Suggestions on wires to hook up my HT are welcomed Thanks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-25-2013, 09:02 AM - Thread Starter
dizzyrapper18's Avatar
I'm getting ideas on some wires and plugs to use for my first HT. I do not want the cheap stuff but I do not want the best stuff. I was also thinking of just going to bestbuy or abt or frys, any electronic store would be easier. Obviously pre-made ones would save time and effort but are they better than ones you make yourself?? Links would be great. s regular wires better than using bannana plugs or you still get the same power either way? Thanks for the input.
20130125_100420.jpg 2423k .jpg file
dizzyrapper18 is offline
post #2 of 3 Old 01-25-2013, 10:22 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 142
Spaceman is offline
post #3 of 3 Old 01-25-2013, 04:38 PM
srg775's Avatar
I agree with spaceman. My entire wiring for my HT came from monoprice. Excellent prices, great products.
I would personally use banana plugs compared to bare wires.
srg775 is offline
