Another soundproofing and insulation thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Old 06-01-2014, 07:08 AM
Tyrone Ragbasi's Avatar
I have recently build a room for a studio, with the intention of soundproofing it... in which the flooring is cast as well as the roofing, and the sides are blocked up, so its all wall right round...it has no windows, and only one door... how do i soundproof that room ?
Tyrone Ragbasi is offline
Old 06-01-2014, 07:12 AM
Old 06-01-2014, 10:14 AM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
For a studio, for best results, I would go with a "room within a room". Stud walls isolated from the block walls, ceiling joists supported by the isolated walls, at least 2 layers of 5/8" fire-rated drywall with green glue between layers. Cover the floor with acoustic mat, with OSB on top of that, then padding and carpet. Heavy door with seals, maybe connecting doors. Pay attention to any wall penetrations, including HVAC supply and return.
Basic stuff -- see the Soundproofing Master Thread on this forum.
Then you's need to worry about acoustical treatment inside the studio....
LeBon is offline
