The Alberta Room , building and planing - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 01-13-2013, 10:39 PM - Thread Starter
Tama's Avatar
Im just about to start wiring the room , but i had a question maybe someone could help me with , ive seen some post about people building boxes around their speakers for inwall,
ive got Klipsch 5800 w was curious if anyone knew what volumn of box was best for them in wall or should i just install them in the insulated wall and hope for the best , ive looked for information on this but cant seem to find any , or should I contact Klipsch on this matter ?
Tama is offline
Old 01-14-2013, 09:00 AM
JamesB77's Avatar
I would contact Klipsch and see what they recommend. Most inwall speakers are designed to work with really large rear spaces and if you build a box too small it could affect the sound. Klipsch may even have a backerbox designed for the speaker. If you just cut into the drywall you will negate any soundproofing you plan on doing.
An Aspen Woods Theater - Under Construction
JamesB77 is offline
Old 01-19-2013, 11:19 PM - Thread Starter
Tama's Avatar
contacted Klipsch was told i need 4 inches of wall space from front of speaker side. dont think he understood my question about speaker volumn within the wall, maybe ill have to call them ,
anyways been making some progress determined im going to go with a 107 inch screen on diagonal , 16:9 format which is approx 96x54
going to set the bottom of the screen at 30 inchs off of the floor ,
Had some electrical run this week , got 2 dedicated 120/20a circuits , 2 120/15 amp dedicated circuits , one 120/15 amp circuit for the 2 subs
dedcided to run 3 potlights in the front of the room ceiling approx 4 feet from front wall , and in the same circuit 2 more near the centre of the room , couldnt mount a 3rd because of ducting , and 2 more on a seperate circuit 36 inches off of back wall one on each side and mount the projector in the rear in that area , tails everywhere ...
Tama is offline
Old 01-23-2013, 06:24 PM - Thread Starter
Tama's Avatar
well heard back from Klipsch yesterday was told optimum volumn is 1.5 cubic feet for the 5800s
also learned a neat trick this week , I ran flexible watertight conduit for my speaker lines and sub lines , and i was having trouble feeding the speaker wire inwall in it , i know u can buy a snake and some goop for it , and that what i was looking for but was told of a neat trick , take a piece of string and make a lil flag at the end of it insert it into the conduit and start a vaccum at the opposite end and it suppose to pull it right thru and then u can feed your speaker line thru with that , I lll let you know how it works
Tama is offline
Old 02-08-2013, 11:26 PM - Thread Starter
Tama's Avatar
Had a busy day today , my friend Charles and I build some pot light boxes 7 today for the 4 inch Halo retrofits to be installed , still have to make 4 more for the swivel heads for the columns,
Made a prototype of a column to see what it would be like in the room before we go ahead and make them for the room in maple , had some cloth laying around so we tried out the picture frames in the columns with i believe it was 1/4 round router bit
Also made a box for the heat register duct that had to be rerouted , added some mdf blocks inside it to make it twist in a s shape , to contain the sound from flowing back up into the rest of the houses ducting
well some progress today now to get them up inot the ceiling this coming days
Tama is offline
Old 02-13-2013, 07:07 PM - Thread Starter
Tama's Avatar
Picked up a bunch of new cables today and some recessed gang boxes for wiring the rest of the basement, and was looking for some sub cables but was told rg6 quad i had laying around would be more than enough to run a subwoofer , whadda yah know i read about it on here and it seems to be a acceptable practice . any other opinions on that?
Tama is offline
Old 02-21-2013, 02:04 PM - Thread Starter
Tama's Avatar
Picked up a bunch oc 703 this last week , going to use for the corner bass traps , and passed my electrical inspection for the entire basement , over 500m of 12/ and 14/2 used, whew lota wire , Onward!
Tama is offline
Old 02-28-2013, 07:55 PM - Thread Starter
Tama's Avatar
heres some pics of the progess recently , Drywall showed up 22 sheets 5/8 , another 60 sheets various sizes for rest of the basement , dont envy those guys at all . got the walls reinsulated with roxul and gooped back down,
And fitting The box i built to cover the wiring from the flexible conduit line i installed , btw the vaccum trick sure works slick for pulling the cords through to pull speaker wires etc..
Got a line on a server rack 24 inches wide going to look at it soon , hope that works out
Tama is offline
Old 03-02-2013, 10:04 AM - Thread Starter
Tama's Avatar
Installed the furring channel on side walls , still have to finish insulating the ceiling and install the pot light boxes , and frame off around the rear ceiling speakers to enclose them to be 1.5 cubic feet , then ill finish installing the furring on the ceiling ,
Tama is offline
Old 03-04-2013, 03:34 PM - Thread Starter
Tama's Avatar
Well had a challengeing weekend to try to get the ceiling in room insulated , used a combination of roxul and regular fiberglass to do the area because roxul safe and sound just isnt as flexible as regular fiberglass unfortunately Used a rigid board by roxul to surround the bottom of the ducts , got the the box i built installed in ceiling and hooked up to the 6 inch ductline used a flexible insulated hose to connect to the box that has been prebuilt , and , it actually has some decent airflow considering the zig zags inside the box , and its mainly for room circulation , and secondary heat , since floor is heated already , just waiting for some more clips underestimated clips and used more on the jut wall than i had orginally planned , oh well hopefully they will be here in the next week ,
Now to install some of the furring i have clips for on the ceiling and to start installing potlight boxes at the proper height after the furring is up
Tama is offline
Old 03-17-2013, 08:07 PM - Thread Starter
Tama's Avatar
Well , got all the potlight boxes into place , thx again Big for that help on designing them , boxed in the rear ceiling speaker boxes , to approx 1.5 cubic feet and installed the rest of the ceiling furring channel , bought the 5/8 osb.. ended up getting 19/32 T&G all i could get without special order .. dont think ill miss the 1/32 and the T&G should prob stay together better anyways and leave less gaps .
Tama is offline
Old 03-23-2013, 08:29 AM - Thread Starter
Tama's Avatar
OSB is UP! woohoo.. now to get the 5/8 up on Theatre room , then to get drywaller in to finish rest of basement and taper in to do entire basement and knockdown Onward !
Tama is offline
Old 03-23-2013, 03:06 PM - Thread Starter
Tama's Avatar
18 sheet drywall up 4 more to go today , green glue amazeing stuff easy to work with , but can get a lil sticky if u mess up .lol dont ask me how i know that =( havent sealed all the joints and corner and bottom yet running low on tubes of GG , luckily i heard they carry it locally now
Tama is offline
Old 03-23-2013, 04:47 PM
Damage Inc's Avatar
Nice progress. Are you using a lift for the OSB and the drywall?
Damage Inc is offline
Old 03-24-2013, 05:54 PM - Thread Starter
Tama's Avatar
I had access to one but we had a delivery of around 80+ sheets drywall and I told them to put it into the theatre room 22 sheets 5/8 out ofthe way while we finished insulating and wiring of the rest of the basement , pprob not the best idea ive had in a while . so we ended up just man handling it into place, there is only about 7 sheets on ceiling so we used 2 2x6s cut a lil below the height and wedged it into postion . it worked , but going to hire someone else to do the other 1000 square feet basement , money well spent imo
Thx to my friends Ken and Antonio , and my wife and her mother keeping us looked after while we worked
Tama is offline
Old 03-28-2013, 08:53 PM - Thread Starter
Tama's Avatar
Well have 2 projectors in mind atm
the new sony 50
and the new jvc 4k 46 i believe it is
96 wide x 54 high screen size is what im thinking accoustical screen 1.0 gain
any suggestions?
budget for screen and projector is approx 6k
Tama is offline
Old 03-30-2013, 09:45 AM
JamesB77's Avatar
You're making good progress.
Are you going to DIY the screen or buy a pre-fab one? For DIY a lot of people seem to like Seymore. That's what I will be using as well.
JamesB77 is offline
Old 05-03-2013, 09:47 AM - Thread Starter
Tama's Avatar
I just ordered a Jamestown 16:9 110 seymour acoustical screen today should be here in a few weeks
Drywall is still ongoing , because finishing entire basement at same time , cabinetry is about to be ordered hopefully in the next week if we can get the final pricing only 1 small cabinet is to be used in the small room off the a/v room to hold the electronics , which will hold a bar fridge and cabinets for treats , included is a shot of the area in front of the office located behind the HT room
Tama is offline
Old 05-03-2013, 07:47 PM
JamesB77's Avatar
Things are looking good. I like the stone
JamesB77 is offline
Old 05-03-2013, 10:32 PM - Thread Starter
Tama's Avatar
Ive been looking at a JVC DLA RS55 and JVC DLA X55 anyone out there care to explain to me which one would be better for my room or do you think its overkill , been also looking at the sony HW50 but its not 4k eshift atm , any Opinions ?
Tama is offline
Old 01-21-2014, 05:23 PM - Thread Starter
Tama's Avatar
screen wall with speakers mounted
screen wall before drywall with 1.5 cubic feet volumn for speaker
a test strip of rope lighting
here are some pictures of the past summer and fall work that was done
Tama is offline
Old 01-21-2014, 05:32 PM - Thread Starter
Tama's Avatar
this area is outside the av room , its the bar fridge and cupboard space and where the av rack shall be located
older picture of the front screen wall with the screen frame assembled
picture of the 2 rear ward columns in the room to hold the 2 side speakers and to position the picture frames around the room
Tama is offline
Old 01-23-2014, 06:50 PM - Thread Starter
Tama's Avatar
with the 5/8 drywall 5/8 osb and green glue + knockdown thickness is quite a bit
painted the pot lights bought some swivel head mounts with gu10
bought these from Costco suppose to have a 40,000 hour life warranty for 20 year , wonder if they will around that long ..
painted ceiling a red to match the cloth added some black to tone it down some
potlights installed put up the klipsch 5800 into the ceiling and sprayed it flat black
Tama is offline
