Help with Riser Width - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-05-2012, 10:38 PM - Thread Starter
Cobb28's Avatar
Need advice on riser width. Room is 20ft wide. The Fusion Lagoon 1011 seats I will order are curved and 134.75" from end to end.
Planning on making the risers 7' long and 8" high with 2 layers of plywood with tar paper/felt in between the plywood.
I've read up quite a bit on it but couldn't exactly find a good conversation regarding width. I've used the riser height calculator which recommends 10.25" height for the risers so I'm thinking with the added plywood and felt I should be just about right. I don't really want to go wall to wall as my ceilings are only 8' in height. How many inches/feet wide to play it safe?
Thank you.
Cobb28 is offline
post #2 of 2 Old 12-06-2012, 03:47 AM
Quoted: 3354 Post(s)
Liked: 2830
I prefer wall to wall. Consider building a 6 inch riser and a 2 inch booster riser under the base of the seats.
