Remote Wireless Transmission Through Sound Proof Walls - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-05-2012, 06:58 PM - Thread Starter
SKINSnCANES's Avatar
Liked: 25
I'm doing my framing in the morning and Ive been worrying about my xbox, ps3, direct tv, etc controllers. Im going to have all of my electronics outside of the theater in a rack. So between the seating, which probably less than 10 feet away, will be double 5/8th dry wall with green glue, on both sides of the wall.
I know plenty of people here had builds with racks outside of the room. Will RF controllers work in the theater, or in my other matrixed tvs on the other side?
SKINSnCANES is offline
post #2 of 4 Old 12-06-2012, 05:05 AM
Quoted: 3823 Post(s)
Liked: 3253
I've not heard of an issue with RF and super thick walls, but if you are really concerned put in a run of Cat6 from the screen wall to the equipment area and worst case you could use an IR link.
post #3 of 4 Old 12-06-2012, 05:09 AM
Willie's Avatar
Quoted: 79 Post(s)
Liked: 111
Your best bet is to check out the A/V Automation and Control sub-forums here on AVS. Options include Wi-Fi IP control to low voltage wiring for an IR based system. Not sure RF is the best avenue.
Willie
Willie is online now
post #4 of 4 Old 12-08-2012, 06:31 AM
HT_SoulMan's Avatar
Checkout the remotes forums here. You can also do some research on MRF-250 and up base stations and/or remotes that are compatible...
HT_SoulMan is offline
