LED track Lighting Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-03-2013, 10:36 AM - Thread Starter
PaulFSemicolen's Avatar
I don't know if this is the best place to ask this:
I have the following LED strip Lighting product
http://www.amazon.com/TaoTronics-TT-SL001-Waterproof-Changing-Controller/dp/B004T0BM0O/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=X6QNC4OL08&coliid=I3FOMSZ1JS4ZTE
I want to recreate the sunrise/sunset via a timer/dimer combo device. I have been searching everywhere online for a programable device that will do this. Any sugestions on what I can do to give the affect of a natural sunrise and sunset, exercising the use of color to mimick this action? For relatively cheap?
domz777 likes this.
PaulFSemicolen is offline
post #2 of 7 Old 04-04-2013, 02:15 AM
mijotter's Avatar
Liked: 59
Have you looked at lighting controls for Aquariums? I know they have LED dimmers and timers and there is also a controller that let's you control the color spectrum as well. I can't remember the brand but maybe it's a start.
PaulFSemicolen likes this.
mijotter is offline
post #3 of 7 Old 11-08-2013, 11:47 PM
domz777's Avatar
Quoted: 76 Post(s)
Liked: 76
looking for something like this?
domz777 is offline
post #4 of 7 Old 11-09-2013, 12:18 AM - Thread Starter
mijotter and domz77 thanks for the replies. What I've decided to try to do is use a Rasberry Pi micro computer to allow me to write a program and create the effect I'm looking for. I still have to finish my build and painting before this step though. The lighting effect will be my last step. smile.gif I'm hoping in the next 2 weeks to get the work done, now that I have all the electrical working, it should be full steam ahead. The Misses will be happy too, since the project has been on stand still since May o.O
post #5 of 7 Old 11-09-2013, 12:30 AM
domz777's Avatar
Quoted: 76 Post(s)
Liked: 76
Well, if using the pi for the lighting control doesn't work out for you,
you can always make a mini stand up arcade machine that uses a cell phone
screen as a monitor Think I might have to do 1 of these for myself!
THIS THING ACTUALLY WORKS PERFECTLY - SAME SOUNDS, SPRITES, CONTROLS, EVERYTHING
domz777 is offline
post #6 of 7 Old 11-09-2013, 01:00 AM - Thread Starter
Yeah! These are awesome!!!!! and for around $35-$50 it's not too bad of an investment ^_^
post #7 of 7 Old 11-13-2013, 03:07 PM
Budget Lighting's Avatar
Budget Lighting is offline
