Acoustically Transparent Screen or Standard Fixed Frame - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 11-12-2012, 01:20 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 107
ANSI White would not necessarily be the same and color balance could be different. None-the-less, directional or multilayer coatings cannot be used on woven screens (at least yet). The coatings have to be applied BEFORE the weave process. If they were applied after, then the "holes" would be plugged. Since they are applied before the weave, one has no control over directionality, twist, etc.
Woven screens are less expensive to construct ... you go to a mill, specify your thread, and weave .... bzillions of yards are produced. You order a screen, they cut your order from the roll it off it goes. If the uniformity is a bit off, it's a bit off. Vinyl screens (well, Stewart anyway) go through an extensive inch by inch QA. For some, that may not be important...for others it is.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Chairman
www.erskine-group.com
Dennis Erskine is offline
post #32 of 34 Old 11-12-2012, 03:10 PM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 87
LeBon is offline
post #33 of 34 Old 11-12-2012, 04:45 PM
Brad Horstkotte's Avatar
Liked: 69
Like many aspects of my theater, my choice of Seymour CenterStage XD DIY material was the result of many hours of online research, much of it second hand information from those here whose opinion I respect, followed by a leap of faith. Well, there was a material sample in there too, but that breaks the whole "like many aspects of my theater" bit. I wouldn't change a thing, it has worked out great - 136" wide screen, front row at about 12 feet.
As Dennis mentioned, the measurable A/V differences may or may not matter to you. Everyone's ears, eyes and bank account are different.
Brad Horstkotte is offline
post #34 of 34 Old 11-12-2012, 10:34 PM
SierraMikeBravo's Avatar
Quoted: 349 Post(s)
Liked: 221
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is offline
