Moving past 7.1 into 9.1/11.x/3D ObjectAudio in HT via AudysseyDSX/DolbyPLIIz/DTS Neo:X™/Auro-3D - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #721 of 894 Old 03-17-2014, 12:03 PM
wse
wse's Avatar
Quoted: 1976 Post(s)
Liked: 739
The ATSC 3.0 3Daudio codec is supposed to be chosen in 2015"
Nothing before that :( I guess that way we can all save to be able to buy a new processor when they come out
wse is offline
post #722 of 894 Old 03-17-2014, 12:22 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5283 Post(s)
Liked: 4167
Originally Posted by Josh Z View Post
SRS MDA was a hybrid format like Atmos. An SRS rep confirmed that to me just prior to their acquisition by DTS. I would assume that DTS-UHD retains that characteristic.
A Hollywood sound mixer friend of mine claims that this type of hybrid formatting is necessary, because some sound elements in a movie soundtrack still make much more sense to embed as channels rather than objects. For example, you don't want the musical score or ambient background tones to move around from speaker to speaker when the camera POV changes. Those should remain fixed to specific channels regardless of what happens on screen. Sound effects, meanwhile, are frequently more directional and can be tied to the visible action.
This seems to be the consensus.... according to my industry sound-mixer friend. wink.gifbiggrin.gif
Nothing before that frown.gif I guess that way we can all save to be able to buy a new processor when they come out
Sounds about right.
Scott Simonian is offline
post #723 of 894 Old 03-17-2014, 01:15 PM
Josh Z's Avatar
Quoted: 2137 Post(s)
Liked: 1434
It only makes sense to give mixers the flexibility to embed sounds using a combination of both methods, rather than exclusively one or the other. I imagine that any future sound formats will continue to use this hybrid approach. If a mixer really didn't want to use the 9.1 channel beds, he could always just leave them silent and focus on the objects.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #724 of 894 Old 03-17-2014, 01:44 PM
Nightlord's Avatar
Quoted: 711 Post(s)
Liked: 237
To generalize it even more, the mixer shouldn't have to consider the format it ends up on when doing the mix, that should be possible to generate automatically to different formats when done.
Under construction: the Larch theater
Nightlord is offline
post #725 of 894 Old 03-17-2014, 02:27 PM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 895
...or, preferably, one universal format.
ambesolman is offline
post #726 of 894 Old 03-17-2014, 03:07 PM
Dan Hitchman's Avatar
Quoted: 3413 Post(s)
Liked: 1766
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #727 of 894 Old 03-17-2014, 03:11 PM
Liked: 1766
So, would you say that Dolby Atmos and DTS-MDA (aka DTS-UHD) are pretty much the same thing when it comes right down to it? Or does one format have some added benefit to the mixer and/or listener over the other?
I'm just wondering if both home versions would be taking their TrueHD and Master Audio bit-for-bit lossless codecs and just adding object extensions to them, and whether they would bump both consumer formats' channel beds from 7.1 to 9.1... or if these codecs are from-scratch.
I also hope they do allow for more than, let's say, a 11.1 speaker layout for a much more immersive 3D effect.
post #728 of 894 Old 03-17-2014, 03:12 PM
Bass Enabler
Liked: 4167
Maybe not one 'format' but more so one agreed upon overall compromise speaker layout.
Later on be it Dolby, DTS, Auro, etc it is up to the processor at home to re-route the signals properly. This is key and by far the standout reason to move to object based audio for home consumer use.
post #729 of 894 Old 03-17-2014, 03:19 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
As a good atmos estimate, im guessing a 5 speaker "X" on a home theater ceiling might work.
Blazar!
blazar is offline
post #730 of 894 Old 03-17-2014, 03:20 PM
Liked: 1766
I still don't quite see the benefit of Auro3D in the context of moving towards object surround as the SMPTE committee seems to be doing. It's yesterdays news in terms of technological advancement and system scalability.
post #731 of 894 Old 03-17-2014, 03:22 PM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
LOL! I was typing this exact point when your post came through. Just like we have "standard" 5.1 and 7.1 speaker layouts used by all the processing CODECs, so too should there be an optimal speaker layout for object-based surround. I think a lot depends on how many independent channels content providers intend to incorporate in 4K Bluray and high-resolution streaming services. If the max they will ever provide is 13.1, then we're stuck. If they go with the full-blown DTS-UHD setup shown several pages ago, that's a 22.1 system. It'd be nice if they made 22.1 available and then an end-use can configure what speakers they actually have, with the processor making the necessary accommodation to the surround processing.
TMcG is offline
post #732 of 894 Old 03-17-2014, 03:25 PM
Liked: 1766
If Dolby sticks with their recommended speaker layout like commercial Atmos installations, there would be left/right top speakers, but no center mono top speaker. Any sounds concentrated in one location above or behind somebody's head tends to be mistaken as coming from in front of the listener.
post #733 of 894 Old 03-17-2014, 03:30 PM
Josh Z's Avatar
Liked: 1434
I don't know enough about DTS-UHD, or Dolby's home version of Atmos, to make that comparison.
Josh Z
Josh Z is offline
post #734 of 894 Old 03-17-2014, 04:11 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Yeah good point, honestly though I am wiring now for height speakers but no ceiling yet. I suspect its already going to pan really well and be very enveloping... The ceiling speakers I'm still not sure about. I might stick up some temporary speakers on a pair of ladders or something once I get an Atmos unit and then see how relevant the ceiling speakers are in a home environment.
Blazar!
blazar is offline
post #735 of 894 Old 03-17-2014, 05:02 PM
Liked: 1766
The top speakers finish the x/y/z sound location axis patterns, especially for object based surround formats like Atmos and MDA. They create the illusion of height and spatial depth that is the necessary third dimension, which is one of the key benefits of going beyond two dimensional 5.1/7.1 sound. Another reason why the best Atmos installations have mirrored top speakers for every side wall surround.
post #736 of 894 Old 03-17-2014, 05:25 PM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2900
The object-oriented part (metadata and rendering) will be from scratch, but there's no reason other parts have to be.
The channel beds and object files aren't going to be delivered to consumers as uncompressed PCM, so some form of lossless packing will be used for Blu-ray, in which case why not use familiar technologies (TrueHD, DTS-MA). For broadcast, cable, satellite and streaming, the audio can be transmitted as lossy compressed DD or DD+. I can't imagine the metadata taking up much bandwidth.
As for structure, the likely approach was posted last year in the Atmos thread:
Originally Posted by Roger Dressler View Post
In order to provide a compatible track for, say, some future BD format release, there will need to be a 5.1 or 7.1 complete mix. The "extras" (i.e. objects and other bed channels) will be delivered as extensions, and using the same techniques currently used for lossless codec extensions, the original mix will be reconstituted in the "object aware" surround processor, to whatever degree the available speakers permit.
So it will probably be a 5.1 or 7.1 track with an extension packet containing the objects. Since HDMI 1.3 can transmit TrueHD and DTS-MA, even a BD player from 7 years ago should be able to bitstream the soundtrack.
Current AV receivers will see a complete 5.1 or 7.1 track, containing all the sounds in the soundtrack. Users will have the option to upmix using PLIIz or Neo:X to a 9.1-speaker layout that includes a couple of heights. Newer (object-aware) receivers will recognize the extensions and route the objects to the appropriate speaker(s). Those object sounds will also be inverted and used as out-of-phase cancellation signals to slice them out of the channels.
Same approach was used during the DVD days for the DTS-ES Discrete 6.1 format, which was a complete 5.1 track plus an extension packet containing the discrete surround-back channel, which was sent to the rear speakers with an out of phase version cancelling those sounds from the side speakers. No need to re-invent that approach for Atmos on Blu-ray.
Scott Simonian likes this.
Sanjay
sdurani is offline
post #737 of 894 Old 03-17-2014, 05:31 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
If the base layout isn't changed beyond what's already accepted and pretty well standardized, then backwards compatibility would seem easier (IMO), and all the height extension can be either matrixed out (PLIIz, etc.) or mapped to height speakers via object data. The beauty of the object system is that it doesn't require a specific layout - so they don't need to settle on one, IMO. Better would be to settle on a few general guidelines, like "include as many elevated speakers as is practical, seeking to leave no more than 45 degrees of azimuth or altitude between speakers." I would think the existing psychoacoustic research could be adequately summarized to generate such a recommendation.
(or basically, what Sanjay said.)
HopefulFred is offline
post #738 of 894 Old 03-17-2014, 05:42 PM
Bass Enabler
Liked: 4167
Lol, yeah pretty much the same thing. Yes.
post #739 of 894 Old 03-17-2014, 05:42 PM
sdurani's Avatar
Liked: 2900
]If the base layout isn't changed beyond what's already accepted and pretty well standardized, then backwards compatibility would seem easier (IMO), and all the height extension can be either matrixed out (PLIIz, etc.) or mapped to height speakers via object data.
Now that would be a nice added touch: if you're going to downmix an Atmos track to 5.1 or 7.1 anyway (for backwards compatibility), then might as well matrix encode the height information using PLIIz or Neo:X so that current AV receivers can decode those signals. This way, when you use PLIIz or Neo:X during playback, the height speakers get information that was intended to be heard from above.
Sanjay
sdurani is offline
post #740 of 894 Old 03-17-2014, 06:15 PM
thebland's Avatar
Quoted: 1490 Post(s)
Liked: 841
This is all cool but likely 2-3 years for new release Blu Rays in Atmos.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
post #741 of 894 Old 03-17-2014, 06:16 PM
Liked: 1766
It won't be so much because of today's Blu-ray players (since these new object codecs will probably only be for UHD media and beyond), but because they want the soundtracks to be backwards compatible with decoders that only have DTS-MA and Dolby TrueHD included. I would also assume if DTS and Dolby want 9.1 channel beds, the extra height channels will also be extensions (besides the sound objects) to the 7.1 channel base track. I can see the first players would have two different HDMI outputs just like they did with 3D when that rolled out.
DTS's Coherent Acoustics codec gets a little more jumbled because it would be lossy core + lossless data extensions + lossless channel extensions (9.1) + object extensions. Dolby TrueHD would be Meridian Lossless Packing in a 5.1 channel bed + two extra back channel lossless extensions (7.1) + two extra lossless top channel extensions (9.1) + object extensions. Whew! If that's they way they end up handling DTS-UHD and Dolby Atmos for the home.
Personally, I would hate to have to continue the dumbed down broadcast and internet audio with lossy compression. I would much rather they went lossless so there was a consistency of audio quality across the UHD media board. God knows there won't be with video quality.
post #742 of 894 Old 03-17-2014, 06:22 PM
Liked: 1766
I really, really doubt you'll see these new audio codecs added to regular Blu-ray. UHD media and beyond, yes. They want to get you to buy into the next television format. They'll be included from the start in any new UHD media, if the track was mixed with object data in the first place or was re-mixed/re-rendered to pump up certain catalog titles. It'll be regular channel based DTS or Dolby lossless as before if they're only old school mixes.
post #743 of 894 Old 03-17-2014, 06:24 PM
wse
wse's Avatar
Liked: 739
Originally Posted by TMcG View Post..... It'd be nice if they made 22.1 available and then an end-use can configure what speakers they actually have, with the processor making the necessary accommodation to the surround processing.
I agree
wse is offline
post #744 of 894 Old 03-17-2014, 06:29 PM
Liked: 1766
tt'd be nice if they made 22.1 available and then an end-use can configure what speakers they actually have, with the processor making the necessary accommodation to the surround processing.
I agree as well, but they would have to make these object decoding enabled electronics (receivers and possibly pre-amps) modular with data-linked add-on units that can increase your speaker layout for much improved 3D audio as I've talked about before. That's the beauty of object surround... the surround effect gets better the more speakers you add.
zuluwalker likes this.
post #745 of 894 Old 03-17-2014, 07:33 PM
sdurani's Avatar
Liked: 2900
No one said the soundtracks would be backwards compatible "because of today's Blu-ray players". Just pointed out that using current packing/compression codecs would have the benefit (intended or unintended) of allowing bitstreaming from even old BD players.
Yup, anything beyond current 8-channel soundtracks will be carried in the extension packets.
Only for 4K players.
I'm the other way 'round: when it comes to streaming, broadcast, sat/cable, I'd take an Atmos soundtrack in Dolby Digital rather than 2 channels of lossless. The difference in fidelity is small compared to difference in spatial resolution.
Sanjay
sdurani is offline
post #746 of 894 Old 03-17-2014, 07:41 PM
Just add water and stir
zuluwalker's Avatar
Quoted: 46 Post(s)
Liked: 490
Now this is interesting food for thought.
zuluwalker is offline
post #747 of 894 Old 03-17-2014, 07:41 PM
Liked: 1766
There's one teensy problem with that. What if the only way you can watch a particular show or movie is via the internet? One day they may not release a physical product no matter how much the home theater community wants one. Many people would want the highest possible sound quality no matter what and whatever specs. the industry players come up with for UHD broadcasts and internet content should take that into consideration.
post #748 of 894 Old 03-17-2014, 08:14 PM
Quoted: 490 Post(s)
Liked: 422
I think virtually everyone can agree with that statement as written. The issue is what you define as quality. I think most listeners on most systems would perceive the better spacial resolution that Sanjay is after as a better quality improvement over good old Dolby Digital stereo, say, than Dolby TrueHD, also stereo. Maybe you're taking that as given, in context, not sure. I still think that lossy discrete 7.1 or 9.1 would offer more improvements over 5.1 TrueHD, but I suppose that's debatable, maybe.
sdurani likes this.
post #749 of 894 Old 03-17-2014, 08:43 PM
sdurani's Avatar
Liked: 2900
What if the US gave away the internet and we couldn't do streaming any more? The internet-only hypothetical won't be a reality for a while, what with a 4k disc in the works. In the real world, bandwidth for streaming is limited, so the choice is between a couple channels of lossless or more channels of lossy. You already know my preference.
Even if they had the best of intentions to deliver the highest possible sound quality, the required bandwidth cannot be willed into existence. Limited bandwidth means compromising.
Sanjay
sdurani is offline
post #750 of 894 Old 03-17-2014, 08:53 PM
sdurani's Avatar
Liked: 2900
Agreed, even about the "debatable" part. Lossy can reach a point of diminishing returns, where raising the data rate doesn't buy audible improvements. But it can save you enough bandwidth to be able to have many more channels (and objects, hopefully).
Just to remind everyone, the discussion about lossless vs lossy is in the context of streaming, broadcast, cable, sat, etc. Optical discs carry lossless audio, and will continue to do so into the forseeable future (even with object oriented soundtracks).
Sanjay
sdurani is offline
Emotiva Xpa 5 5 Channel Power Amplifier , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Sony Vpl Vw1000es Projector , Panamax , Audyssey
