The Stonewater Cinema Build Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 349Likes
post #61 of 1774 Old 12-05-2012, 01:30 PM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
Absolutely!! It's a Cadillac SRX, so all the guys at 84 Lumber always get a chuckle when I start loading up and hauling out the lumber because they are so use to seeing only pickups and normal flat bed trucks. But hey, to get to the finish line I have to watch every last penny to make the budget work so delivery charges are not my friend.
I probably should've taken a picture of it, but I have hauled every last drop of framing lumber in this thing - even the 12' long 2 x 12s. My first load of 2 x 4 x 105s was so big that my tailgate was completely horizontal and the vehicle definitely showed a bit of strain on the rear suspension. Thankfully I have a V8 engine and am past most of the heavy hauling stage.
I'll post some pics a bit later today, but another friend and forum member, ten8yp, helped me with two huge loads of sheet material and insulation for the theater...it's literally piled chest high in one stack and waist high in another. In fact you'll probably see him pop in from time-to-time to help out in the construction.
I am in the military stationed in Hawaii but will be moving to Augusta in Feb where we are going to build our retirement home. I would love to pop up on the weekends to help you out once we are settled.
cw5billwade is offline
post #62 of 1774 Old 12-05-2012, 02:41 PM
Quoted: 328 Post(s)
Liked: 184
PS my wife has a F150 we can use that to move things!
post #63 of 1774 Old 12-05-2012, 02:45 PM
J_P_A's Avatar
Quoted: 590 Post(s)
Liked: 443
I'm also interested in your subs. I'd love to go with an IB setup, but I don't like the soundproofing problems it can cause with trying to isolate the back chamber if it's outside the room.
I'm sure you've looked at this from every angle, but would it be possible to make your door an out-swing to keep from interfering with your riser? Could you build a raised platform outside the room so that you enter at riser height? Then you could extend the riser all the way across.
The Plains Theater Has Begun
J_P_A is offline
post #64 of 1774 Old 12-05-2012, 05:15 PM - Thread Starter
TMcG's Avatar
Quoted: 1049 Post(s)
Liked: 836
Fair warning . . . lengthy post . . . blame it on a 3 hour flight!
Now, on to the pictures of the room itself….
Here is a view from just outside the theater. I will be purchasing and installing a backlit movie poster lightbox and a custom Stonewater Cinema marquee from Hollywood Marquees. Both of these units are typically surface-mounted and protrude about 4 inches. But since they are built-to-order, they are honoring my request for a small amount of customization with regards to the electrical connections so I may recess this unit into the wall. Instead of being hardwired with a pull-chain to turn the light on/off, I am requesting that the unit be hard-wired only at a very specific wire entry point and then I will turn the power on/off for each unit via a standard light switch. I may even tie each of these into a Grafik Eye zone. When recessed, the frame of the marquee will sit on the surface of the wall, making it looked like a framed and backlit piece of artwork. The movie poster unit will stick out from the wall about ¾” since the front is hinged and must maintain proper swing clearances to change the poster. The movie poster unit also comes with interchangeable placards that can be placed either above or below the movie poster that can say “NOW SHOWING”, “COMING SOON” or any other phrase I choose. And one nice thing about the marquee is that they include a fairly generous pack of individual letters that can be slipped in and out of the marquee for up to two lines of text to feature the movie title, rating, etc. - just like a real movie theater. The letters go in the white area pictured below:
I plan on going the DIY route with two other movie poster display boxes using the Cuzed / Moggie / Air Benji method found in this forum and at these links:
DIY Lightbox thread started by Cuzed: http://www.avsforum.com/t/1392444/another-diy-poster-marquee-light-box
Moggie's Old Vic Theater Thread: http://www.avsforum.com/t/1117148/saga-of-the-old-vic/1050#post_21989987
Air Benji's Esquire Theater Thread: http://www.avsforum.com/t/1289590/the-esquire-theater-construction-begins/1650#post_22610398
For soundproofing, I decided to go all-out and use full double-studded walls with a 1” air gap. You can see on the LEFT wall that I already have 1/2" OSB, Green Glue and 1/2" drywall installed. This is because I had originally chosen to maximize the width of my theater. When I made the decision to add the second wall, I kept hearing John’s (from the Soundproofing Company) voice in my ear telling me to uninstall this sheet material because of the “triple leaf effect”. As real as this phenomenon is, I have consciously decided to not rip it all out and just roll with things the way you see them here. Between acoustic treatments, two layers of 5/8” drywall attached to a separate and decoupled wall filled with R13….then a 1” air gap, then ½” drywall / Green Glue / ½”OSB covering a second wall filled with R13….I think I should be OK. Ideal – no, but livable – yes. Perhaps the “boom” of certain low frequencies may get emphasized, but I just couldn’t see ripping everything out. I’ll be sure to report my findings once things are up and running.
I had a 4" plumbing drain line coming from the second floor that made an immediate 90 degree turn the moment the radius had cleared the underside of my joists. In order to install a soundproof shell, I had to lower and reconfigure this pipe. I calculated that with the ceiling hangers, the 7/8” hat track and two layers of 5/8” drywall that I would need a minimum of 2.5” between the pipe and the joists. If you look carefully, you can see 2.5" of blocking that served as my minimum spacing when I reconfigured the pipe. My plan is to clean and wrap the pipe with soundproofing material and then recreate the proper slope with pipe hangers secured to the ceiling of my new soundproofed shell. I will then further encapsulate the pipe with framing, insulation, OSB/Green Glue/Drywall AND THEN build out the perimeter soffit around this and the other mechanicals using more of the same standard soundproofing techniques. This should be more than enough to quell the sound of running water, flushing toilets and the like. The ¾” PEX water lines will also be remounted directly to the underside of the soundproof shell after being wrapped with standard foam pipe wrap FWIW.
Full view of the total mess of mechanical lines I have to deal with in the ceiling of this theater. Not only are there water and drain lines, but gas lines and two VERY noisy HVAC line sets. I have unsecured everything so the soundproof shell can be built and the lines insulated / wrapped and secured to the shell. Like I described above for the drain and water lines, I will be building a "box" around all of these mechanicals to contain the sound, followed by the soundproofed perimeter soffit. Hopefully this will eliminate any sounds from these mechanical systems seeping into the theater and raising my noise floor.
Two AC line sets, gas lines, and temporary installation (support) of the 10" flex return line dedicated for the theater HVAC. I left the full length of the 10” flex duct in place until it is determined exactly where I will be placing the return air duct. Once this is determined, I will cut the flex, add a rigid 90 degree elbow and 10” rigid pipe down into the 14x14 return air box collar. This is done for three reasons: 1. So the HVAC penetration through the soundproof shell is with rigid pipe (the preferred method professionals use); 2. The ceiling penetration is contained within the soundproof soffit (with acoustic caulking around the penetration, fyi); 3. The 90 degree elbow will hinder the amount of escaping sound through this penetration and fan noise from the nearby HVAC unit from entering the room. Well, at least that’s the plan!
Full picture of rear wall. You can see immediately behind the theater framing that this is another area where I was previously trying to maximize the theater dimensions. The original back wall is a 2x6 wall directly underneath the steel support beam and faced with ½” OSB, Green Glue and ½” drywall. The wall is filled with R19 and the theater wall will naturally be filled with R13 and covered with DD 5/8” + GG. But this is another area of potential “triple leaf effect”. Fortunately the right wall and most of the front wall are backed by concrete covered directly with closed cell spray foam.
Right side wall of theater. The wall is built in front of 2" of closed cell polyurethane spray foam that was applied to the concrete foundation wall. I slid the wall into position as close as possible and trimmed down a bunch of “peaks” in the spray foam with my reciprocating saw where the framing was hitting high points in the foam. I probably gave myself about 1.5” of room by doing this while still preserving a minimum spray foam thickness. I will have to go back and do some reframing around the line sets because I am not happy with how these mechanicals run through the wall. I think I can reframe a bit and do better.
Left side of theater wall. Theater door is in the left side of the photo. As you can see, I will have to deal with a steel support beam running horizontally through the middle of my room. This is unfortunate because I will be building a fiber optic star ceiling and like the continuity a single large area provides. However, dividing the soffit in two is not the end of the world.
Front theater wall. Behind the framing on the left side (where you see the drywall), there is a two foot extension that was originally going to be orphaned space. Since I am fighting for every inch of depth and viewing distance I might – MIGHT – take the plunge and open this area up to gain the extra cubic volume for my infinite baffle subwoofer system. I might pick up 5 or 6 inches of depth in the room by being able to slide the baffle wall back even further, but I will be discussing this with Dennis first before I commit the hours to redoing this part of the theater. As discussed above, green foam indicates where the concrete foundation is along my front wall.
To house all of my equipment for the whole house including the theater, I purchased two Middle Atlantic MRK-4431 racks which can be ganged together. These racks came from through an eBay deal a couple of years ago and were already outfitted with a full-blown thermal management system, power protection system and rear door. As luck would have it, a year or so later another seller on eBay was liquidating the EXTREMELY expensive smoked plexiglass locking front doors brand new, so I was able to pick up on two of them. I am actually almost as excited to put together the rack and load all the equipment as I am building out the theater. I have a massive number of dedicated circuits and low voltage wiring running into this rack area. You will also see that I located these racks at the foot of the basement steps so there is still easy access from upstairs in case I need to load any media. As the crow flies, the front of the rack is about 7 feet away from the left wall of the theater which is on the other side of the steps. After I lay hardwood in this area, the racks will sit directly on the floor and are framed to protrude through the wall. These racks represent the front of a fully dedicated equipment room, complete with dedicated ventilation systems.
Another view of the racks:
I will be posting a lot more photos, plus separate posts highlighting my equipment plan, my full basement plan and my soundproofing plan featuring products from Kinetics Noise Control and the ubiquitous Green Glue.
TMcG is offline
post #65 of 1774 Old 12-05-2012, 06:48 PM
fax6202's Avatar
Looking good. I can't wait to see those racks filled to the top.
Im not surprised, but how did you talk the sign company into rewiring it for you? I like the recessed idea much better than a sign with a pull chain. That just wouldnt look right with everything else in the Theater top of the line.
fax6202 is offline
post #66 of 1774 Old 12-05-2012, 07:42 PM
xjagox's Avatar
Quoted: 39 Post(s)
Liked: 30
I've also got very similar length, and height, and seating plans in my room (4' narrower). I'll be watching as things progress!
xjagox is offline
post #67 of 1774 Old 12-06-2012, 12:48 AM
Nightlord's Avatar
Quoted: 701 Post(s)
Liked: 236
Very happy to see someone that's foamed a wall, I was thinking about doing the same with my problem wall (at least I hope it is that one), so it's good to know that it's actually been done before and not a stupid invention on my part. smile.gif
Under construction: the Larch theater
Nightlord is offline
post #68 of 1774 Old 12-06-2012, 04:37 AM
Dennis Erskine's Avatar
Quoted: 63 Post(s)
Liked: 100
Foamed walls are excellent for energy use reduction, thermal insulation, and air penetration. What most consumers are not told is the most benefit per inch from these products comes in the first 2". After that the benefit per inch falls off a cliff. From an acoustics perspective, fiberglass insulation is far better. (Foam will also couple the interior and exterior walls to each other). When foam is used (for all the right reasons), I suggest no more than two inches. That is followed by fiberglass, isolation clips and HAT channel, then drywall. In a 2x4 framed wall that leaves just over 5.5" of total depth. With two inches of foam, you have enough remaining depth for fiberglass batts...the acoustic wall remains decoupled. FWIW
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #69 of 1774 Old 12-06-2012, 05:03 AM
Nightlord's Avatar
Quoted: 701 Post(s)
Liked: 236
Thanks. I was thinking just a thin layer anyway and build the frame for the wall freestanding in regards to the light concrete block wall with which I think I have problems. Fiberglass of the same kind as in the riser and back wall. Was thinking about a sandwich wall of OSB, porous board and drywall with some equivalent of your green glue.
Isolation clips and HAT channel I would not know what they're called or where to find here in Sweden, but I'll try google.
post #70 of 1774 Old 12-06-2012, 05:13 AM
Quoted: 63 Post(s)
Liked: 100
Based upon experience, Sweden, Denmark and Norway are part of the modern world and these products are available; but, since my command of the Swedish language sucks, I'd have no idea what they are called. wink.gif I can also state from experience that Oslo is bloody cold and dark way too many hours in January.
Using a CLD (constrained layer damping) agent, such as Green Glue would make your "porous" layer not relevant, not needed and detrimental to the CLD agent. You can use OSB + gypsum board (drywall) or two layers of drywall. The "porous" layer would prevent the CLD agent from working as intended.
post #71 of 1774 Old 12-06-2012, 05:47 AM
Nightlord's Avatar
Quoted: 701 Post(s)
Liked: 236
Thanks again. Already found some "acoustic profiles" that seems to be similar to HAT channel, so far still no hit for clips, but having found the one will give me companies to mail and ask.
Ok, if I do find the glue as intended, I'll skip the porous board then.
Given that I work on my own - a big OSB I can handle on my own, I think. Drywall I will have to use smaller pieces normally used for ceilings to be able to get them into my car and generally handle them (weight and not breaking them). Have done that before on a normal wall in the past.
Well, it is a bit dark now, but it's just 15 days left until it starts getting lighter again. You should try our wonderful long summer evenings too, they quite make up for it *imho*.
Do hope that the rest of the walls are decent enough, I'd hate bringing down all the job I put in the last half year to start over from scratch. My acoustical consultant thought they were ok, the problem wall was not done fully at that time, so I keep my fingers crossed that fixing that one will be enough besides sealing the door and the attic hatch.
post #72 of 1774 Old 12-06-2012, 08:36 AM - Thread Starter
TMcG's Avatar
Liked: 836
I really like the layout - especially in the ways that I find it is very similar to mine (I love to have a little confirmation for my plans). Our dimensions are very similar, except of course for the extra four feet of width you've got - I'll try not to be to jealous of that. There's plenty else to be envious about - like an array of procellas smile.gif
What is "stone metal?"
Do you have reservations about using a view port? Maybe it's my own analysis paralysis, but I get paranoid about needed to change a throw distance, so I can't commit to that setup.
What I have marked as "stone metal" I planned to discuss in an upcoming post about my lighting plan which is proving to be quite elaborate - but I might as well share some of the design right now.
So far, this is my color pallet for the room:
All the finish carpentry will be African Mahogany and the carpet will most-likely be by Kane (Style shown is called "charming" in the color "Obsidian"). Here's a few pics of the actual veneer I bought unfinished, along with a finished example. I am not settled on this finishing style yet, but it is a consideration and matches well with everything I would like to do from a style perspective:
Now, to answer your question about the "stone metal". I wanted to internally light the columns and not use any surface mounted fixtures or any recessed can lights pointing straight down on the column. After some research and to keep with the Art Deco style theme, I decided I wanted to backlight some sort of alabaster stone. A quick trip to the stone distributor / fabricator convinced me that I either had to hit the lottery, capitalize on the inheritance I can expect from a long-lost Nigerian uncle I had which I receive so many e-mails about or find another material alternative. A bit more searching and I came across Kokomo Opalescent Glass which manufactures art glass by hand, typically used for stained glass windows. After receiving samples I knew that this would work, but given that the glass is only 1/8" thick and NOT tempered, one wrong move and I could have an expensive art glass panel shatter into a million shards. It was just about that time that StockMonkey was building his Desert Sunset theater. You can see the installation of his material at THIS post. I contacted StockMonkey and he said he ordered this material from a company called 3-Form in his state of Utah. FAIR WARNING - you can literally spend hours combing through this company's website. If you ever need unbelievably good cutting edge design ideas, set aside some time and go through the galleries.
Needless to say, but it wasn't long before I stumbled on 3-Form's "Alabaster" with either grey or brown graining and ordered a sample of both. In a word - the material is perfect for my needs. Here's a couple of pictures of the samples I received. The "lit" sample is just me holding it up to one of my kitchen lights about 3 feet away from the sample. Properly lit I can imagine it will be stunning. Apologies for the fuzzy pictures and bad lighting...
So that's the stone part. If you refer to my first post you will see a picture of the Paramount Theater where there is backlit glass but also sculptural metal in front of it, giving another dimension of detail to the design. This is where I have struggled to find the design cues I like to incorporate into custom metal work - and where I would love to have some input from this forum. I'll have to dive into this topic a bit more deeply at a later post, but here is where my head is at now:
As it stands now, I'd like to develop a full-scale design using the curve structure similar to that in the light above. You could think of my columns as replicating this fixture on a much larger (and flatter) scale with the alabaster behind decorative metalwork.
To take things one step further I am probably going to use a professional-grade RGB LED lighting package from Color Kinetics so I can mimic incandescent lighting with the backlight, but then change to any color under the rainbow at a moments notice and other cool features like slow color rolls, etc. This is what I am actually working on right now.
Stockmonkey chose to directly illuminate his panels with 120v light. To avoid hotspots and yield a smoother overall look with these professional lights, I am in consultation with 3-Form's lighting engineers where they have offered a bit of complimentary help to integrate their products. I'll post what I can with more of my patented hand drawings / engineering schematics.
I hope this answers your question with sufficient detail and I would REALLY like to hear some input on this design direction.
Now, regarding the projector....I am looking at an Epson 5020 or 6020 which has sufficient light output and has throw distances that enable me to mount it at the very back of my room. HOWEVER, the further back the projector goes, the dimmer it gets. To maintain my ideal 16 ft. lamberts on a screen this big, that requires that the projector be installed at around 17.5' maximum throw distance which puts it right above the back bar area. Another reason for keeping within the 17.5' throw distance is that the Panamorph UH-480 anamorphic lens has its focal sweet spot at this maximum distance. If I put the projector at the back of the room I will probably have to send the lens to Panamorph for conversion to a "long focal length" lens package at a cost of $995. So I, meaning Dennis Erskine, has some work to do on this part of the design!
If I stick with the 17.5' throw I will NOT be using a viewport and the projector will be in open air. If I put the projector in the back of the room I will be enclosing the projector in a hush box with a view port. When force-ventilating a projector hush box it is extremely important to have 100% control of the intake and exhaust air for ventilation. If I did not have a Viewport, negative pressure created by the powered exhaust of the ventilation system would draw MASSIVE amounts of dust through an open viewport "hole" in the hushbox which is not good for your optics for obvious reasons. Second, the beam propagation for most projectors is not so extreme that the viewport's size would be the limiting factor in selecting a projector. It is really the distance between the front of the projector's lens to the back of the viewport's glass. We'll see how everything shakes out in the coming months.
TMcG is offline
post #73 of 1774 Old 12-06-2012, 08:57 AM - Thread Starter
TMcG's Avatar
Liked: 836
Originally Posted by rs691919 View Post
Nice drawings, Tim! Am I reading correctly that from floor to top of soffit is 7'7"? Or is that just from top of riser? I had also originally planned to go with a chair rail with panels on either side but then it seemed that it was going to be too tight, what with crown and baseboard and frames around the panels themselves. So in the end I just went with larger raised acoustic panels. Are you planning on frames around your panels?
From the floor to the underside of the perimeter soffit will be about 92", which is the 7'7" you see. In the middle of the room where the fiber optic star ceiling will go, I gain another 8" in height so the center "coffers" of the room will be in the 8'3" range to the ceiling. My riser height is currently specified at 11.5", so deduct this from each of the two measurements.
So for people in the back bar nearing 6'7" tall, they may want to watch their heads when walking under the soffit. But like I said above - the back bar may be eliminated and if I do keep it, the people sitting there should just appreciate that they have a seat if the regular chairs are full!! biggrin.gif
I am planning for panel mold around the acoustic panels, but this may change slightly when I get to the finish carpentry stage. Crown and base molding will overlap the columns, but the chair rail will not since I will have a large backlit piece of alabaster to light the column.
TMcG is offline
post #74 of 1774 Old 12-06-2012, 09:04 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
I'm as giddy with anticipation as a kid on Christmas Eve! I love your color choices and those columns are going to look awesome.
Spaceman is offline
post #75 of 1774 Old 12-06-2012, 09:08 AM - Thread Starter
TMcG's Avatar
Liked: 836
Originally Posted by BllDo View Post
What drivers are you planning for your IB set up? Is 4x the max VAS you can get?
Edit: Also, I didn't see any other subs on the plans (which look very nice BTW.) Were you planning on any side or rear subs?
I am open to suggestions, but most people on this forum and several others seem to really like the Fi Car Audio IB-318 subwoofer driver. On my original ceiling-view sketch you will see the subwoofers in self-contained opposing driver manifolds sticking into the IB chamber. For the front elevation drawing I didn't bother penciling in the manifolds between the center channel and the left and right speakers respectively.
I need to talk with Dennis about this, but the initial review of my drawings did not yield any balancing subwoofers for the room, which surprised me given my room's cubic volume and the added benefit 10" or 12" subs can provide in helping to balance out the bass in the room. I'll keep everyone posted when I get everything finalized which will have to be incredibly soon if I am going to start closing up the walls.
Regarding the 4x VAS....I had an extensive conversation with Scott, the President of Fi Car Audio regarding exactly how much VAS was needed. As a rule of thumb, the absolute minimum is 3x VAS. There is noticeable improvement if you go to 4x VAS, but beyond this the law of diminishing returns kicks in. He said to target a 4x VAS space and the addition of pink insulation will make the drivers act like they are operating in an 8x to 10x VAS space. Beyond 10x VAS there is absolutely zero acoustic benefit. As it stands now, I am just over 4x VAS and will have the drivers "seeing" about 9.1x VAS when I add the insulation into the baffle wall chamber.
TMcG is offline
post #76 of 1774 Old 12-06-2012, 09:23 AM - Thread Starter
TMcG's Avatar
Liked: 836
Thanks Bill! Send me a PM when you are ready. New baby is expected April 19, so I am on a bit of an extreme deadline to get things done. I would love to pay you a visit in early April...I hear there's a small little golf tournament around that time....biggrin.gif
And thanks as well for the screen print info. That certainly works, but you definitely lose in resolution. Another AVS member had Acrobat and did the conversion for me in about 5 minutes. Moving forward I'll just scan into jpg when I produce any other drawings.
TMcG is offline
post #77 of 1774 Old 12-06-2012, 09:28 AM
xjagox's Avatar
Quoted: 39 Post(s)
Liked: 30
Those 3form glass products are pretty cool looking. What's the rough cost range of that stuff?
xjagox is offline
post #78 of 1774 Old 12-06-2012, 09:34 AM - Thread Starter
TMcG's Avatar
Liked: 836
Good points JPA. I specifically designed the room so the IB chamber would be contained within the soundproofed shell, so hopefully this will contain the full power of this system without shaking the house (and waking the future baby!). We'll see, but I'll rest easy knowing that I did everything possible that was practical and within budget to keep this sound contained in the theater.
You are correct regarding the door - I could easily have the door hinged in any direction. Here was my reasoning for having it swing the way I have it planned: I could have the theater door open and not blocking either the lighted movie poster or the pool cue holder which will be on the other side. By having the door on the inside I also create a recess on the exterior of the theater door for some of the decorative elements that will be on the front surface of the door, including some RGB LED lighting and Art Deco metalwork. And finally, it would be difficult if not impossible to "hide" the door inside the theater and have all the acoustic panels on the same plane. This last point was actually my primary consideration for having it the way I do now. So it does encroach on the riser and make it more difficult for the people sitting in the proposed back bar area, but access everywhere else should be fine. I haven't mentioned this before, but I was even considering installing a small railing to block access to the upper tier back bar as soon as you walk in, forcing traffic around the seating area to the roomier step. This is just a consideration, nothing final yet.
I really appreciate the feedback! What are your thoughts after hearing my rationale for the door swing?
TMcG is offline
post #79 of 1774 Old 12-06-2012, 09:36 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Tim are you looking at three layers of drywall for the bass containment?
__________________
Ted
The Soundproofing Company
Ted White is offline
post #80 of 1774 Old 12-06-2012, 09:41 AM - Thread Starter
TMcG's Avatar
Liked: 836
It was no big deal, really. Since each one is built to order all I had to do was request that the pull-chain system NOT be installed, specify where a standard metal romex connector needed to go (and the size of the hole) and requested four drilled holes (two per side) for securing the light box to the framing when recessed. They are doing the same for the marquee, fyi. I will probably be placing my order for both by Christmas. Hopefully by the time I receive them the drywall will be installed and painted in my basement and they can be installed / enjoyed immediately!
TMcG is offline
post #81 of 1774 Old 12-06-2012, 09:46 AM - Thread Starter
TMcG's Avatar
Liked: 836
Technically, two. From inside the theater to my basement stairwell I am planning for:
- 2" Quest Acoustic panel (budget allowing)
- 5/8" drywall
- Green Glue
- 1/2" OSB
- 2x4 framing filled with Roxul Safe 'n Sound (R-13 equivalent) insulation
- 1" air gap
- 1/2" drywall
- Green Glue
- 1/2" OSB
- 2x4 framing filled with standard R-13 batt insulation
- 1/2" drywall (finished side of stairwell)
The scenario above is ONLY for the left side and rear of the theater where you see drywall behind the framing. You and I discussed that clips and track to these walls wouldn't be of much value at this point. After seeing these pictures, do you foresee any problems or would you make any changes to the above? Thanks!
TMcG is offline
post #82 of 1774 Old 12-06-2012, 09:48 AM - Thread Starter
TMcG's Avatar
Liked: 836
Pricing varies by panel style and I don't have a quotation (with shipping from Utah, fyi) yet, but early word is this material is approximately $850.00 per 4' x 8' panel. My alabaster "window" in the column will be 16" wide to maximize the material at three columns per sheet. Unfortunately I will need two sheets just for this feature.
TMcG is offline
post #83 of 1774 Old 12-06-2012, 09:57 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
The more massive these walls are, the better the LF isolation. I read your IB comments and thought I'd ask. So three layers is beter than two, and 5/8" is better than 1/2". These things will only affect your LF isolation, as the rest will be contained with two sheets.
__________________
Ted
post #84 of 1774 Old 12-06-2012, 10:01 AM
Jonny5nz's Avatar
Quoted: 31 Post(s)
Liked: 93
I chuckled to myself that you happened to be talking about door entrances and a pool cue holder. I was looking at this just last night:
http://hiddenpassageway.com/wp-content/uploads/2011/10/Pool-Cue-Rack-Secret-Passage-Technical-Drawing.pdf
Jonny5nz is offline
post #85 of 1774 Old 12-06-2012, 10:16 AM - Thread Starter
TMcG's Avatar
Liked: 836
I have a bit of additional information on this comment, because I was exploring alternative options (i.e. less foam) when getting this spray foam a couple of years ago. A lot of the spray foam companies are offering an alternative to the full depth foam for those who want to completely air seal a space but can't afford the full depth of product. They call it "flash and batt" where they spray about 1/2" to 3/4" of closed cell foam to get the air seal and then you can install your own R-13 batt for the insulative value. This is only about a 85% vapor barrier at this thickness and you will not get the full R-13 from your batt because part is compressed (due to losing the 1/2" depth to spray foam), but overall the insulative value of this is R14.
To get full air sealing and a 95% vapor barrier, that can be done with 1" of foam. If you are getting a spray foam quote for 2", you can literally divide that quote in half. The only problem is that you will have rip 1" material and attach it to the facing of every stud with glue and screws to install an R-13 batt without significant compression. Total R value of this assembly is just short of R20.
The full 2" gets you the 99.9% - 100% vapor barrier after which Dennis is right - the benefit of deeper foam falls off the cliff. Where it does not fall off the cliff is in regards to additional insulating value. Many folks will fully fill exterior walls with the 3.5" of foam for this exact reason. So while I agree it is not necessary to go beyond 2" for air sealing and vapor barrier, you can go as deep as you like in 2" "lifts" to get additional insulation value.
I went with the foam against the concrete primarily for the full vapor barrier, but also as a very efficient insulation. As you can see in the shots below, the foam guys sprayed directly on the theater wall before I framed. I then built my walls in front of the foam.
I actually got a bit lucky because their install guys had never sprayed on open walls before - always between studding where they had a good handle on how much depth they were spraying. If you look at my pictures, you can see where they were spraying the foam 4-5" thick at the bottom before they realized about halfway through the project that they were spraying WAY too much foam. I ended up getting a LOT of free foam because of the error. So from the middle of the wall to the top you can see where I gain another 2.5" in depth between the back side of the framing and the front face of the spray foam. I ended up cutting down some of the high points of the spray foam on the bottom of the wall with my Sawzall as you can see in some of the pictures. At no point does any of the theater framing touch the closed cell foam, although it might look close in the pictures.
Cutting down a high point of foam in the lower portion of the wall
Just over 2.5" of gap from the back of the framing to the foam from the middle height of the wall to the upper height:
TMcG is offline
post #86 of 1774 Old 12-06-2012, 10:27 AM - Thread Starter
TMcG's Avatar
Liked: 836
The 1/2" drywall I previously installed was given to me for free by a neighbor who had his basement professionally finished, so I cheaped out and used it. I still have the option of using two layers of 5/8" drywall for the interior of the theater, but I like the idea of finding something for my finish carpentry to really bite into literally anywhere I want. There is quite a difference between the pounds per square foot for 7/16" OSB and 5/8" drywall.
If I build my shell entirely out of two layers of 5/8" drywall, what is the best method to build my perimeter soffit on top of the soundproof shell? Go all the way down to the original studding with a direct connection or anchoring products such as plastic toggles? I suppose that since my walls are decoupled it doesn't matter one bit if the soffit was fixated to the ceiling and wall framing directly.
TMcG is offline
post #87 of 1774 Old 12-06-2012, 10:38 AM - Thread Starter
TMcG's Avatar
Liked: 836
Thanks Spaceman! I can tell already that selecting an acoustic fabric that will jive with everything is going to be the toughest. I just got a delivery today . . . a brand new Canon Rebel T4i so hopefully my pictures will improve dramatically over my standard 4MP point-and-shoot. I'll try to take some of my first pictures with the new camera of the interior design plan so it's not quite so dark and fuzzy.
TMcG is offline
post #88 of 1774 Old 12-06-2012, 11:08 AM
rs691919's Avatar
You could substitute 5/8" OSB for the first drywall layer. Several others have done that. It made it very easy to screw in the soffit framing and attach the columns.
rs691919 is offline
post #89 of 1774 Old 12-06-2012, 11:09 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Tim, depending on the weight of the soffits, you can either leave a dedicated clip + channel up there for the vertical face of the soffit ir if larger / heavier, you can leave a 2x4 up there, held with IB-3 clips
__________________
Ted
post #90 of 1774 Old 12-06-2012, 01:13 PM
HopefulFred's Avatar
Quoted: 486 Post(s)
Liked: 421
So that's the stone part...
...but here is where my head is at now:
There's a lot to a decision like this, IMO. For starters, the question for me is are you a "gold" guy or a "silver" guy. I always prefer steel/chrome/pewter/silver to gold/brass. The veining in your alabaster (brown or grey), the light temperature/color of the LEDs, and the decorative metalwork should all work together. My experience and preference is that you not mix the warm tones with the cool tones, except for maybe the light temperature, IMO.
For the next question I don't have as clear and defined a vocabulary of design elements - if that makes any sense. To me, Art Deco can be one of two different aesthetics (though, certainly deco designs draw from and blend into many different styles) - there are ornate designs that trend toward Beaux Arts, which has a sort of neoclassical feel (corinthian columns, etc.) - and there are more stark geometric designs that are more reminiscent of Batman comics. That's probably an oversimplification, and maybe complete misunderstanding, but it get's me to my question for you: how ornate a design are you looking for? Further, and maybe more importantly, are you looking for something organic or geometric - curved or straight?
My personal design leaning is geometric and simple, with cooler colors (I really like and would work from an aesthetic like BIG's).
I've done some searching for examples, and really find very little. The Paramount's lobby is a good example, obviously, and includes a middle-of-the-road metalwork design which is detailed and ornate, while still being geometric and understated. Most often it seems that alabaster or glass is left open (as in this recent renovation of the Venetian in Las Vegas). I think there's a strong argument to be made for allowing the stone to speak for itself and not be cluttered by the metalwork. On the other hand, maybe Tiffany has some design cues to lend. This last design couldn't be translated very directly to your space, but it's one of my favorites that I've seen today - it's simple and bold (ignore the text, just check out the column).
Hopefully, I'll find some time to sketch some later, but I'd like to hear where your aesthetic leanings are first.
Fred
HopefulFred is offline
