My upcoming Project <Attic Build DIY> Video Added - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-13-2013, 06:33 PM - Thread Starter
bduncan118's Avatar
I've been thinking about starting my HT Attic room for quite some time. My wife gave me the go ahead today. I have a large open space in my attic that I have been using for storage for a while. The size of my room is going to be 10 X 20 with 9ft ceilings. I could go 12 X 20 but I have a large roof support post coming down in the room. I was blessed that the flooring is already down (The builder said it was built with an addition in mind, and it shares the same 2X10 trusses as the upstairs bedroom does).
Do you think the building inspector will make me use the exterior wall and put a window in, or will I be able to build 4 new walls and not do the window. I am doing everything except HVAC, and electrical myself. Thankfully the upstairs already has its own AC unit and all they will have to do is run the vent tubes to the room (The AC unit is in the attic and will be about 12 feet from the room). I plan on doing this in 4 stages:
#1 Room Construction- Building room, insulation, drywall, lighting, and paint
#2 Electronics- Projector, Screen, Audio, Furniture
#3 Hallway walking to theatre
#4 Extra Storage
The Entrance
The Roof of the Attic (20+ ft high)
The Main part of where the room will be. Note the roof support truss coming down. I could go an extra 2 ft wide and build a column around the post, undecided on that.
UPDATE:
https://www.youtube.com/watch?v=XaFkSU1Rh9Y&feature=youtube_gdata_player
Attached is a video of the room I will be building in. It starts at 3:30 for the upstairs. Any creative ideas with the step up when you first walk in the attic? I can not change that as the downstairs hall has 12 ft ceilings and the rooms surrounding it have 10.
bduncan118 is offline
post #2 of 9 Old 01-13-2013, 07:46 PM
jmhug's Avatar
I would assume an egress point is required for attic space that is finished in all code jurisdictions. That means you need to construct a way out other than the staircase leading up to the attic. You really don't want to get stuck up there if there is a fire in the space that blocks the stairs. As much as a pain in the rear code can seem, it's there for a reason (for the most part). A dormer with a window that opens usually qualifies but you should call your code/planning department and just ask them what would be required to pass inspection.
Looks like a promising space otherwise!
jmhug is offline
post #3 of 9 Old 01-13-2013, 07:59 PM - Thread Starter
bduncan118's Avatar
That's a bummer for sure. You walk up the steps into a bedroom. Through the bedroom you go into the attic. There is a window in the bedroom. Unfortunately from the door to the attic to the door in the theatre will be a 12 ft hallway. I really didn't want to have to cut the exterior of the house to put the window in. That would be out of my comfort zone and something i would have to pay somebody to do.
post #4 of 9 Old 01-14-2013, 03:51 AM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 192
You should speak to the building department and see what they are going to require. Typically, there is no requirement for a room (other than a sleeping room) to have a window or door to the exterior.
However, you are finishing space on the third floor now, which can trigger other requirements based on where you live. It may trigger a requirement for a window; in NY you would have to install fire sprinklers.
Tim
Mr.Tim is offline
post #5 of 9 Old 01-14-2013, 06:06 AM - Thread Starter
bduncan118's Avatar
This is on the second floor. Half the floor is finished the other half is the attic.
post #6 of 9 Old 01-14-2013, 06:47 AM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
I have an almost identical situation. Luckily for me I had a dormer that we were able to use. If you want to count the space as a bedroom you will most likely need a window. Is there anywhere you could transfer the load from that post coming down from the rafters? I'm no pro framer but I can't imagine that is actually holding the roof up. Also, do you know if your HVAC unit is big enough to service this addition? I too have a unit on my 2nd floor but it is only half of what I need for my addition. Are you going to go full bore on the soundproofing? If you really want it quiet you will most likely need to pull up that subfloor and isolate it from the floor joists. I didn't do that as the subfloor was down already. You could also look at putting acoustic mat on top of the subfloor and laying another layer of subfloor on top. I look forward to watching your progress. I have been planning my build for a year and we are almost done with the framing.
wraunch is offline
post #7 of 9 Old 01-14-2013, 06:58 AM - Thread Starter
bduncan118's Avatar
Thanks for the input! I most definitely wont be counting the space as a bedroom. The house already has 4. The current upstairs AC only runs about 200-300 sqft so i don't think it will have a problem with the new room. As far as the soundproofing Im not at all considering taking up the floor. I consider this a bonus that it is already down and i would be able to justify the noise downstairs to save the money. I will definitely look at the mat idea.
BD
post #8 of 9 Old 01-15-2013, 02:31 PM - Thread Starter
bduncan118's Avatar
Updates. I decided to go ahead with the window. Guy came out and measured and I should be getting an estimate today. The upstairs AC unit is 18,000 BTU (american standard Heritage 13) so I don't think adding another 275 sqft is out of the question. The existing room is a "T" room no more than 300 -400 sq ft. Below is the plan for the layout with a 3d image of it
The hallway came out a little mis-shaped but I'm ok with that. I actually ended up measuring 21ft long plus a 3 ft deep closet / AV rack room. There is a roof support beam that sticks out 3 ft into the closet area, so I will just leave that in the unfinished storage side to the right of the room. If the building inspector makes me hire an engineer to certify that the floor can handle the load I'm gonna see about moving the roof support over (Which will make the overall room 4 ft wider at 21X14).
post #9 of 9 Old 01-22-2013, 11:16 AM - Thread Starter
bduncan118's Avatar
I forgot to add that the entrance door will be at the top of the hump.
