Basement subwoofer options?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-15-2013, 10:05 AM - Thread Starter
Scott Leonard's Avatar
Sorry for the cross post, but I think this might be a better spot to ask:
I'm not sure if this is the right forum but I will give it a shot. I'm building a projector home theater room in the back corner of my basement. There will be a small unfinished area in the front right corner, just right of the screen (not on the screen wall). My wife is not a fan of seeing the subwoofer. Is it possible to put the subwoofer in the unfinished area? If so what kind should I look for? Can it sit on the concrete floor and point out of the closet? Do I need a speaker cover cut out in the wall? Any other options? thanks in advance.
Scott Leonard is offline
