Help with hiding all my A/V equipment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-20-2012, 05:21 AM - Thread Starter
mgp32's Avatar
I just bought my first house about a year ago and plan to finish my basment sometime in the near future. I plan to mount a 60"+ LED TV on the wall and run all my a/v lines to the utility room where I will have my A/V equipment. (I also might do a projector but not sure yet) I will have a dirctv receiver, PS3 and Home theatre receiver. My question is, how would I control these decives from the family room since they are all hidden. Im already running my Directv receiver upstairs on R/F since its hidden in the closet so I probably can't do that with this one since they will most likely interfere. I'm new to all this and any help would be appreciated.
thanks
mgp32 is offline
post #2 of 9 Old 11-20-2012, 07:45 AM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
The DirecTV RF remotes are "paired" with the receiver - you can use more than one with no problems...
If you put the whole stack in one location, you can use an HDMI-over-cat5e extender with IR repeating to handle this. I'd recommend the HDBaseT technology to do this, and Monoprice has a great little unit which includes IR repeating as well as Ethernet in the mix:
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011012&p_id=8123&seq=1&format=2
Also, spend some time reading in the 'Home A/V Disttribution" forum a few down from here, where this topic is common...
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is online now
post #3 of 9 Old 11-20-2012, 08:08 AM
dirtydiesel55's Avatar
I have the exact same setup... Search logitech RF remotes (Logitech's Harmony 890), they do have more advanced models but they are awesome!
dirtydiesel55 is offline
post #4 of 9 Old 11-20-2012, 09:17 AM - Thread Starter
mgp32's Avatar
Thanks for the responses so far. I have one question though, why would I need to hook up cat5? Can anyone show me a wiaring diagram?
Thanks again...
mgp32 is offline
post #5 of 9 Old 11-20-2012, 09:19 AM
secondhander's Avatar
Pretty much what's been said here. In general you would use either an IR repeater kit or an RF remote.
secondhander is offline
post #6 of 9 Old 11-20-2012, 09:51 AM
I did try an ir repeater first, that being said my lighting in my theater badly affected it when i tried using my remotes, it was a pain. Bought the logitech remote it worked flawlessly.. (Not saying that you would have the same problem, but just throwing it out there)....
post #7 of 9 Old 11-20-2012, 09:54 AM
randy98mtu's Avatar
I have a pair of Harmony 900 remotes for my basement. One for my theater, one for the living room. They work quite well. A little lag sometimes, but overall very good. The lag was noticed when adjusting the volume on my Denon. I moves very slowly 1 touch at a time. But if you hold it down, the lag could bite you and take the volume too high. It's a bit of a balancing act.
randy98mtu is offline
post #8 of 9 Old 11-20-2012, 10:55 AM - Thread Starter
mgp32's Avatar
Or in other words, just buy a harmony remote and it should be able to control my future a/v receiver and directv without interfering with my upstairs directv thats using RF? It sounds like I shouldnt have to worry about my ps3 since its bluetooth and will only be about 15 feet away and only traveling through one wall.
Does that sound right?
mgp32 is offline
post #9 of 9 Old 11-21-2012, 10:14 AM
I have two rf direct tv remotes in my house and the logitech remote, there is no interference with the logitech remote.
