Will raised basement floor increase tactile bass response? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Roger Dressler
post #1 of 7 Old 12-23-2012, 11:42 AM - Thread Starter
MSutton's Avatar
Currently have carpet directly on concrete from previous owners.
Since no sub is going to transmit through concrete, would adding a subfloor (Barricade, DriCore) provide more tactile feedback of bass transmission?
MSutton is offline
post #2 of 7 Old 12-24-2012, 05:38 AM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
Raise your basement floor to make it more comfortable to walk on and provide a small margin of flood resistance. (your carpet will probably last longer too) Get some buttkickers for tactile bass, unless you have the space for a couple of those Orbit shifters or giant infinite baffle (IB) setup and the amplification for either to make it sing. just a thought. merry krimble
underachiever extraordinaire
weaselfest is offline
post #3 of 7 Old 12-24-2012, 07:42 PM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 711
Yes, it will improve the tactile bass sensation a lot. Dolby did exactly that in their SF theater,which is built on 3 layers of concrete. They not only built the seats up on risers, they provided an open channel so the sound of the subwoofers could more easily reach under the seats.
In my room, already built on the second story of a house, wood joists and subfloor, I built my 2nd row riser 12" tall but used 6" joists to allow airflow (filled with pink insulation) and to prevent direct contact with the floor. The riser is also separated from the side walls by a small gap, and the frame itself sits on the foam carpet pad that I left in place after pulling the original carpet. The bass sensation is really good, feels totally natural, and is totally free. The front row has some tactile sensation also, but noticeably less. So you can vary how much based on how rigidly you build the subfloor. If is is very rigid and in direct contact with the concrete, it may be rather mild.
saginawjuggalo likes this.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #4 of 7 Old 12-25-2012, 08:45 PM
xb1032's Avatar
Liked: 26
My guess is this helped. When I did my room I split treated 2x4s and spaced them 16" apart by gluing them to the concrete floor with liquid nails and used OSB for flooring. I can feel the bass with this setup but it's not even close to as effective as what I can feel in the family room above. I've had water in my basement before and this actually saved the carpet since the water was under the flooring and I dried it out but lifting the carpet, drilling holes, and pushing air in the the affected areas.
xb1032 is offline
post #5 of 7 Old 12-25-2012, 09:03 PM
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
No problem with tactile response here. I am also on Concrete floors with no risers.
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #6 of 7 Old 12-26-2012, 07:00 AM
Skylinestar's Avatar
Quoted: 1062 Post(s)
Liked: 186
How is that possible?
Skylinestar is offline
post #7 of 7 Old 12-26-2012, 12:00 PM
jedimastergrant's Avatar
Quoted: 576 Post(s)
Liked: 303
Well, after checking out Dave's sig it looks like he has 4 x 18'' XXX drivers in an IB and he is adding 3 more soon! I would say just about anything is possible with that much firepower.
I believe that concrete is actually a great conductor of sound so if you have enough subwoofer up front you should not have any problems with tactile sensation. I would guess most people maybe don't quite have enough subwoofer to get the sensation they are after. And then for some people it will simply never be enough!
I can attest that my "smallish" built in subs contained in my Def Tech Mythos STS towers shake my main floor wood floor like crazy! So I am hoping my Orbit Shifter will be able to provide some tactile sensation via my concrete floor. I will be doing a riser as well and I anticipate that the sensation will be much greater for the second row riser. I am currently planning to put my OS on a sand filled stage and this will probably decrease the transmission of sound and I am a bit worried about this. Maybe I should place the sub directly on the concrete and only have the stage built in front of the false wall? I dunno.
The most insane tactile feel I have ever experienced was at member DesertDomes at the recent Omaha Home Theater tour. He has an in floor IB setup with 8 x 18" drivers. His floor is wooden and is likely near 80-100 years old. It shakes your entire body! Everyone in attendance had a huge grin on their face. It was actually a little bit too much for me but very very fun.
I am sure one also needs to consider distance to the source when attempting to get more tactile sensation.
You could always put a second sub on top of a riser like the one Roger described. My riser will be constructed in this fashion too.
I have had mixed results with tactile transducers. It can have an artificial on/off feel to it if not done correctly. I would rather have my bass be ''natural'' with all of the smaller increments of sensation intact. But, if my OS just can't go through my stage and concrete then I will look into tactile transducers and/or near field subs.
Edit: I would consider doing the raised floor just like XB described but my ceiling height is an issue. Maybe just a layer of plywood would help? This may or may not hinder any soundproofing efforts you have.
jedimastergrant is online now
