Ideas for a 20L X 12W room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 01-27-2013, 07:41 AM - Thread Starter
tkeyes's Avatar
Anyone have any plans or pics? We need a minimum of 5 seats. Thanks in advance
tkeyes is offline
post #2 of 17 Old 01-27-2013, 07:50 AM
AaronN's Avatar
Similar to my size, although I'm leaving my room open in the end. Here's my plan; we switched to a row of three in front and a row of two on the riser. You should be able to easily to two rows of three.
Mine is a little over 11' wide after framing and one layer of 5/8" drywall. And to the back of the riser is a little over 20'.
__________________________________________________ ______
http://www.avsforum.com/t/1415464/aa...sement-theater
AaronN is offline
post #3 of 17 Old 01-27-2013, 07:54 AM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
Wow.....um....er......ah.......yeah. We will need just a little more information to point you in the right direction. Items like budget, design elements or themes, dedicated space or multi purpose media room, DIY or professional build out. Diagram or pictures of the space also help.
RTROSE
RTROSE is offline
post #4 of 17 Old 01-27-2013, 03:11 PM
Tedd's Avatar
Quoted: 925 Post(s)
Liked: 339
room height? door layout? Any obstructions? Any current gear?
Tedd is online now
post #5 of 17 Old 05-28-2013, 08:55 PM
adde2020's Avatar
Hello !!,
I am also planning to convert my unfinished room and found this thread .Sorry for using the same .Here is my info. Room Layout 20 L x 12 W x 9 H . Planning to have 2 rows ( 3 & 2 ) .
Looking for a 5.1 speaker configuration and already have the following :
Pioneer VSX-1122-K 630W Receiver
polk speakers ( Monitor 70 , CS2 Series II Center Channel , Monitor 35B Compact Bookshelf and PSW505 Sub woofer ) .
Planning a budget of around 3K for projector and screen . Please advise the projector model , screen and speaker setup.
Room Configuration
_____________________ DOOR __________
|__________ |
\ \ \ \ \ ___________ _______ |
adde2020 is offline
post #6 of 17 Old 05-28-2013, 09:30 PM
Quoted: 3256 Post(s)
Liked: 2743
Xoxoxo
post #7 of 17 Old 05-28-2013, 09:43 PM
Brad Horstkotte's Avatar
Liked: 68
Brad Horstkotte is offline
post #8 of 17 Old 05-29-2013, 07:05 AM
Liked: 2743
You at least get hugs and kisses with mine.
post #9 of 17 Old 05-29-2013, 08:10 AM
Willie's Avatar
Quoted: 75 Post(s)
Liked: 106
Sweet.
Willie is online now
post #10 of 17 Old 05-29-2013, 09:42 AM
Liked: 2743
TKeyes, now that we have had a good laugh at your expense. Welcome to the forum.
draw a measured floor plan showing the room and all the breaks like door and the jog. Indicate dimensions. You don't need to use any computer drawing program, just draw on a piece of paper then take a picture and post in this thread, I promise you will get some intelligent responses on how to lay out the room. A picture of the current condition would help as well.
post #11 of 17 Old 05-29-2013, 09:45 AM
BroncoSport's Avatar
My room is only 1' longer than your space and the same width. Click on my signature link to see what you are able to do with that size room. As soon as I get 2 boards milled with a wedge shape to cant my seats slightly back, I will have 2 rows of 4 high back rockers in my theater. (and I can finally have the carpet installed!)
BroncoSport is offline
post #12 of 17 Old 06-09-2013, 07:01 AM
budk's Avatar
Mine room is slightly narrower and I have 3 rows of 3.
Bud
There is a solution to every problem.
2nd Run Cinema - A fabric frame theater
budk is offline
post #13 of 17 Old 06-10-2013, 10:47 AM
djkest's Avatar
Quoted: 26 Post(s)
Liked: 39
Well, at 12' wide you are probably looking at 2 rows of seating, 3 seats in each row.
First row at 11-12', and 2nd row at 15-16'.
120" screen would be a decent starting point. I'm sure others will chime in.
With that limited width you might consider an AT screen, speakers behind the screen, and bass traps in the front corners all behind the screen.
djkest is offline
post #14 of 17 Old 06-10-2013, 03:18 PM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
With that big a screen in a narrow room you will need to make sure the side walls are fabric covered with a black or very dark and non-reflective fabric otherwise you are going to light up those sidewalls very distractingly.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #15 of 17 Old 06-10-2013, 04:19 PM
My room (12' 4" wide after treatments) has a 124" wide scope screen and it fits perfectly. Very much a WOW factor. That leaves me about 16" on both sides. I have darker tapestry fabric above the chair rail and yes you can see the side walls while a movie is playing, but it is NOT distracting at all. I didn't want and wouldn't have ever built a super dark theater. My play movie scene on the Grafix Eye is about 10% sconces on the side walls.
If I didn't have some framing on the screen wall (on the sides) to attach a future power masking system, I would have gone up to 134"ish wide!!! smile.gif
I just hate to see folks that build a super nice theater and put a (relatively) dinky screen on the wall. It's supposed to be immersive!
post #16 of 17 Old 06-10-2013, 06:06 PM
jchasen's Avatar
My room is 12'4" wide by 20'8" long and we managed to fit 9 seats and a 120" 16:9 screen.
You can find more pics and plans in my build thread: Chasen the Dream Theater.
jchasen is offline
post #17 of 17 Old 09-02-2013, 07:53 PM - Thread Starter
tkeyes's Avatar
Wow. That room looks great. Our room is similarly sized, but with rather poor door placement. At this time, I think we are going to go with 2 seats in the back row and two in the front row. Unless we go with really narrow seats, I don't see any other way to do it. Thoughts?
tkeyes is offline
