JMAN's Home Theater and Basement Build-out - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 89 Old 03-01-2013, 08:53 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
I was going to suggest taking a look at JTR speakers. I have looked at a LOT of different options and had settled on the idea of getting Ascend Acoustics Sierra towers with the matching center. Then I really started to read into the JTR thread. Jeff at JTR makes some pretty great speakers which have very high sensitivity which are great for HT use and they are not bright like some other brands. I'm only suggesting it because there's a used LCR set up in the classifieds for a really great price. Kevin is selling his 2010 models which have been upgraded to the 2012 crossovers for $1900.
They aren't the prettiest speaker but for their price they'll knock your socks off. I read the entire 240+ page thread and there was even a couple guys that have switched over from Klipsch Ultra2 set ups and said they would never go back after getting the JTR's.
http://www.avsforum.com/t/1449859/3-jtr-triple-8s-1-900-shipped-price-drop
jbrown15 is offline
post #62 of 89 Old 03-01-2013, 09:19 AM - Thread Starter
THEJMAN311's Avatar
Those seem like great speakers, if I had built a screen wall I would have gone with something like that. But I need in-walls for my setup and I'm not seeing any options for that on JTR's website.
THEJMAN311 is offline
post #63 of 89 Old 03-01-2013, 09:33 AM
jbrown15's Avatar
Liked: 1995
Oh I see, I thought you were going to have a false wall and hide everything behind it for some reason. The only option they have that would possibly work would be the Triple 8HT-LP low profile speakers that can be wall mounted....lol talk about profiling, but I only suggested them to you because you have a PSA sub so I know you can appreciate a good ID brand.
jbrown15 is offline
post #64 of 89 Old 03-01-2013, 11:04 AM - Thread Starter
THEJMAN311's Avatar
I definitely appreciate the suggestions smile.gif Ideally I would have had a screen wall, but with this space and it being the first theater I just decided to get the most amount of space for the length of the room and stuff an extra huge AT screen with in-wall speakers behind it cool.gif
We shall see how the sound turns out, some say in-walls are less than ideal compared to towers, I'm sure to my untrained ear whatever in-walls I end up with will sound amazing compared to my 15yr old Paradigm spakers that are in my loft setup.
post #65 of 89 Old 03-02-2013, 02:17 AM
pyrotech6's Avatar
Just saw your thread! Wow, fast work so far.
I am also in Colorado (Stapleton). I just began framing myself. I wish you the best of luck.
-Tim
pyrotech6 is offline
post #66 of 89 Old 03-02-2013, 07:37 AM - Thread Starter
THEJMAN311's Avatar
-Tim
Thanks Tim, best of luck to you as well. I'll keep an eye on your build thread.
post #67 of 89 Old 03-02-2013, 07:40 AM - Thread Starter
THEJMAN311's Avatar
Here's this weekend's project
Tile 1-1/2 baths and a wet bar area. About 130 sq. ft. total for all 3 areas.
post #68 of 89 Old 03-02-2013, 08:02 AM
mjmitchell1970's Avatar
Ouch! My knees and back are already aching just thinking about all that work.
mjmitchell1970 is offline
post #69 of 89 Old 03-02-2013, 01:29 PM - Thread Starter
THEJMAN311's Avatar
I've got most of the cuts done for both bathrooms. Here's a preview of the design for the bathrooms biggrin.gif
post #70 of 89 Old 03-07-2013, 09:34 AM - Thread Starter
THEJMAN311's Avatar
Here's the latest pics of the progress. Got the tile put down over the weekend and did grout yesterday. My contractor has most of the doors hung and trim up. Painter's come tomorrow and carpet should be getting installed in about 2 weeks.
post #71 of 89 Old 03-08-2013, 03:02 AM
eRob's Avatar
Looking good. I like how you have an open feel to your theater.
eRob is offline
post #72 of 89 Old 03-10-2013, 09:28 PM - Thread Starter
THEJMAN311's Avatar
Thanks eRob, we're really happy with how our design has turned out so far. The painters should be done at the beginning of the week so I'll have some updated pics afterwards.
post #73 of 89 Old 03-11-2013, 06:55 AM
JMEANS's Avatar
Quoted: 14 Post(s)
Fantastic build man with a open layout similar to my future plans! You have mentioned the Width of the theater but I didn't catch the length? Did I miss it? Lots of progress in a short time for sure and look forward to the quality finish and your Bar planning! Anything drawn up yet? Jim
JMEANS is offline
post #74 of 89 Old 03-11-2013, 09:01 AM - Thread Starter
THEJMAN311's Avatar
Hey Jim, the length of the theater is a little over 24'
I have a 3D rendering of the cabinets for the bar area, I'll scan it in when I get home this evening. Our cabinets should be showing up at the end of this week. So I might be able to get some of them installed over the weekend. We are planning to just do granite tile for the countertops, this will match what is existing in our kitchen.
post #75 of 89 Old 03-11-2013, 09:29 AM - Thread Starter
THEJMAN311's Avatar
I totally forgot to mention that I finally got my speakers figured out and ordered.
And the winning in-walls are......
TRIAD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Here are the specifics:
THEATER
Mains & Center - InWall Silver/6 LCR x 3
Front Height - InWall Mini/4 Sat x 2
Mid Surrounds - InCeiling Bronze/8 Sat x 2
Rear Surrounds - InCeiling Bronze/8 Sat x 2
ZONE 2
Family Room - InCeiling Mini Open Rounds x 2
Hallway - InCeiling Mini Open Rounds x 2
I'm really excited to hear these things, I think the sound is going to be AMAZING
post #76 of 89 Old 03-11-2013, 10:05 AM
JMEANS's Avatar
Quoted: 14 Post(s)
Mine is around 24 too ~Wild! Wasn't sure if a second row would be possible over a back counter and stools so very excited now and also on your speakers news! Congrats and will check back soon!
JMEANS is offline
post #77 of 89 Old 03-13-2013, 05:37 AM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
cw5billwade is offline
post #78 of 89 Old 03-13-2013, 07:32 AM - Thread Starter
THEJMAN311's Avatar
Here's the 3D render of the wet bar area.
We'll see how the actual setup matches this on Friday!
JMEANS likes this.
post #79 of 89 Old 03-13-2013, 12:50 PM
GWCR's Avatar
Quoted: 17 Post(s)
Liked: 39
GWCR is offline
post #80 of 89 Old 03-22-2013, 09:57 AM
Quoted: 144 Post(s)
Liked: 138
Any updates? Pictures?
HT - JVC RS520 - Anthem AVM 60 - XPA-7 - XPA-5 - GE Triton 2 - GE Supercenter XXL - GE Invisa 650 x 8 - Xbox One - PS4 Pro - Oppo BDP-203 - Dual Rythmik FV15HP's - Lumagen Radiance Pro
My Media Room
kaotikr1 is offline
post #81 of 89 Old 03-23-2013, 12:14 AM - Thread Starter
THEJMAN311's Avatar
A lot has happened in the last week.
Here is how the bar area turned out. I'd say it's pretty spot on with the rendering smile.gif
The bar top, it's a little over 12' long (You don't even know how glad I am to finally be done with the wet saw)
Some updated shots of the theater...now with paint and scones!!!! We're really happy with how the color turned out, it's exactly what we were going for
Carpet is getting installed on Monday, so I'm pretty excited about having a ton less dust around the house once that's done. My seats shipped on the 19th so they should be getting installed not too long after the carpet, then the painters come back and do the touchups and this basement should be wrapped up in just around 2 months time.
post #82 of 89 Old 03-23-2013, 07:44 AM
tcramer's Avatar
Quoted: 281 Post(s)
Liked: 130
Looks awesome!
What component rack did you go with? I'm debating between purchasing a rack such as that or just building one in the wall, recessed back into my mechanical room.
JVC DLA-RS600, 110" Stewart Cima Neve, Oppo UDP-203, TiVo Bolt, Denon X4300H
Dual Rythmik FV15HP, Energy Veritas Fronts and Surrounds, 4x RSL C34E for Atmos
tcramer is offline
post #83 of 89 Old 03-23-2013, 09:25 AM - Thread Starter
THEJMAN311's Avatar
Originally Posted by tcramer View Post
Looks awesome!
It's the Sanus CFR2144
It comes with a TON of accessories which makes it a really great deal and quite a bit less than any similar MA rack.
It was actually pretty easy to get downstairs after taking the sides and doors off too.
post #84 of 89 Old 03-23-2013, 08:05 PM - Thread Starter
THEJMAN311's Avatar
Theater In-Walls and In-Ceilings Installed!
post #85 of 89 Old 03-23-2013, 09:15 PM
tcramer's Avatar
Quoted: 281 Post(s)
Liked: 130
Nice color! Willing to give the name and brand of paint you used for that?
I'm still trying to convince the wife to let me do something similar instead of a white ceiling. Maybe your picture will be what it takes to convince her. smile.gif
tcramer is offline
post #86 of 89 Old 03-23-2013, 09:59 PM - Thread Starter
THEJMAN311's Avatar
Here's the paint and carpet samples. The actual paint used was Kwal that was color matched to these. The samples were from Lowes of Valspar brand paint. The Aspen Gray was eggshell finish and the Rogue Blue is flat. The carpet is from Home Depot.
post #87 of 89 Old 03-28-2013, 04:15 PM - Thread Starter
THEJMAN311's Avatar
It's almost ready to use!!!!
Seats got delivered today, took a gamble on 4seating.com and the transaction went really smooth and the seats were in amazing shape, they are the Lane 160's.
Jamestown Screen frame somewhat assembled, going to finish it tomorrow when I have some help to tension it.
post #88 of 89 Old 03-28-2013, 05:41 PM
J_P_A's Avatar
Quoted: 650 Post(s)
Liked: 483
Looking awesome. I'm liking that stage more and more
The Plains Theater Has Begun
J_P_A is offline
post #89 of 89 Old 03-29-2013, 11:59 AM
Quoted: 328 Post(s)
Liked: 184
