Diamante Build in DC - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #181 of 199 Old 11-19-2013, 08:36 AM - Thread Starter
RossoDiamante's Avatar
Carpet is in.  My minimalist screen wall frame is up and painted.  The rack is getting put together in its final configuration.  Things are looking good.  To my ear, the room sounds a lot better now with all the absorption of the carpet.  Can't wait to measure it over the next couple of days.  I have 5 days off so should have a lot of time to fiddle.
This should be the last picture of a theater without a screen!
Diamante Build in DC - Double Drywall, Green Glue, Drywall Furring Channel, Riser, Stage, Bass Trap, In-Wall Speakers, BG Radia, JTR Captivators, Seymour AV, Sony HW-50ES, Sherbourn, Panasonic, Middle Atlantic, Lutron Grafik Eye, Baffle Wall
RossoDiamante is offline
post #182 of 199 Old 11-19-2013, 08:52 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 84
Looking good! Can we see a pic of the carpet installed?
AirBenji is offline
post #183 of 199 Old 11-19-2013, 12:12 PM - Thread Starter
Don't have the greatest pictures of the carpet alone. Here's a couple of shots that shows it a little bit better.
post #184 of 199 Old 01-04-2014, 05:46 PM - Thread Starter
The rack is nearing completion.  Need to get the mounting ear for the ethernet switch fabricated and installed and then a couple of other smaller connections and then time to button it up.
The wiring closet wall houses an HDMI splitter to send the signal elsewhere around the basement, a Darbee, and a Lumagen.  I haven't quite figured out if the Darbee is supposed to come before or after the Lumagen.
post #185 of 199 Old 01-04-2014, 08:17 PM
TMcG's Avatar
Quoted: 1186 Post(s)
Liked: 1002
I see you have the fancy Sherbourn 2U rack fan underneath the amplifier, but ideally you really want to put it ABOVE the amplifier. If you choose not to do this, you need to have a minimum of 2 rack spaces for ventilation above that Sherbourn amplifier and therefore move UP the preamp, Oppo, Monster Power, etc. Another tip is that you really want to have the heavy items at the bottom of the rack...it will make the rack much more stable when you go to move it. I realize you're probably "over' your theater project, but if you get into re-racking, I would make those changes.
The one last thing I would suggest is to pick up a 10-pack of cable lacing bars (Middle Atlantic LBP-1R). They will help tremendously in running your wiring between components and strain relief. Here are a couple pics of my old rack while I was mid-wiring so you can see the cable lacing bars.
BrolicBeast likes this.
TMcG is offline
post #186 of 199 Old 01-05-2014, 04:01 AM - Thread Starter
Nice wiring job!  Where did you end up putting the "excess" cable length?  I had to loop some cables along the vertical posts.
I put the pre-amp and amp together for cosmetic reasons.  But there is no reason I can't flip the fan and amplifier.  I believe I have the requisite cable lengths.  I'm somewhat limited in prettying up the wiring by the "short" speaker wires.  Not enough length to wire them off to the side of the rack and down.  However, if I move the amplifier down .....
The neat thing about the rack fan is the configurable airflow paths.  I have the fan currently set to draw cool air from its bottom and front and force it through its top through the amplifier.  I actually have another fan that I'm thinking of inserting above the components that will draw the warm air from the bottom and shoot it out its back.  Then I have a ventilation return in the AV closet that vents the warm air from the ceiling out of the room.
I like those cable lacing bars.  I have to order a shelf/faceplate for the new DirecTV receiver and will get some of the bars at the same time.
Progress certainly takes a back seat (literally in my case as all this stuff is BEHIND my theater seating) once everything is hooked up and playable!
post #187 of 199 Old 01-05-2014, 01:35 PM
TMcG's Avatar
Liked: 1002
Thanks. I start where all the wires come through the wall and organize by group with some temporary cable ties for the remaining run length, so all the cables are totally in line and already secure. This way it is a piece of cake to route them through the rack to the right spots with only minor tweaks. Once attached to the back of the equipment, I work my way backwards, leaving any excess as part of a slightly longer "loop" or slack in the line. There's a way to hide the slight variations within the interior of the wall / ceiling above the rack.
As for the rest, it is all custom wiring. But I know my position is a bit unique since I have all the pricey tools, cutters, crimpers, etc. to do the job. I can't wait to wire my two new racks of equipment!
How are the finishing details coming along?
TMcG is offline
post #188 of 199 Old 04-01-2014, 02:17 PM
JVoth's Avatar
Quoted: 305 Post(s)
Liked: 152
JVoth is offline
post #189 of 199 Old 04-09-2014, 09:49 PM - Thread Starter
Well, it's fully functional.  Still cosmetic stuff to finish up.  Movies look great on the big screen.  Sound is impressive as well.  Room EQ seems pretty reasonable given just a little bit of attention and parametric equalization.
Here are the acoustic measurements as of the last set of tweaks:
post #190 of 199 Old 04-09-2014, 09:53 PM - Thread Starter
Cosmetically, the fabric is going up on the walls.  I think I'm going to be quite short on black GOM fabric.  Anyone have some they want to sell?
post #191 of 199 Old 04-26-2014, 06:24 AM - Thread Starter
I've run out of black fabric.  Waiting for more fabric before finishing the walls.
post #192 of 199 Old 07-29-2014, 12:10 PM - Thread Starter
I've got some leftover stuff that hopefully someone local might be interested in.
I think there are 19 pieces of 10' furring channel (of the type and specification recommended by The Soundproofing Company and others here) and a few short pieces as well. I also have part of a 5 gallon bucket of Green Glue. I've got 19 IB-3 brackets and about 2 or 3 dozen Whisper Clips.
I'm in Potomac, MD. Prefer local pickup. If I have to ship the clips, it's just as easy for me to return them.
Let me know if there is any interest.
post #193 of 199 Old 07-29-2014, 01:25 PM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
So I take it your room is done? Let's see some photos!!!
BllDo is offline
post #194 of 199 Old 07-29-2014, 01:44 PM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
all those cable ties - hubba hubba! Stuff like that gets me really excited in a terribly awkward way
JRock3x8 is offline
post #195 of 199 Old 07-29-2014, 03:27 PM
TMcG's Avatar
Liked: 1002
Ha ha...thanks! For a large-scale rack wire like the double racks pictured, I probably go through 1500-2000 cable ties to get all the wires to final dress. The two pics above were taken midway through the wiring of this system. I spent the better part of a week getting all the wires in the rack and custom-making every single interconnect except the HDMI and optical wires.
Here's one more for you:
TMcG is offline
post #196 of 199 Old 07-29-2014, 04:06 PM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
Have you estimated yet the time for your new racks? If I remember right, you had quite a bit to stuff into two racks.
BllDo is offline
post #197 of 199 Old 07-29-2014, 04:49 PM
TMcG's Avatar
Liked: 1002
A single rack like Rosso's with a single dedicated system would take about half a day to fully dress. Things get much more complicated when you layer in distributed HDMI and audio, all networking and full automation. I'd expect several days at a minimum to go from rack cleaning, placement and leveling all the way to loading equipment and finishing the final wiring details.
I have two new weapons in my arsenal, though. A Panduit Cable Bundle Organizer and a DYMO Rhino 6000 label printer which is the only label maker I am aware of that can print directly on heat shrink tubing for perfect wire labeling.
Rosso - sorry for the mini thread jack....back to your regularly scheduled programming and good luck with your sale! And by the way.....I will dress rack wiring for beer!
TMcG is offline
post #198 of 199 Old 07-29-2014, 05:42 PM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
I like how you work man - you can come and tie my cables any day (not a euphemism...ahem)
JRock3x8 is offline
post #199 of 199 Old 04-22-2015, 03:44 PM
BrolicBeast's Avatar
Quoted: 1388 Post(s)
Liked: 1442
Legendary!!!!!!!!!!!!!!!!!!!!!!!!
BrolicBeast is online now
