Another Omaha-area build -- VERY preliminary basement plans - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 65 Old 03-06-2013, 05:54 PM
Tedd's Avatar
Quoted: 1151 Post(s)
Liked: 440
Strikes me you could be taking a page from BigMouthinDC's room...
http://www.avsforum.com/t/837848/minimalist-approach-to-screen-wall
What about some removeable window plugs that can be stored away?
The rears surrounds could be in-ceiling speakers that aim forward. Having them in-ceiling and further back,
would make it easier to set surround levels and keep them out of circulation space. (The rears as drawn,
would be distracting and draw attention to themselves at the nearest seats.)
Tedd is offline
post #62 of 65 Old 03-06-2013, 07:18 PM - Thread Starter
trancemitr's Avatar
Quoted: 17 Post(s)
Tedd, thanks for the link. I haven't looked too much at it yet, but I know you can't generally go wrong following Big. The window plugs could be an idea worth looking into; I haven't even seen someone do something like that before. As for the rears, I hadn't really thought about in-ceilings. I know if I hung bookshelf speakers it probably would be distracting, but what do you mean about it being easier with the in-ceilings to set surround levels?
trancemitr is offline
post #63 of 65 Old 03-06-2013, 07:41 PM
Tedd's Avatar
Liked: 440
The surrounds could be pushed further back and not be in the way (and be practically invisible if ).
Big's rear surrounds are in ceiling too:
http://www.avsforum.com/t/1434671/what-did-you-pay-for-your-speakers
And there's commercial offerings like the bronze Triads and B&W's
Google Images can be a great research tool too.
As for setting volume levels for surrounds, if you set a level suitable for seating ten feet away, then the volume level will be too loud for a seat a foot or two,
away. That speaker will then draw excessive attention to itself at the nearest seats.
The trick is to get the surrounds up higher and further away, so the differential between seats becomes less.
Tedd is offline
post #64 of 65 Old 03-06-2013, 08:17 PM - Thread Starter
trancemitr's Avatar
Quoted: 17 Post(s)
Alright, I get what you mean now. I hadn't put much thought into the listening experience for the rear seats really as most of the time it will be just the two of us.
post #65 of 65 Old 12-03-2014, 07:07 PM
yamahaSHO's Avatar
I have re-found your thread. Post some pictures!
EDIT: I found your new thread.
-Jason
The "Z" Family Theater - Almost "complete".
-Not your average sub build
-Klipsch Sonosub Build
SONY quality and customer service FTMFL
yamahaSHO is offline
