AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Dedicated Theater Design & Construction (http://www.avsforum.com/forum/19-dedicated-theater-design-construction/)
-   -   Lighting Underneath Seat (http://www.avsforum.com/forum/19-dedicated-theater-design-construction/1437641-lighting-underneath-seat.html)
mantaraydesign 11-05-2012 12:43 PM
Hi,
What type of lighting do I need to put underneath my couch? I was watching a video and saw a really cool blue lighting underneath the seats. The color does not have to be blue, it can be red, orange, white, yellow, purple, pink, etc. Can I get something like that at Home Depot?
Here is the youtube video about home theater building:
http://www.youtube.com/watch?v=MrJvzSGV9T8&feature=related
Thanks for any advice!!
Brad Horstkotte 11-05-2012 08:49 PM
Rope light would be my guess?
Frosteh 11-05-2012 10:44 PM
LED's or cold cathodes would work great. I recommend LED's. http://www.elementalled.com/shop-by-item/strip-lights.html
mantaraydesign 11-06-2012 04:27 AM
Thanks you guys!
I will give it a try.
IWin40 11-24-2012 10:35 PM
Check out Lowes, http://www.lowes.com/pd_696-24994-HTP904E_0__?productId=3316942&Ntt=led&pl=1&currentURL=%3FNtt%3Dled&facetInfo=
Cryon LED lighting systems. I used these behind an acoustic transparent screen to show the speakers behind. Turned out pretty cool.
ADDUpstate 11-25-2012 02:30 PM
barlighting.com
i've used them for behind screen and actual bar lighting. great and easy to use.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
