Mass Loaded Vinyl - AVS Forum
post #1 of 7 Old 12-01-2012, 01:02 PM - Thread Starter
mijotter's Avatar
Liked: 58
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?productId=202861596&storeId=10051&langId=-1&catalogId=10053&MERCH=REC-_-SearchPLPHorizontal1-3-_-NA-_-202861596-_-N#more_info
Is this the same as MLV(Mass Loaded Vinyl)?
mijotter is offline
post #2 of 7 Old 12-01-2012, 07:23 PM
HopefulFred's Avatar
Quoted: 135 Post(s)
Liked: 194
I think it is - but I'm not sure. In either case, read the reviews posted at that link. It seems that the details of the product have been changed from what you see in the picture. May be functionally different, or may not.
HopefulFred is online now
post #3 of 7 Old 12-03-2012, 07:51 AM
Ted White's Avatar
Liked: 32
Also consider what you need MLV for in the first place. For wrapping stuff it is helpful, because MLV is flexible.
__________________
Ted
The Soundproofing Company
Ted White is offline
post #4 of 7 Old 12-03-2012, 03:58 PM - Thread Starter
mijotter's Avatar
Liked: 58
I'd be using it to lay on the return plenums that are flush with the joists. Also will be doing duct liner inside the plenums as well. Would this product work?
mijotter is offline
post #5 of 7 Old 12-03-2012, 04:07 PM
Ted White's Avatar
Liked: 32
Yep!
__________________
Ted
post #6 of 7 Old 12-05-2012, 06:02 PM - Thread Starter
mijotter's Avatar
Liked: 58
What would be the best way to adhere this to the plenum? Staple gun? a certain glue? Thanks.
mijotter is offline
post #7 of 7 Old 12-06-2012, 06:37 AM
Ted White's Avatar
Liked: 32
Stapling works, if the MLV has been extruded. Cast MLV is much easier to tear.
__________________
Ted
User Tag List
