ceiling speakers ?
Mfusick is offline
post #1646 of 2869 Old 08-18-2014, 12:23 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
Wow.......Gold LCR's for surrounds!
After hearing Noesis 212's, I knew Triad Plats were too much for me......too much as in output!
Erskine Group knew a lot more about my needs than my wants........I give them credit for that. Triad Plats would have been too much for my listening habits!
Still have never heard Plats, Paul Scarpelli even tried to convince me to go that route sight unseen/heard. In actuality.......Gold LCR's are perfect........have listened to only one movie at reference level.......clean uncompressed......but won't do that again!!!!
You must be one bold guy.......or at least like loud, clean, uncompressed sound!
Yeah, I plan to be at CEDIA........hopefully, Triad has something up their sleeve..........but with back and forth conversations with Steve Colburn who is involved with Product Development at Triad.......nothing of any sort was mentioned about Atmos ceiling speakers.
Keeping fingers crossed........
post #1647 of 2869 Old 08-18-2014, 12:29 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
That's exactly what I've been told......even to point of being paramount.
Thanks again for info and feedback.....
post #1648 of 2869 Old 08-18-2014, 01:18 PM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
TMcG is offline
post #1649 of 2869 Old 08-18-2014, 01:21 PM
TheUglyBad's Avatar
Quoted: 20 Post(s)
Just saw this thread. Great stuff!
TheUglyBad is offline
post #1650 of 2869 Old 08-18-2014, 01:44 PM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
I have to say, I'm all over the place with how to go on this. What I've read recently indicates that those attending the Dolby demos have slightly preferred the ATMOS enabled speakers over the in/on-ceiling speakers. I'm still having a hard time making my brain believe that. Some of the reviewers have even said that having heard the demo, they were inclined to use the ATMOS enabled speakers over ceiling speakers.
That said, I think I'm still leaning towards ceiling speakers, but it sounds like you can't lose regardless of which avenue you choose.
J_P_A is offline
Sony Vpl Vw1000es Projector , Marantz Av8801 , Peavey Ipr2 7500 Power Amplifier 7500 Watts
