Ahh..Laminate floor in my "home theater", please assist in my dilemma/strategy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 11-14-2012, 01:19 PM - Thread Starter
audio4me's Avatar
Long story short, this is my prospective Home Theater:
Rough top-down blueprint:
Pic from Position 5 (ignore the junk):
Yes, the space is not ideal but it I have to use it.
It has wall to wall laminate which echoes extremely well. I'm obviously concerned about reflections.
I'm tentatively planning to have the A/V at the 2 position and listening from the 5.
Can't afford $500 for W2W carpet despite being the best options.
The question: Can strategically placed throw rugs or carpet remedy this issue? Are there any techniques or general rules of thumb known to work? I'm even entertaining the idea of tiles on the walls and ceiling if I have to.
The goal is to do this in a tasteful, budget conscious manner. I'm sure this seems pretty half-@$$ed to some but this is part of exploring every single option before I commit, and I'm sure others have experienced this problem. I did do a search but couldn't find anything specific to throw rugs/carpeting sections used in this way..
W2W Carpet in basements is a scary thing, I do have an older house I just moved into to and while I have no leak or moisture issues, I’d rather find out with crap laminate, then to tear up my new carpet.
My speakers are Polk Monitor Series II's, CS2 Center flanked by M70's, M40-Rears with a BIC V1020 sub running via Denon 5.1 receiver.
Any experience with this would be extremely helpful.
audio4me is offline
post #2 of 14 Old 11-14-2012, 01:23 PM
cdika17's Avatar
Liked: 27
Go to a carpet wholesale store and get an end of the roll deal and use area rugs, i had laminate in my theater and was horrible for sound and reflection, now I am in total remodel stage, everything ripped out. Not much a person can do but use area rugs.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #3 of 14 Old 11-14-2012, 01:40 PM
fritzi93's Avatar
Liked: 41
I agree, an area rug would be easiest. It might or might not be good enough for you, depending on how discriminating you are.
My HT is ~ 14' x 14', with wood laminate floor. I went to a bargain outlet and got an 8' x 10' Persian style rug for about 100 bucks. (A similar rug runs about 200 bucks at Lowes, for instance.)
fritzi93 is offline
post #4 of 14 Old 11-14-2012, 06:32 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Some wall mounted sound absorbing panels would do a lot too. Especially on the side walls to catch first reflection from the left and right speakers, and on the wall housing the TV. Carpet on the wall won't do much of anything though.
You could build some decent panels from rigid fiberglass insulation or duct board.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #5 of 14 Old 11-15-2012, 10:19 AM - Thread Starter
audio4me's Avatar
Thanks for the replies.
I guess nothing revolutionary needs to be done here. Pretty much what I was planning on doing.
I do however question the rigid float idea. I have some extra left over from a project and just testing it with my own voice and doing a "pssst" sound I found it localizing and reflecting a little. I would think a softer, porous panel would be much better.
Anyone with before/after experience in using wall panels in a reflective room?
audio4me is offline
post #6 of 14 Old 11-15-2012, 10:41 AM
mn_hokie's Avatar
Liked: 27
2 inch rigid insulation wrapped in a fabric frame should do the job. My favorites are the Chameleon frames.
mn_hokie is offline
post #7 of 14 Old 11-15-2012, 12:31 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
Originally Posted by DavidK442 View Post
I think the notion that a reflective floor is an acoustic nightmare only tamed adequately with wall to wall carpeting is a home theater thing.
I think that's true - I think with enough other acoustic features in a room (whether designed deliberate treatments or simply furniture and people), there's no harm in a hard floor; however, it's easy in a sparsely decorated room to have troublesome flutter echo between the floor and ceiling.
HopefulFred is online now
post #8 of 14 Old 11-15-2012, 01:44 PM
SierraMikeBravo's Avatar
Quoted: 335 Post(s)
Liked: 214
The key if you have reflective floors is the ceiling. Often the most offensive surfaces acoustically are the floor and ceiling due, in part, to their respective surface areas. One MUST be treated. It is often easiest and cheaper to treat the floor. I.e. wall to wall carpeting. If the floor is not treated, then the ceiling must be...and well treated at that.
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is offline
post #9 of 14 Old 11-15-2012, 03:38 PM
Quoted: 490 Post(s)
Liked: 422
Shawn - I've understood from reading (Toole) that foam carpet pad is not as good for sound as a felt pad - which Toole describes as "common" - but it seems like most installers carry and recommend foam pads. Can you comment? Is the difference meaningful?
(I hope this isn't to much of a distraction from the OP's question - I think it's germane, and I hope he's understanding.)
post #10 of 14 Old 11-15-2012, 05:32 PM
Quoted: 335 Post(s)
Liked: 214
Carpet in itself is not thick enough to affect too much except the highest frequencies. However, being close to the boundary may offer some measurable difference but this is really frequency dependent. In my opinion, carpet assists in the reduction of reverberation. You can address more broadband absorption on the ceiling. Foam has never been a popular choice for absorption (open vs closed cell) and its density (mass) will likely be less than that of felt. From that point of view, I can see where Toole is coming from. However, the carpet guys may like foam because it is probably lighter and easier to carry and it is likely more resilient than felt.
Shawn Byrne
shawn@questai.com
post #11 of 14 Old 11-15-2012, 05:45 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Foam or rubber is cheaper with massive margins, thats why they use it (in Australia at any rate).
Felt is actually a lot more resiliant and used in large commercial (office) flooring jobs - it keeps its shape (flatness) unlike rubber and foam which compresses to easily and doesn't withstand the wear and tear
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #12 of 14 Old 11-15-2012, 09:35 PM
Quoted: 335 Post(s)
Liked: 214
Resiliant part was a guess, so I stand corrected on that one. Thanks Elill!
Shawn Byrne
shawn@questai.com
post #13 of 14 Old 11-16-2012, 01:23 PM - Thread Starter
audio4me's Avatar
Some good information here, I appreciate the discussion.
audio4me is offline
post #14 of 14 Old 11-27-2012, 02:14 PM
cityinruin's Avatar
What did you end up doing and how did it work out ? I have hard laminate floors in a room with two 12 foot high brick walls and am struggeling with reflections too.
cityinruin is offline
