New Construction help...new thread with 3D plan - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-19-2013, 05:49 AM - Thread Starter
DarinS's Avatar
I decided to start a new thread due to the very helpful advise from a number of you. I have quickly bagged the idea of doing an open theater in my new recreation room which will be about 30x45'. In the image below, the home theater is 21'x16'. The space has cathedral ceilings but the HT will have a 9 foot ceiling. (The spiral staircase in the image will lead to a small loft situated above the theater...mainly to be used by the kids for sleep overs and such). The black rectangle on the wall by the pool table represents the HDTV suggestion to simply hang a monitor out in the play area instead of having the more open theater.
This is my very first go-around with any kind of 3D design. Obviously, things are a little sketchy and I used what components I could to fill in the space. I made this using the Google SketchUP.
Other thoughts: I have not added windows in the gaming area so use your imagination. The cathedral ceiling will employ exposed wood beams and pine. Hardwood in the gaming area with wood on the walls up to a chair-rail height and then paint on the rest of the walls. We are going for a lodge-type look. I live on a small farm and will have some old farm stuff like saddles, tools, etc on the exposed wooden cross beams. It should look pretty nice I would think.
So, any thoughts on the general design? Any specific thoughts on the theater area? Oh, yeah, one more thing. Upon entering the theater, that floor will be flush with the gaming room floor. It will then step down about 9 inches. I thought that would be pretty cool instead of having to step up.
Thanks for the help.
D
JBL #3677 Cinema Channel Loudspeakers x3 R/C/L
JBL #8320A Surround Loudspeaker x4
Danley DTS-10 Passive Subwoofer
QSC CMX 300Va, 500Va, and 800Va amps
Denon AVR-X4000P Integrated Network AV Receiver
Da-Lite Cinema Contour 81" x 144" 16:9 Screen, Pro-Trim, HD Pro 1.1 Perf
DarinS is offline
post #2 of 10 Old 01-19-2013, 06:45 AM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
That looks pretty good. 16x21 should be good for two rows - 6 seats easily, maybe 8 (I'm never good at remembering how wide they run).
When you say 9 feet for the ceiling, is that at the entrance end, or the screen end? If the screen end, it might be worth looking into pushing up a little more, but that wouldn't be absolutely necessary.
Now that you've committed to a dedicated design, it's time to start considering sound isolation and HVAC. Especially with lots of activity nearby, keeping a low noise floor in the theater can be challenging. As you may have seen referenced around here, there is only so much dynamic range in a recording - to be able to experience all of it, the room needs to be very quiet. If it's not very quiet, you'll either miss the quiet parts of the recording, or find yourself jumping for the remote when the action kicks in. Any thoughts about sound isolation expectations? Do you know what sorts of HVAC equipment will be installed and where they will be (zoned system?)?
HopefulFred is offline
post #3 of 10 Old 01-19-2013, 11:16 AM - Thread Starter
DarinS's Avatar
1. It would be 9' at the entrance end. However, I actually think the interior ceiling height will be more like 8' at the entrance. If we do the exterior walls at 9' and the loft, I'm guessing the support for the loft will dictate some 2x12' support would lower the interior height. This is, of course, not my area of expertise and will have to talk with my architect on that. If we do not do the loft, I'll probably lower the exterior walls to 8' since we will have the cathedral ceiling.
2. My thought was to put insulation in the walls between to help with noise. As I think about it, I guess I'll need to insulate the ceiling as well. I'm not sure about low noise floor. I've not read much about anything there besides putting in carpet.
3. HVAC will be a zoned system ducted from the crawlspace beneath.
Any more issues to discuss and think about? Also, I would love to have a little more feedback on the general idea on the space from others who have viewed but not replied.
D
DarinS is offline
post #4 of 10 Old 01-19-2013, 07:22 PM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
A lot of the theaters you will find on this forum use decoupling and damping in their sound isolation. How many of you will there be in the house? If you have kids, or expect to watch movies when your other half is already in bed, you might want to consider a more comprehensive design. what are the neighboring rooms like? Is this theater on a second floor, first floor, basement, etc?
As far as HVAC, a dedicated space will require more cooling capacity than most contractors will generally design for. On top of that, to keep the noise floor down, you want the air coming into the room to be moving slowly so that it's not noisy at the register.
Finally, where are you planning to put the door in that powder room? I can't tell if that's a hallway beside it or not in your model
The Plains Theater Has Begun
J_P_A is offline
post #5 of 10 Old 01-19-2013, 08:49 PM - Thread Starter
DarinS's Avatar
The room is actually going to be attached to the house through the small hallway by the bathroom (which enters through the hallway). The bathroom and wall where the foosball is pictured is a shared wall to the master bath. The master bath is actually separated from the master bedroom by a walk-in closet. There will be like 40 feet and 4 walls between the theater room and the master bedroom.
This is on the ground floor. I have 3 kids all of whom have upstairs bedrooms. Besides the one small shared wall, the rest of this structure will have exterior walls. We do a lot of entertaining so I would like to be able to fit 2 rows of 4 seats ideally with maybe some stools to pull in from the gaming area when needed. Most of the time, however there will be 7 of us max (my family and her parents). In order to get the 4-wide, I wonder if I need to design the room a little wider. Thoughts on that?
My architect has some experience but not a ton with doing nice, dedicated HT's. My HVAC company is pretty good, so I may shoot them the plans once they are complete and see if they can zone that room with a low-flow concept. Another great thing to think about. Thanks.
As far as the noise floor, I'm still very early in my understanding of that kind of stuff. Any thoughts or helpful links would be great. On that same note, where do most people put the AV equipment in one of these rooms?
Darin
DarinS is offline
post #6 of 10 Old 01-19-2013, 10:01 PM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
With regard to the noise floor, that's just a $10 way to say you want it quiet in the room. Think about the last time you watched a movie when the dishwasher, or clothes washer, or dryer, or, or, or was running. You turn the volume up to hear the dialogue over the ambient noise in the room, but then a loud action scene follows and you're grabbing for the remote to turn it down and marking off a few more points on your hearing test wink.gif the idea is to keep the ambient noise in the room as low as possible so the audio is not competing with it.
With the HVAC, you still need the flow to keep the room cool when it's packed full of people and a hot projector. However, you want the air moving slowly so that it doesn't generate noise as it enters the room. Again, turning up the volume to compete with the noise every time the AC turns on.
You might want to check the Pimp My Garage thread and get Brad's thoughts on soundproofing a detached room.
J_P_A is offline
post #7 of 10 Old 01-19-2013, 10:05 PM
Quoted: 490 Post(s)
Liked: 422
A few more thoughts and design considerations that you may not have run across...
When specifying A/C service, be prepared for running the system to cool the room pretty much year round (where are you ?). Each person produces heat more-or-less like a 100W bulb, plus the 250 or 300 watts in the projector, plus any other electronics or amps that might be in the room, or any lights left on (not generally recommended), so the room will warm quicker than you expect. There are a number of build threads where the details have been hashed out, but some guidelines include trying to turn over or replace the air in the room 6 times per hour - that's a lot. And as J_P_A said, keep the vent velocity down - shoot for 250 fpm or less to keep them quiet - that's much lower than normal.
Supporting both the idea of cooling the room and minimizing extraneous light, you might consider putting the AV equipment in a closet or rack outside the theater. Often, closets are designed so that the face of the equipment is accessible from within the theater to load discs or adjust settings, while the rear is outside and ventilated elsewhere. Equipment racks require their own considerations, but generally provide enough advantages to make it worthwhile.
You might also look into an acoustically transparent screen or the importance of masking systems or maybe constant image height with or without an anamorphic lens ("a-lens"). If you haven't read through a few build threads, it's definitely worthwhile to spend a few hours (days) browsing and seeking inspiration. If you check the sticky threads at the top of the dedicated theater construction forum, you'll see the index of "show me" threads, which are great collections of theaters you can search for ideas that suit your preferences.
Sometimes it's tough for us (me) to make recommendations without knowing what you like and expect. With such a blank canvas there are so many options (not to mention it's taken me about three or four years of reading this forum to accumulate the "knowledge" that I have), I could design the space for me but not necessarily for you.
Fred
post #8 of 10 Old 01-20-2013, 08:42 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
I'd think the loft would be the most difficult sound containment problem. If there are kids in the rec room they will want to mess around in the loft too. They'll be making enough racket to disturb the space below.
16' may be a bit narrow for four seats across.
Where does the door behind the theater lead to? Can you incorporate that space into the theater? Or maybe tuck the bathroom back into that corner.
The kid loft could go above the kitchen area.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #9 of 10 Old 01-21-2013, 02:07 AM - Thread Starter
DarinS's Avatar
I met with my architect yesterday who will do the actual design of the entire space, soundproofing, etc. He needs me to come back to him with some specifics on the home theater (seating, air flow requirements, etc). How wide will I need the theater for a 4 seat across design? The online dimensions for some seating arrangements are in the 138" range wide. How much space is needed on the sides to make it reasonable to get around? Also, about how much space should I allow between the rows?
Darin
DarinS is offline
post #10 of 10 Old 01-21-2013, 07:35 AM
Quoted: 490 Post(s)
Liked: 422
I'd like 2.5 to three feet on each end of a row to walk comfortably. 2.5 should be fine, IMO, but you'll want a little extra to make room for acoustic treatments mounted to the wall or maybe a column or surround loudspeaker. So 11.5 feet for the seats, plus another 6 to 7 for aisles and things on the walls. 18 would probably be totally reasonable, but closer to 20 would feel relaxed and comfortable.
For rows spacing, I'd shoot for 7 feet from the front of one row to the front of the next, if using recliners. Certainly not less than 6.
