Greedo's Cantina - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #211 of 228 Old 02-16-2017, 09:15 AM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Originally Posted by DougUSMC View Post
It's my fault b/c it's easier than I made it seem. Since I didn't know your own personal technical skills, I went to a lot of detail so you wouldn't have a tough time figuring it out your first time.
In reality, it's: Drag & drop, copy and paste link to pic, add tags before and after.
It takes 5 seconds.
Still. I've been in IT for 20 years, primarily working on web technologies, and this is horrible. No auto-resizing of images, etc etc. 5 seconds per picture, when the web is largely visual, is nuts. Definitely a change for the worse for the forums.
greedo is offline
post #212 of 228 Old 02-16-2017, 09:53 AM
DougUSMC's Avatar
Quoted: 302 Post(s)
Liked: 240
Well, you have to expect *some* changes when it's 2.5 years between posts, and 5 years after thread start. :P
I hear you that we expect at least a bit of improvement with "changes", but personally I appreciate the free forum, and just go with the flow on stuff usually.
greedo likes this.
DougUSMC is offline
post #213 of 228 Old 02-16-2017, 11:16 AM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Four years! (Though it'll probably be five when everything is said and done...)
greedo is offline
post #214 of 228 Old 02-16-2017, 11:22 AM
DougUSMC's Avatar
Quoted: 302 Post(s)
Liked: 240
Oops, you're right! My fault, my math was off.
Four sounds *so* much better than five.
DougUSMC is offline
post #215 of 228 Old 02-17-2017, 08:49 AM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Pics from the rest of the completed basement
Here are some pics of the bathroom I installed. I did all the work with the exception of the plumbing.
ID:	1975553   Click image for larger version
greedo is offline
post #216 of 228 Old 02-17-2017, 08:58 AM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
This is the entrance to the HT, with the stairs to the right:
Here's the hallway leading to the craft room and bedroom. On the left you can see some under-stair storage, and past that a bit the opening to my HT rack. The right door heads to my utility room.
This is my wife's craft room for scrapbooking/sewing etc. I'm going to see how long I can hold off on building a panel over the electrical stuff, but she's pushing hard!
Here's the french doors leading to the bedroom I added. To the left is the door to my rack under the stairs
Finally, the bedroom itself. I need to get a proper cover for the egress well, but plywood has worked for two years, so fix what isn't broken?
ID:	1975617   Click image for larger version
ID:	1975625   Click image for larger version
ID:	1975633   Click image for larger version
ID:	1975641   Click image for larger version
greedo is offline
post #217 of 228 Old 02-17-2017, 09:37 AM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Here's my rack room. I'm using an MA Slim 5.
Here's the external access to the rack. It's ugly now since I don't have any external facing components. At some point I might install a hinged smoked glass door, but I don't want to impede airflow.
Rear access to the rack. It's not as wide as I'd like, but even a fat dude like me can still fit back there when needed. I put two LED lights into the recess above the rack, so there's plenty of light.
Back of the rack. Right now I just have my ethernet runs going into a temporary 100mb/s switch, fed by a TWC/Spectrum modem. We're getting fiber in our neighborhood this year, and I'll upgrade to GigE at that point.
My cable runs from both the HT and the rest of the house. I ran two extra conduits for future growth. One runs to the front wall and the other next to my projector's Powerbridge.
Here's the Powerbridge and dedicated 20amp circuit. The Powerbridge will connect to my UPS so my projector can cool down in the event of a power outage. We haven't had any since I've lived in this house (13 years) but might as well do it right.
ID:	1978129   Click image for larger version
ID:	1978137   Click image for larger version
ID:	1978145   Click image for larger version
ID:	1978153   Click image for larger version
greedo is offline
post #218 of 228 Old 02-17-2017, 10:31 AM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Here's the HT after all the drywall mudding was done. I need to see about finding a black smoke detector, as this white one will stand out like a sore thumb.
Facing the screen wall:
From under the soffit at the front:
Reverse angle:
Showing the proscenium:
Back wall:
ID:	1976009   Click image for larger version
ID:	1976017   Click image for larger version
ID:	1976025   Click image for larger version
ID:	1976041   Click image for larger version
ID:	1976057   Click image for larger version
greedo is offline
post #219 of 228 Old 02-19-2017, 02:57 PM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Painted my grills and light trim with Rustoleum high-temp paint. Did the smoke detector too after carefully masking it. I'll need to touch that one up with a brush.
greedo is offline
post #220 of 228 Old 02-19-2017, 03:00 PM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Here's the HT after being primed. I had the primer tinted gray so that the ceiling paint would look best, but both I and the wife like this gray. But I'll be using a deep Burgundy from Sherwin Williams with gray sound panels.
ID:	1980801   Click image for larger version
ID:	1980809   Click image for larger version
greedo is offline
post #221 of 228 Old 02-19-2017, 03:04 PM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Duct Insulation
After priming the room, I was playing around with a cheap sound meter, and then realized that the air return at the back of the room hadn't been covered in linacoustic or anything like that. So now I'm worried that I might get some background noise from the AC via that route... I could cut up some pieces of Knauf Atmosphere liner and put them in, but that's going to be hard to do properly with the returns sealed up. Any ideas?
Before drywalling:
The return openings:
The returns connect to the trunk via flexible connections that have some damping ability, but it's only an elbow (90 degree) turn without a lot of flex to absorb noise. I'm super mad that I missed this when I was drywalling the room, it never entered my mind.
ID:	1980825   Click image for larger version
greedo is offline
post #222 of 228 Old 02-23-2017, 03:44 PM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Got the first coat on the ceiling and front wall. Sherwin Williams Promar 400. Very flat, looks good on the ceiling, but the back wall looks like crap since I rolled it on too hard and left edge marks. The front wall will get covered with Knauf Atmosphere Liner, so I just wanted it black and didn't really stress about it. The ceiling just disappears with the black paint, very happy with it. I'll throw on at least one more coat this weekend.
In two of the pics you can see the burgundy/rust I'm using for the side walls. I really like it, better than a traditional red. The sound panels that will go around the room will probably be close to the gray of the primer on the walls right now. I'll have to decide on a carpet pretty soon too; I don't want anything patterned, and I'd like it to be a bit of a plush carpet since I love being barefoot.
ID:	1989473   Click image for larger version
ID:	1989481   Click image for larger version
ID:	1989489   Click image for larger version
greedo is offline
post #223 of 228 Old 02-23-2017, 03:45 PM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
What's a good adhesive for gluing duct liner to a duct? Wasn't sure if I should use one of the PL types, or a spray on adhesive.
greedo is offline
post #224 of 228 Old 02-27-2017, 06:44 AM
kmhvball's Avatar
Quoted: 531 Post(s)
Liked: 297
I used FastCap cabinet screws to attach my duct liner to the wall.
kmhvball is offline
post #225 of 228 Old 03-01-2017, 07:36 PM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
I'm using FastCap screws (on Big's recommendation) as well. I was referring to installing the duct liner into the actual duct. I found a post of Big's that said to use 3M 77 spray adhesive. Hopefully that will be easy enough to use, as I'm going to have to be putting the liner into the duct through the register opening.
greedo is offline
post #226 of 228 Old 03-03-2017, 02:27 PM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Been busy getting the paint finished, adding all the trim, and putting up the duct liner on the front wall. I'm very happy with how everything is looking so far, and it's nice to get to a point where you're not "imagining" how things will look!
ID:	2004433   Click image for larger version
ID:	2004441   Click image for larger version
ID:	2004449   Click image for larger version
ID:	2004457   Click image for larger version
ID:	2004473   Click image for larger version
ID:	2004481   Click image for larger version
greedo is offline
post #227 of 228 Old 03-03-2017, 03:01 PM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Here's the room ready for carpet, plus some of the carpet styles we're contemplating. One question I have is if I cover the front wall (the ductliner) with velvet or GOM, how should I attach it? I used Fastcap screws for the ductliner, but I don't think those would work well for the front wall fabric.
ID:	2004577   Click image for larger version
ID:	2004585   Click image for larger version
ID:	2004593   Click image for larger version
ID:	2004601   Click image for larger version
ID:	2004617   Click image for larger version
ID:	2004625   Click image for larger version
ID:	2004633   Click image for larger version
greedo is offline
post #228 of 228 Old 03-07-2017, 06:19 AM - Thread Starter
greedo's Avatar
Quoted: 13 Post(s)
Any ideas on fastening the GOM to my front wall?
greedo is offline
