HDMI Issues - inwall/under carpet - AVS Forum | Home Theater Discussions And Reviews
Old 10-30-2012, 07:34 PM - Thread Starter
e485926's Avatar
Hi all -
So i have a Pioneer vsx 53 receiver. I just connected my JBL speakers to them and tried to connect it to the PS3 and WD Live player. After everything was hooked on, i tried my new 35 ft long HDMI wire to connect the receiver to the TV ( i plan on using the receiver with the TV and the Projector - thus i need a 35 ft hdmi wire), there were lines and spots on the TV. I used the 2nd HDMI and i couldnt even see anything. So i thought my receiver had a problem, so brought it close to my TV and used the normal HDMI and it worked well. Here is what i bought -
I bought 2 35 ft wires - here is the link
BlueRigger HDMI Cable (35 feet) - CL3 Rated for In-wall Installation
http://www.amazon.com/gp/product/B005LJQM3Y/ref=oh_details_o05_s00_i00
What do you guys recommend i use? i plan on returning the ones i bought but i dont know which brand and type will work in my setup. Can you suggest what i get?
Your help is greatly appreciated.
e485926 is offline
Old 10-31-2012, 09:39 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 101
Bluerigger HDMI cables are not approved or certified. Go to www.hdmi.org to find a list of adopters.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
