Should I build the rack under stair or other room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 12-24-2012, 02:40 PM - Thread Starter
amb1s1's Avatar
I was planning to do my rack on the back of the HT, but wife so the empty space under the stair and want me to build it there. What you guys think? It this a fight worth to fight? Here is the picture,
amb1s1 is offline
post #2 of 19 Old 12-24-2012, 03:55 PM
NGiovas's Avatar
Liked: 43
If I had the room, I would have preferred to put my rack outside of the theater in another area to eliminate the heat from the equipment. Unfortunately, there wasn't a good place to put it outside of the theater. It looks like you may have a really good option. If that area is right outside the theater, you could make a lobby area and have the equipment there. With all of the remote software and network control of devices, it isn't necessary to have the equipment in the room any more.
NGiovas is offline
post #3 of 19 Old 12-24-2012, 06:09 PM
JamesB77's Avatar
I have my rack going in its own room under the stairs.
An Aspen Woods Theater - Under Construction
JamesB77 is offline
post #4 of 19 Old 12-24-2012, 07:32 PM - Thread Starter
amb1s1's Avatar
I told my wife that I consult the avsforum guru and they told that it can't be done, she was ok.
amb1s1 is offline
post #5 of 19 Old 12-24-2012, 08:24 PM
scl23enn4m3's Avatar
My rack is under the stairs as well. There isn't a lot of room behind it, but then again I rarely need to go back there. No regrets.
scl23enn4m3 is offline
post #6 of 19 Old 12-24-2012, 08:39 PM - Thread Starter
amb1s1's Avatar
Can you guys take a picture of your rack under the stair.
amb1s1 is offline
post #7 of 19 Old 12-25-2012, 12:22 PM
dynfan's Avatar
I put mine under the stairs because I wanted the gear in the room and also access behind it. Here's some pictures.
The back of the rack is a bass trap ans is removable to access the hardware.
Here is a shot with the back removed.
Pick of rack from the front.
I would do it again in a heartbeat! It was inexpensive as I made all of the shelving and the bass trap is completely functional. Also accessing the rack is nice. The bass trap is kinda heavy but I'll take that tradeoff with being able to move things around and work on wire management sitting down with a beer!
Hope this helps.
dynfan is offline
post #8 of 19 Old 12-25-2012, 01:35 PM - Thread Starter
amb1s1's Avatar
Is that mdf?
amb1s1 is offline
post #9 of 19 Old 12-26-2012, 11:43 AM
MrSmee's Avatar
FWIW, I decided to build the equipment closet under the stairs since it was a more efficient use of space and it was easy to access and yet unobtrusive. I did have a little bit of an issue since I had a load bearing column in the way, but I was able to get 22" of usable width after installing the trim. The original stairs were fairly flimsy, so I rebuilt that and added insulation between the stairs and MDF that went under the stairs. In order to keep the rack cool once I add a glass door to the rack, I added an air vent to draw in the air from the floor level from one of the sides with an exhaust fan on the other side to draw the hot air out. I also built an access door to the equipment rack, I do have to crouch a little while I am playing with the connections). The rack was built using closet maid standards and brackets with MDF boards for shelving with trim and stained it. Some pictures below -
MrSmee is offline
post #10 of 19 Old 12-26-2012, 04:22 PM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
Awesome!
love the "PeeWee's Playhouse" type door to acces behind the rack.
I have the same molding you used for your shelf fronts on a powder room mirror frame I built.
underachiever extraordinaire
weaselfest is offline
post #11 of 19 Old 12-26-2012, 05:51 PM
I snapped these with my phone a few minutes ago so you'll have to ignore the poor lighting and mess.
This is the rack from right outside the room. The door to the right of the rack leads into the back.
This is what's through said door. I didn't have enough depth in the room to get a good shot, but I think you get the idea. The second rack in the back was just because I ran out of room in the first, so it's where all of the networking equipment ended up. There is just enough room for one person to stand and turn around in.
And to put it into the perspective, the stairs exit into the basement on the left. The ceiling of the rack room is the landing for the stairs.
The only downside to the rack being where it is, is running all of the wires into it. That structure is load bearing, and I ended up making a lot of holes in the studs to pass the wires through. My contractor said it was no problem, but I doubled up every stud just to be sure.
post #12 of 19 Old 12-26-2012, 08:05 PM - Thread Starter
amb1s1's Avatar
This is the rack from right outside the room. The door to the right out of leads into the back.
How big is the frame opening without the rack?
amb1s1 is offline
post #13 of 19 Old 12-26-2012, 08:14 PM
Just shy of 21" if I remember correctly. It's a 19" rack so that plus the width of the side posts.
post #14 of 19 Old 12-26-2012, 08:18 PM - Thread Starter
amb1s1's Avatar
What is the height and the depth of your rack.
amb1s1 is offline
post #15 of 19 Old 12-26-2012, 09:43 PM
dynfan's Avatar
Originally Posted by amb1s1 View Post
Is that mdf?
Yes the side walls are all 3/4" MDF and I used a piece of pegboard as a reference guide to drill out the holes for the shelf pegs. All of the shelfs are cut from MDF also. It worked very well and was VERY cheap to do. Certainly more room to make it more elegant, but I wanted functional and to blend in to the area...
dynfan is offline
post #16 of 19 Old 12-27-2012, 08:44 PM - Thread Starter
amb1s1's Avatar
How do you do the frame where the mdf are sitting and attach to? And how do you do the mdf box? Just a simple glue and nail?
amb1s1 is offline
post #17 of 19 Old 12-27-2012, 11:14 PM
dynfan's Avatar
I framed the closet like I would any other project. I then had it drywalled like the rest of the theater and put my MDF over the Drywall and screwed it in to the studs. I planned on doing this so I took my measurements in to account but in reality I had a ton of room. I wanted to leave everything as poen as possible to provide plenty of air circulation around components. As it stands now I am making more shelves so that NO components are stacked on each other and each has it's own shelf.
dynfan is offline
post #18 of 19 Old 01-16-2014, 08:08 PM
Tfleming675's Avatar
Here is my solution for under the stairs. This is a new project. Just done this yesterday. I am worried about heat under the stairs. Also, this now has a large whole in the sound proofing. Any thoughts? I am using a Mid Atlantic SRSR-19 and my recover is an SC-65 from Pioneer.
photo.jpeg 912k .jpeg file
Pioneer SC-65
KEF, Q5 Front, Q9 Center, Q1 rear, Q800DS
Epson 3020 Projector, 135 in 235.1 screen
OPPO 103D, Apple TV, XBOX 360
Tfleming675 is offline
post #19 of 19 Old 01-18-2014, 03:09 PM
dsiroky's Avatar
My rack is in the room, but hidden behind an acoustic panel so you don't hear/see it when the movie is playing.
I included a load of disc storage space within the room, so that you can pick your movie and load it without leaving the room.
I find it was a good decision, as I'm constantly loading Blu-ray discs in the room, and would find it annoying to have to walk to another room to load the disc.
dsiroky is offline
