Min length room for two seating rows. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By BIGmouthinDC
post #1 of 18 Old 10-27-2012, 11:25 AM - Thread Starter
Jimbo2012's Avatar
I was going to make my room 14 foot long with a 100" screen
But it may be to short for two rows.
What do you think the min length should be?
I may be able to push it a bit.
Jimbo2012 is offline
post #2 of 18 Old 10-27-2012, 11:43 AM
Quoted: 3255 Post(s)
Liked: 2743
If you can push back the wall put your first row back of chairs at 11.5 ft and then you need 6.5 ft for a second row unless you don't use recliners for the second row. Even then best practice is not to have the back row smack against the wall for audio purposes. At those distances think about 115-120 diagonal for a 16:9 or 130 wide 2.35:1.
DigitalAV likes this.
post #3 of 18 Old 10-27-2012, 11:51 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
What type of seats will you be using?
What type of screen?
My room is 19' deep and eyeballs in the 1st row are 9-1/2' back from a 115" wide 2.35.1 screen. I wouldn't want to be any closer. I've also sat 9-1/2' from a 105" 16:9 screen, and that is pretty much how close I can be without feeling uncomfortable. With a 100" screen, you might be able to cheat your front row to 9', but that's really close. Depending on your screen type, you may start to see the weave in the screen at that distance.
Eyeballs in the 2nd row are a little over 16' back, which doesn't leave much room behind the 2nd row. When fully reclined (sleep mode), 2nd row heads will be very close to the back wall. When normally reclined during movie watching, I have a few feet of breathing room, but I would have preferred more to get the most out of the rear surrounds.
So, to answer your question, I wouldn't make the room any smaller than 19' if you plan on having 2 rows of reclining seats. In a shorter room, you might look at reclining seats in the front and traditional theater seats or a couch in the back.
Spaceman is offline
post #4 of 18 Old 10-27-2012, 12:09 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
You could make it work but you'd be sitting pretty close to the screen, I just went and did some quick measurements in my theater. My rear riser is 6' wide and even with the chairs reclined it gives you just enough room to squeeze by them if someone was sitting in it reclined. There's about 9"-10"s of room between the first row. But at only 14' deep for your room if you did have a 6' wide rear riser that would only give you about 4'6" to 5' to the screen after the first row of seats. That might be a little close for a 100" screen.
jbrown15 is offline
post #5 of 18 Old 10-27-2012, 12:13 PM - Thread Starter
Jimbo2012's Avatar
It's going to be a painted screen wall,
so it sounds like it will not fit I can push it to 16 ' overall length but that's about it.
post #6 of 18 Old 10-27-2012, 12:59 PM
Liked: 2743
You must have very small seats and/or short people. Sorry but 6 1/2 is the minimum for full size theater recliners. Even then you need to lower the foot rest to let people pass.
post #7 of 18 Old 10-27-2012, 01:05 PM - Thread Starter
Jimbo2012's Avatar
It's not their height......it's their width:rolleyes:
They may also be vegans
post #8 of 18 Old 10-27-2012, 01:16 PM
jbrown15's Avatar
Liked: 1993
I have full size powered theater recliner seats and I'm not short, and it works with 6'. 6 1/2 isn't the minimum for full size recliners. And you can get by without having to have someone lower their seat while reclined. Sure I wish I had more room, like I said I have about 9" to squeeze threw. And it works fine.
jbrown15 is offline
post #9 of 18 Old 10-27-2012, 01:28 PM
jbrown15's Avatar
Liked: 1993
I wish I had the room to make a wider riser the was 7' wide but I didn't, so I had to make it 6' wide. With your room size you'll have to make compromises no matter what if you wanted two rows.
jbrown15 is offline
post #10 of 18 Old 10-27-2012, 04:37 PM
Liked: 2743
What model seats do you have? The seats I've seen, Mostly Berkine, Lazy boy and Fusion needed 6.5
post #11 of 18 Old 10-27-2012, 05:07 PM - Thread Starter
Jimbo2012's Avatar
one other thought since it looks like one row of 4 seats will be the way to go, should i make one riser 6.5' across the width of the room or just put them on the floor?
I have a 10' ceiling, so an 8" high riser may work, what do you guys think?
post #12 of 18 Old 10-27-2012, 06:47 PM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
If you are only planning 1 row of 4, I see no reason to put them on a riser.
Spaceman is offline
post #13 of 18 Old 10-27-2012, 06:56 PM
Liked: 2743
If you go with one row put the seats with their backs 2-3ft off the back wall.
post #14 of 18 Old 10-28-2012, 12:24 AM
jbrown15's Avatar
Liked: 1993
I honestly can't remember what brand of seats they are, I bought them from my local Audio/Video store. I just did some measurements, they only need to be 2.5" from the back of the wall and in fully reclined position they are 63" in length. So you only get about 6" to squeeze by when they are in full recline. So I was off when I said 9"-10". It's a little tight but they do work. The backs aren't as tall as some of the Berkine's I looked at getting but they are comfortable and work great.
jbrown15 is offline
post #15 of 18 Old 10-28-2012, 08:28 AM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 41
Here's a very very nice example of a short room (16x11) with a 108" screen and two rows of seats:
http://www.avsforum.com/t/897055/the-arthouse-fomerly-the-grindhouse-planning-and-construction-thread
How myny seats do you want in the room? Also, how wide is the room?
My Theater Room JVC RS4910, Panamorph UH480, 148 in. 2.40:1 Dalite HD Pro 1.3, Klipsch THX Ultra II's x 7, Quad JTR Captivator S1 subs
My Previous Non-Dedicated space
RobZ is offline
post #16 of 18 Old 10-28-2012, 06:18 PM - Thread Starter
Jimbo2012's Avatar
The room is 10' wide but open on one side so I can push a bit wider, don't need isles
Interesting thread using two rows, tks
post #17 of 18 Old 10-28-2012, 06:23 PM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 41
How about a row of five space saver chairs (Lane 175, Palliser Bullets, etc) in the IOIOOOIOI configuration?
RobZ is offline
post #18 of 18 Old 10-29-2012, 09:35 AM - Thread Starter
Jimbo2012's Avatar
A bit to expensive for this little room,
