help and advice first theater room. Framing done - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-05-2013, 10:23 AM - Thread Starter
steve392's Avatar
I have been reading these forums over the years and learning all I can with respect to projectors/speakers/receivers. I was hoping to get some advice as I just finished framing my theater room and I am about to run all wires. I have attached a picture with the layoutThe green box is the subwoofer. The big red box is where my floor is rasied 6 inches for the second row.
I need to know the best possible location for the sub and surround speakers. this setup is 100% movies and I like it very loud with lots of bass. I liked the bass my old velodyne dsp10 put out. Also I wouldn't mind some suggestions on speakers and projector. I care more about 2d picture quality. I like the picture very bright and vibrant.
Front Speakers: Klipsch RF82
Center Channel: Klipsch RC64
Subwoofer: ??? need Help here
Surrounds: Klipsch RS62
Receiver: Onkyo NR818
Projector: Panny 8000U mounting 15 feet from 120" pure white screen.
I am open to two subs if possible. Also should those surround speakers be mounted directly in the corner because if they are the sound will not be pointing at the seating positions due to there style.
My budget for the Projector is 3k
Speaker budget is 3-5k
any help would be great.
ht.bmp 988k .bmp file
steve392 is offline
post #2 of 6 Old 01-05-2013, 10:24 AM - Thread Starter
steve392's Avatar
I also might go with an epson 5020ub
Tough to find dealers in Canada though.
steve392 is offline
post #3 of 6 Old 01-05-2013, 10:55 AM
Damage Inc's Avatar
Regarding sub(s) for retail and bang for your Canuck buck try one or even two of these
http://www.sonicboomaudio.com/sb12nsd-powered-box-sub-12-nsd-woofer-charcoal-black-vinyl-p-48.html
I have one and will most likely and a second when I complete my HT build
Damage Inc is offline
post #4 of 6 Old 01-05-2013, 11:03 AM - Thread Starter
steve392's Avatar
I have been reading a lot about svs subs.. thanks
The only subs I have ever used was a velodyne dsp10 so aslong as the performance is at par or better I will very happy.
steve392 is offline
post #5 of 6 Old 01-05-2013, 04:03 PM
Damage Inc's Avatar
Only took a quick look at the velodyde stas. I think the SVS would outperform it. Even the sealed version would be a substantial improvement. Can't really do much better at that price point unless you DIY.
post #6 of 6 Old 01-05-2013, 05:31 PM
b0gus's Avatar
I currently own a Velodyne dsp10 and will be upgrading to the SVS "new" SB12-NSD. It's the best option for me as well being Canadian.
I think the difference between the two subs will be very apparent. The Velodyne is more of a Futureshop special, and performs fine given the right environment, but the SVS is in a different league altogether. Don't take my word for it. Do what I am doing and read reviews, forum posts from users, etc.
Something I have heard in these forums is that SVS planned on offering free shipping in the new year (2013)...just checked and doesn't appear that they are. Maybe it's only for the Americans.
Nice room size BTW, should be a fun experience for you.
I think it's past time to upgrade my equipment and my room.
b0gus is offline
