easy to open blackout window treatments - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-21-2013, 01:10 AM - Thread Starter
jason is me's Avatar
We have a dedicated theater - the windows currently have fitted insulated panels which block light and reduce heat and i have black curtains to block the panels. i am wanting to remove the curtains and panels and install something that will give me the ability to easily open and close to let light in when i want it and to black out the light when i dont - any suggestions? i have seen roman shades but not much else that would serve my purpose. and for reference this will need to cover 3 windows that run together side by side. i would prefer something that my kids could open without issue and is not electronic to keep costs down.
thanks for any advice!
jason is me is offline
post #2 of 4 Old 02-01-2013, 03:13 PM
Mary Etta's Avatar
I suggest opaque honeycomb cellular shades like those from Hunter Douglas. You could get them cordless, which is not much more. They have a small headrail so three could butt together easily. They also will work vertically if you wanted to go that route.
Mary Etta is offline
post #3 of 4 Old 02-01-2013, 03:18 PM
golfnz34me's Avatar
I second that notion. I am currently using a dark brown cellular shade I got from Lowes, I think, and it does a bang-up job of blocking the light. It is cordless as well.
It's toe-tappingly tragic!
golfnz34me is offline
post #4 of 4 Old 02-02-2013, 09:34 AM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 87
Hunter Douglas also makes a honeycomb-type shade designed for overhead or skylight windows. It has a track on the sides that helps contain any light leakage. I used them in skylights in my last theater, and they worked great. http://www.hunterdouglas.com/product-option.jsp?id=23
LeBon is offline
