Backer box material - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-21-2013, 07:25 PM - Thread Starter
xjagox's Avatar
Quoted: 39 Post(s)
Liked: 32
Is it OK to build recessed light backer boxes from OSB+drywall, or is OSB+cement board necessary for fire safety?
I'm using the 4" remodel cans from Lowe's (the ones that come with a housing and white baffle for ~$16), non IC, but have a thermal cutoff switch. There are no real guidelines in the product documentation about clearances between the housing and any other materials- just 3" min from insulation.
xjagox is offline
post #2 of 4 Old 01-22-2013, 09:21 AM
Quoted: 3255 Post(s)
Liked: 2743
Drywall is fine, It is what is used for firecode backer-boxes
http://intranet.progresslighting.com/firebox/Firebox.html
I like using the cement board because I can cut all the pieces on my table saw for a quick assembly. (Special blade required)
post #3 of 4 Old 01-22-2013, 09:43 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Many years ago, and engineer from USG told me that Type-X paper can delaminate with successive heating and cooling, and the paper is combustible, so that's when we started recommending cement board.
In reality, I have no idea how much of a liability (if any) the drywall is as a liner for these boxes.
__________________
Ted
The Soundproofing Company
Ted White is offline
post #4 of 4 Old 01-22-2013, 01:31 PM
BroncoSport's Avatar
I would be a little leary of using OSB for the actual box. Mainly because of it's density and attaching the components to each other when you screw them together (making a air tight seal).
I used 3/4 MDF for the box and cement siding board to line it. The cement siding worked great, was inexpensive and I only needed one stick of it to do my 6 cans. The MDF (as you know) is very dense and made very tight seals when screwed together.
Just a thought...
BroncoSport is offline
