Question about running different wires along side each other. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-12-2013, 04:43 PM - Thread Starter
Slingblayde's Avatar
Liked: 64
I want to drill some holes along all the studs from the rack closet, around to the screen and past it so I have speakers and sub connects on each side of the screen. I need to run speaker wires (12g monoprice), RCA cables for the subs (also monoprice), and also 3 very long USB cables (monoprice yet again, BUT, with a range extender built inline). Can I run them all in the same holes in the studs? I know not to put any wiring near the electrical wires, but will I get any humming, buzzing or any other type of interference if I have these 3 different types of wire along the same set of holes in the studs?
Thanks for any info!
Optoma HD33, Onkyo TX-NR818 in a 9.2 setup, Emotiva XPA-5 G2, UPA-700 for eventual 11.2 setup
Oppo BDP-103, , Middle Atlantic Slim 5-37-26
F - Klipsch RB-61 II, C - Klipsch RC-62 II, Side/Rear Surrounds - Klipsch RS-42's, Heights - Klipsch RS-41's
Dual - PSA XV15's, Fractal Designs Node 605 HTPC
Slingblayde is offline
post #2 of 2 Old 01-12-2013, 05:17 PM
RTROSE's Avatar
Quoted: 193 Post(s)
Liked: 168
You should be just fine doing what you describe.
RTROSE
RTROSE is offline
