Speaker mouting between studs - AVS Forum | Home Theater Discussions And Reviews
Old 01-20-2013, 04:37 AM - Thread Starter
Lepus's Avatar
Alright i have some Paradigm Surround 1s which I would like to mount on the wall. Unfortunately where I want to mount them is in between two studs. I don't really trust the weight of the speaker on to the drywall itself. So what I was thinkig, is a nicely deocrative board which goes along the exterior of the well and is either attached to the studs, or glued to the drywall. The the speaker mount is drilled through both the board and drywall. Any thoughts?
Lepus is offline
Old 01-20-2013, 08:23 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
That's an eight pound speaker. You'll have no trouble with those if you find the right drywall anchors. HD or your local hardware store should have a good selection.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
Old 01-20-2013, 03:50 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I really like these drywall anchors. It helps to know the thickness of the drywall, when selecting the size.
http://m.homedepot.com/p/Crown-Bolt-6-32-x-2-3-8-in-Zinc-Plated-Steel-Hollow-Wall-Anchors-with-Truss-Head-Combo-Drive-Screws-25-Pack-10762/202187124/
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 01-20-2013, 04:04 PM
aaustin's Avatar
Liked: 36
I agree, you'll have no trouble using drywall anchors to hang those speakers.
I have used these before and like them a lot since they don't require any pre-drilling
http://www.homedepot.com/h_d1/N-5yc1v/R-100234590/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=drywall+anchors&storeId=10051#BVRRWidgetID
The Austin Home Theater:
aaustin is offline
Old 01-20-2013, 06:08 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
The one I linked above also does not require drilling, AFAIK. I hammer it in, insert the screw, and it holds very well. Whatever you use, look at the weight rating on the package.
Neurorad is offline
