Installation of in-walls for HT duty - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-29-2012, 09:28 AM - Thread Starter
omalb's Avatar
Hey Guys
I am in the process of installing some LCR in-wall speakers to replace some exising speakers that
are not meeting the current S.A.F.(spousal acceptance factor) after some recent home decor changes.
I'm installing Definitive Tech 6.5's. Here is my question. Does it make sense to stuff the wall
cavities with fiberglass insulation in order to help with resonances, etc? Or perhaps install some dyna-mat
or some similar material? I've installed somein-walls (PSB's) in my kitchen for "background" listening, but
sometimes I crank them up, and I noticed the pics on the opposite wall vibrate and rattle. I thought stuffing
the holes prior to installation might help, but am uncertain. These new speakers will be driven by some serious
amplication (Caver 250W per) and I know I'll be playing them much louder than my other in-walls.
Thanks in advance for any advice or experience with same.
omalb is offline
post #2 of 2 Old 11-29-2012, 03:45 PM
SierraMikeBravo's Avatar
Quoted: 336 Post(s)
Liked: 214
My suggestion is to consider Triad Inwalls. These come pre made with backer boxes and so less of a problem. smile.gif
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is offline
