Fuse box rattles with subwoofer- how to silence? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-25-2013, 04:00 PM - Thread Starter
johnbomb's Avatar
The doors covering my two fuse boxes rattle with subwoofer notes. What can I do to silence them? What is allowable by code? I don't want to start a fire!
John
johnbomb is offline
post #2 of 5 Old 01-25-2013, 04:22 PM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
self adhesive foam tape? Available in lots of thicknesses at most any hardware store. Would help to see the door, but if it is one surface overlapping another, a little foam tape would go a long way. How much you use along the perimeter of the door will depend on how sloppy it is. Might just need a small piece in each corner opposite the hinges.
underachiever extraordinaire
weaselfest is offline
post #3 of 5 Old 01-25-2013, 04:34 PM - Thread Starter
johnbomb's Avatar
That's a good idea- I just don't know if that would pass code. A fire hazzard, maybe?
johnbomb is offline
post #4 of 5 Old 01-25-2013, 05:09 PM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
paging Mr. Tim the code guy.......Mr Tim, the code guy call on line one please...............
post #5 of 5 Old 01-25-2013, 05:17 PM
Quoted: 3257 Post(s)
Liked: 2743
A little foam as mentioned and some sheets of Dyna-mat Extreme .
