Amb1s1 Official Theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 12-10-2012, 09:34 AM - Thread Starter
amb1s1's Avatar
I officially started my theater build 2 weeks ago, but I'm in the started process where I was deciding how to design my theater. Taking outputs from couple of AVS Users, I already decide my HT layout. Right now, I'm in the cleaning process of my basement and I will be making a big order this weekend. I will be doing my entire basement, but I will like to focus just the Theater build in this tread. I was previews thinking about doing one row, but since I always have my nephew and his girlfriend in my house I decide to do 2 rows.
Here is my layout sketch: I would like to thanks Mat1220 because I use his sketch style and his HT design.
Here are some of my basement pictures.
Screen Wall
Seating area
This is a hole that have space under my daughters Room, it also have a vent to outside. Should I block this hole entirely or should I have like a plug with an small vent. I don't know if I block that vent I would do something wrong.
Here is my List of Items that I want to buy and because I have a 20% HT coupon that will expire on 12/31 I want to buy as much as my budget permit.
1. 2x4 - Framing 24" on center
2. Recessed lights
3. Whisper clip just for the ceiling (I will be doing double wall for my walls)
4. Drywalls
5. Hat channels
6. 14 gauge 100' electrical wire
7. Roxul Safe n Sound
8. Maybe Drywall
I should be busy until I get funds for my next stage. Thanks
amb1s1 is offline
post #2 of 22 Old 12-26-2012, 06:30 PM - Thread Starter
amb1s1's Avatar
Here is my progress:
[IMG][IMG]
amb1s1 is offline
post #3 of 22 Old 12-26-2012, 06:32 PM - Thread Starter
amb1s1's Avatar
I can hear the different when I talk, there is no echo in the room.
amb1s1 is offline
post #4 of 22 Old 12-26-2012, 08:07 PM - Thread Starter
amb1s1's Avatar
I want to use this 3 in recessed light on my soffit:
http://m.lowes.com/product?langId=-1&storeId=10702&catalogId=10051&productId=3014681&store=2328&view=detail
I would like to know how far away from each other should I install the lights?
amb1s1 is offline
post #5 of 22 Old 12-26-2012, 09:03 PM
NGiovas's Avatar
Liked: 43
Probably around 4' apart. Make sure insulation is at least 3" from this light.
NGiovas is offline
post #6 of 22 Old 12-26-2012, 09:07 PM - Thread Starter
amb1s1's Avatar
I'm going to buid a sofit without insulation.
amb1s1 is offline
post #7 of 22 Old 12-27-2012, 06:03 AM
NGiovas's Avatar
Liked: 43
You will want some insulation in your soffit to prevent it from turning into a giant "drum". sounds that penetrate the soffit will just bounce around causing issues.
NGiovas is offline
post #8 of 22 Old 12-27-2012, 06:48 AM
corpkid12's Avatar
This might help with the lighting layout
http://www.forteelectric.com/Howtolayoutcans.html
Jay
corpkid12 is offline
post #9 of 22 Old 12-27-2012, 09:00 AM - Thread Starter
amb1s1's Avatar
If I have the lights 4' feet apart and I can't have insulation 3' near the insulation so that's mean that I have 1 feet of insulation between each lights.
amb1s1 is offline
post #10 of 22 Old 12-27-2012, 09:41 AM
jmhug's Avatar
3 inches not feet. Those lights in your link are non-ic - meaning they can't have contact with insulation. The light itself should state how far away to keep the insulation. ( There are lights made that allow contact with insulation if you need.)
jmhug is offline
post #11 of 22 Old 12-27-2012, 03:47 PM - Thread Starter
amb1s1's Avatar
I got some of my video and audio cables and wall plates from monoprice.
My funds are done for this round. I'm fixing little details and stuff that I can fix without the need of buying materials.
amb1s1 is offline
post #12 of 22 Old 12-28-2012, 04:27 PM - Thread Starter
amb1s1's Avatar
I have a question about my false wall with AT screen. If you see the picture my left side of the front of my ht is 1' away from the wall and the right side is just few inches. Since my room is not that big I'm fighting for every inch. I was planning to put my false wall 16 to 24 inches away, but I would not be able to put my left speaker in the right position. What you guys think I should do?
amb1s1 is offline
post #13 of 22 Old 01-15-2013, 08:34 AM
jmhug's Avatar
What's behind the bump out on the left?
jmhug is offline
post #14 of 22 Old 01-15-2013, 04:51 PM - Thread Starter
amb1s1's Avatar
There is a pipe, but I have some empty space.
amb1s1 is offline
post #15 of 22 Old 01-15-2013, 04:51 PM - Thread Starter
amb1s1's Avatar
amb1s1 is offline
post #16 of 22 Old 01-15-2013, 08:50 PM
jmhug's Avatar
Well I'm a little bit confused so let me know where I'm misinterpreting. If the bump out is currently 12 inches and you are planning on 16-24 inches for your screen wall, why don't you just remove the current framing that is in there in front of the pipe? That way you can frame in your screen wall at 16-24 inches and the pipe will remain hidden. That should leave you with plenty of room for the L speaker shouldn't it?
Also - do you have moisture issues down there? Did you plan for a vapor barrier on the foundation walls? You don't want to start sealing up that room with drywall until that is addressed otherwise you will most likely end up with mold/mildew issues.
jmhug is offline
post #17 of 22 Old 01-16-2013, 03:20 PM - Thread Starter
amb1s1's Avatar
As you can see on my sketch the back of my theater is not as wide as the front. Where should I locate the projector? Right in the back middle of the ceiling, that is my common sense, but I just want to confirm so I can nail a plywood between the studs to support the projector mount. Thanks
amb1s1 is offline
post #18 of 22 Old 04-02-2013, 08:26 PM - Thread Starter
amb1s1's Avatar
Long time that I have not updated my build. Here are my updates pictures:
Front stage
Here is the left column an entry. I'm going to have five zone, three insteon dimmers and two insteon on and off switches. I'm also bought the Bose 191 in wall speaker and I will have it on the columns.
This is the raiser. I did it with 2x8 and two layers of 3/4 plywood. I also had black 30 felt between the 2x8 and the floor and between the two layers of plywood.
This is going to be my equipment rack.
I just bought a 18000 btu 20.5 seer LG mini split. The mini split is double the recommended for my ht space, but I will be using it to cool down the entire basement. We barely use the AC on the first floor during the summer due that my house is cover by trees. For heater, the mini split will be heating the HT and I have baseboard on the other part of the basement.
amb1s1 is offline
post #19 of 22 Old 04-02-2013, 08:30 PM - Thread Starter
amb1s1's Avatar
What you guys think about this setup? I'm thinking about doing this due to budget for the couch. I'm like the pallet to be paint in black with red and black pillow. I can fit just two rows, but the only issue is that must time I would like to wath the movie seating and there is no back support. Maybe I do the back row like this and old sofa in the front. It will be cool with led in the bottom.
amb1s1 is offline
post #20 of 22 Old 04-03-2013, 06:53 AM
Quoted: 3256 Post(s)
Liked: 2743
This reminds of the episode of Seinfeld when Kramer decides to turn his apartment into Levels, eliminating furniture. I think the key is head/back support for long term viewing. If you can figure that out it should work.
http://www.youtube.com/watch?feature=player_detailpage&v=aQyXeLSL0II
post #21 of 22 Old 04-03-2013, 12:21 PM - Thread Starter
amb1s1's Avatar
LOL
amb1s1 is offline
post #22 of 22 Old 08-29-2013, 12:37 PM - Thread Starter
amb1s1's Avatar
If you see post 18 you will see that my columns is going to on front of my seating position and I will have my in-wall speakers in those columns. Thats the only placement that I can have my speaker surround speakers. What you guys think about that? About my rear speakers, should I put them on the side or the rear wall. My planning was having them on the rear wall, but I just want to know what you guys think. Thanks
amb1s1 is offline
