New home - should I build theater under garage? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-19-2013, 05:06 PM - Thread Starter
Johnnymenudo's Avatar
Quoted: 46 Post(s)
We are in the getting ready to break ground stage and we are finding some issues with the current location of the theater next to the mechanicals room. Because of the location of the room and the size of room, we are putting it under the master suite. This means some runs of HVAC and plumbing will need creative planning to find a way to run them in a soffit that fits the room.
I cleared this with my architect and builder, but now the HVAC guy is throwing some monkey wrenches into what I thought would be an adequate 18-24" X 10-12" soffit around the room borders. Great place for small can lighting. The unsoffited area of the room is 9 foot ceiling.
My plan B is to put the theater under the garage that will have a spancrete floor construction. The downside to this is not centrally located and will make for some long runs for whole home audio and the control systems. The upside is the ceiling heights will still be pretty good - 8' plus. I imagine that there are challenges with acoustics and that this will not be a shortcut. Will have to frame out walls and ceiling just like conventional under home room.
If you had the choice of doing a theater in a concrete enclosure under the garage, or building out under the house - what would be your preference and why? pros and cons of both options? Pitfalls and concerns?
Johnnymenudo is online now
post #2 of 4 Old 01-19-2013, 08:30 PM
AaronN's Avatar
I believe I saw a thread here of someone who actually did just that; had the spanned concrete garage floor and all. If I remember correctly, it was fairly easy to soundproof the room. I'll see if I can dig it up.
Edit: Found it: http://www.avsforum.com/t/1365438/bradley-concrete-cave-theater-construction-thread
__________________________________________________ ______
http://www.avsforum.com/t/1415464/aa...sement-theater
AaronN is offline
post #3 of 4 Old 01-19-2013, 09:39 PM
rabident's Avatar
Quoted: 332 Post(s)
Liked: 107
Here is a spancrete in progress http://www.avsforum.com/t/1445270/27l-x-22w-x-10h-diy-concrete-bunker-w-eight-18-ib-subs
If I did my theater again I would put it under a 3 car garage with an equipment room, entrance, and bathroom under the house (at the back of the theater space under the main part of the house - leaving the full 27' or 32' length of the garage for the theater. As far as height goes, can you have them dig out the theater an extra foot or two to give you a taller ceiling in just that room? The main reason I would do a theater under the garage is because of the location. I assume the only wires & HVAC lines coming into the room would be for the room. So it would avoid having to deal with house infrastructure running overhead. They just had to open my ceiling up to fix something running overhead but not related to the theater itself. Under garage is naturally not going to have windows so a good use of space for a theater.
It would make sound proofing easier at least on the walls. Spacing your studs a few inches off the wall counts as double stud wall (according to Ted) so you can just frame the room without having to deal with clips on the wall (options vary for ceiling). Double stud is simpler, cheaper, and you can inspect after work instead of taking a few days off to stay on top of the workers (to make sure they do the work meeting specifications they've never heard of).
Wire, ducts, and tubes are pretty cheap. I would view the locations isolation as a good thing. That said, I haven't done it so can't recommend one way or the other. There may be a bunch of other issues I'm not aware.
Actually, my first choice was to put the HT on the main level. A big ranch. But other priorities for me made that unfeasible. 2nd choice would have been under the garage had I known about spancrete. 3rd choice would be what I did which isn't bad, just not a nice as I had hoped (so far). But all of the above are better than taking what you normally get with a basement and trying to retrofit a theater in there.
rabident is offline
post #4 of 4 Old 01-20-2013, 08:48 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
I'd vote for under the garage. Try for 9 or 10 foot clear from slab to spancrete. You'll eat up headroom with the ceiling treatment and risers.
Isolated AC and heat systems is a good thing in my opinion. Theater loads differ a lot from typical residential requirements. And you won't have to deal with theater sound migrating through ducts to the rest of the house.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
