Home Theater Design - AVS Forum | Home Theater Discussions And Reviews
Old 01-25-2013, 02:23 PM - Thread Starter
mrschumacher's Avatar
I recently moved into a new home and am looking for advice using the existing concealed cable connection. If this is posted in the wrong section I apologize.
Far Wall Location: From the picture the far cable outlet is above a staircase and a coaxial cable is concealed with the wall and runs between the two cable junction boxes.
Closer Lower wall location: Has the coaxial cable from from the wall junction box and 2nd coaxial cable the runs to the outside cable feed from the service provider.
My cable box has a coaxial in and HDMI out.
My question is, using the current setup, how do I get the output form the cable box through the concealed coaxial cable if the cable box output is HDMI.
I see the process as:
Outside cable source>>lower outlet>>coxial input to cable box>> Cable Box HDMI out>>> Convert HDMI to Coaxial?>> Coaxial conenction to HDTV.
Thoughts?
Matt
mrschumacher is offline
Old 01-25-2013, 05:31 PM
Quoted: 3255 Post(s)
Liked: 2743
mount the cable box on the wall behind, or under the TV.
