Lighting Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-08-2012, 05:50 PM - Thread Starter
OzzieP's Avatar
I have a rope light that plugs directly into an outlet but would like to plug it into something that would allow me to control it (ON/OFF or Dim) using my Harmony 1 Remote.
OzzieP is offline
post #2 of 4 Old 12-08-2012, 06:29 PM
ambesolman's Avatar
Quoted: 1100 Post(s)
Liked: 921
Any of your components that have an outlet in the back should work. My old Sony reciever had one I used for a string of lights that illuminated from the back of the tv. Unfortunately my newer reciever doesn't have one so I don't have the lights anymore frown.gif
ambesolman is online now
post #3 of 4 Old 12-08-2012, 08:18 PM - Thread Starter
OzzieP's Avatar
My receiver is a long way from where my LED rope light is.
I am hooking up LED's around the backside of movie screen for a rear glow effect.
and around some steps as well. These lights plug directly into wall outlets but would
like to be able to control them with a master remote like a Harmony 1.
OzzieP is offline
post #4 of 4 Old 12-09-2012, 04:28 AM
Quoted: 3898 Post(s)
Liked: 3333
Visit the harmony one discussions and pose your question. You should be able to hard wire a wall switch dimmer into the circuit. It's just a matter of finding the right one.
