DIY AV furniture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-28-2013, 07:04 AM - Thread Starter
kerednai's Avatar
I'm interested in building my own AV furniture.
The AVC73 looks nice from Sonus but its $1500 and not exactly what I am looking for so am seriously considering buying my own.
Has anyone done or contemplated doing this themselves? Any pointers would be greatly appreciated.
kerednai is offline
post #2 of 6 Old 01-28-2013, 07:36 AM - Thread Starter
kerednai's Avatar
I found a great thread on AV Forums and this is very similar to what I would like to do...
http://www.avforums.com/forums/14315115-post241.html
The full thread is available here - http://www.avforums.com/forums/av-stands-cabinets-seating-furniture/1285476-chunky-monkey.html
kerednai is offline
post #3 of 6 Old 01-28-2013, 12:33 PM
John Reid's Avatar
Yeah, I'm in the process of designing an AV console for my future dedicated media room.
Nothing I've seen prebuilt has done it for me as far as style (I'm looking for modern, but not the Miami Vice look that seems to be available).
So I've been using Google Sketchup to make a model that I'll have a carpenter make for me. I'll buy some pre-made parts, like a TV mount, but everything else will be custom.
I'm thinking of using layers of baltic birch plywood for the material. Sounds odd, I know, but there's some pretty bitchin' stuff you can do with plywood if you treat it right.
John Reid is offline
post #4 of 6 Old 01-28-2013, 12:41 PM
Louquid's Avatar
Liked: 38
I've built TV stands a few times before. Always prefer this over buying particle board stands from the typical places.
Only thing to be careful of is ensuring you have enough bracing for the weight of your TV itself. Of course that's if you plan on setting the TV on the stand. You just don't want the top shelf to begin sagging after a few months.
Birch plywood is easy to work with while also being very stiff/strong. As for finishing, as long as you pre-treat the wood before trying to apply stain you'll be fine. I personally like to put two coats of teak oil before staining, then a final coat after the stain to seal it in. If you go straight to staining you can end up with serious blotchiness.
Louquid is offline
post #5 of 6 Old 01-28-2013, 05:16 PM - Thread Starter
kerednai's Avatar
Some good pointers - thanks :-)
Do you have a specific design you have been working to? My main concern would be heat, but I wasn't planning on adding a glass door front or back so that should be good.
Any chance you could post some pictures of what you have created? Also interested on the thickness of plywood you went for in the end.
kerednai is offline
post #6 of 6 Old 01-29-2013, 06:39 AM
Louquid's Avatar
Liked: 38
I usually just measure all of my components and try to draw up a design. I like for my receiver and center to both be perfectly centered, with the other components on either side. I also usually aim to have the width of the TV to match the Width of the stand. Really it's just a matter of what you want it to look like.
I like using 3/4" plywood. Sometimes I'll use the scrap pieces to make veneer to cover the edges of the plywood. I'll just cut strips to the desired width, and will run them through a table saw to rip the veneered edge off.
Louquid is offline
