Window plug - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-16-2013, 02:15 PM - Thread Starter
jefftr's Avatar
Quoted: 20 Post(s)
Liked: 26
Ok so this wall will be behind the screen wall. It will be clipped & channeled w/ DD + GG over the window but I want to plug it up with something.
I was looking at this:
http://www.soundaway.com/Soundproofing_Closed_Cell_Foam_p/15005.htm
Or should I just stuff some OC 703 panels in there?
How fancy/complicated should I make it?
Jeff
jefftr is offline
post #2 of 8 Old 02-16-2013, 04:27 PM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
Put something over the window that you don't mind seeing from the outside (landscape fabric, GOM, paint the glass black, whatever...), then stuff some pink fluffy in there and drywall over it.
Whatever you do, don't spend $32/ft on that foam! yikes!
Tim
Mr.Tim is offline
post #3 of 8 Old 02-16-2013, 04:36 PM
Quoted: 3897 Post(s)
Liked: 3331
one vote black fabric or linacoustic, black side out. I would be worried that paint would peel over time. Nothing wrong with fabric wrapped OC 703 if you have extra laying around.
This is linacoustic
If you have the depth I've put shades in the closed position, a layer of plywood, insulation then the drywall.
post #4 of 8 Old 02-16-2013, 07:03 PM - Thread Starter
jefftr's Avatar
Quoted: 20 Post(s)
Liked: 26
Yes I have about 3 in depth so I was going to put some curtains and then the insulation. Just wanted to make sure I didn't need something more elaborate
jefftr is offline
post #5 of 8 Old 09-26-2013, 11:18 AM
memmo's Avatar
Quoted: 77 Post(s)
Liked: 66
After the window cavity is filled with insulation, how should it be handled in terms of vapour barrier? The rest of the walls get the 6mil poly. Should the poly go right over the window or should it be cut and wrapped just like it would if the window was being left open?
The Big Bay Home Theater Build Thread
My personal theater build on Kempenfelt Bay, Barrie Ontario Canada
memmo is offline
post #6 of 8 Old 12-14-2013, 07:00 PM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
Would it also be wise to cover the glass with plastic to help hold in cold or heat or doesn't that matter if it is dry walled over?
Claybe is offline
post #7 of 8 Old 12-14-2013, 08:43 PM
Liked: 3331
No, putting two waterproof layers together is a formula for moisture to collect in between and mold to form. If you feel the need you could add a window film tinting or frosting the window, assuming you smooth out all the air bubbles.
post #8 of 8 Old 06-06-2014, 02:46 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 75
Digging up this thread as I now have 4 windows to plug in my new space. Can I run electrical in the "void" between the window and drywall? I'd like to reclaim that wall space for some lighted poster boxes, but would need to run electrical.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
