Corner Mount Perless CM50 or 60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-31-2013, 05:22 AM - Thread Starter
cjd2404's Avatar
Hi all.
I am getting ready to move am older Sharp Aquos 48" LCD into a corner. I prefer to keep it mounted to a wall. I saw the Peerless CM series and they mention the requirement of a peerless flat mount to go with it.
Currently my TV is mounted with a cheap monoprice mount. Does anyone know if that would be compatible with the peerless system? I'd like to keep the cost down, and the corner mount is bad enough by itself.
I am not looking for an articulating arm as I am concerned about sag over time, and I plan on having it fixed viewing from the corner.
If any other systems exist out there that people are aware of, if you wouldn't mind sharing that., I'd appreciate it as well.
Thanks in advance.
-Chris
cjd2404 is offline
post #2 of 2 Old 01-31-2013, 08:16 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Do an avsforum search and/or Google image search of "corner mount"
http://www.google.com/search?q=site:avsforum.com+%22corner+mount%22&hl=en&safe=off&tbo=d&rlz=1Y1UXZM_enUS513US513&source=lnms&tbm=isch&sa=X&ei=BiwLUf3sMobm8QTry4A4&ved=0CAgQ_AUoAQ&biw=598&bih=335
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
