Design help please, new home construction finishing basement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-13-2013, 09:33 AM - Thread Starter
DocNupe's Avatar
My theater room is 187" by 257 3/4 inches long. No windows to room but I had to frame utility closet in back of theater for mechanicals which decreased length of room to 21.5 feet. I have a sofit covering HVAC and steel I beam towards the back of my space that drops down to 7'7" the rest of the ceiling is slightly over 9". I guess I need some help with spacing and layout. I need to leave room to walk into utility room, door will swing into utility room. I assume I need to sit back 11-12' from screen. I want a riser and a sitting bar behind riser for a few seats under sofit.
DocNupe is offline
post #2 of 3 Old 02-13-2013, 09:41 AM
warrenP's Avatar
Liked: 60
If you can post some pics, like a top down view of your space, then we can help. Throw some dimensions on the pic, where walls are, doors, the soffits, beam, etc.... and you'll get some great ideas from lots of great people here.
Every man dies. Not every man really lives.
warrenP is offline
post #3 of 3 Old 02-13-2013, 10:16 AM - Thread Starter
DocNupe's Avatar
I will, I was posting from an iPad at work. Some of these pictures look amazing with the iPad resolution. I have my final occupancy permit this week. We had to drywall the celing because the builder used engineered Ibeams. So I had to rough in plumbing and run14/2 cable all over from utility room. I did manage to run 12 feet of electrical PVC conduit to projector rough in (low voltage and high voltage gang box)
DocNupe is offline
