Where to place entrance door in dedicated theater? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-20-2013, 08:09 AM - Thread Starter
Johnnymenudo's Avatar
Quoted: 66 Post(s)
It is is crunch time and I have to make decisions on location and size of entrance door. My architect wants a rear corner entry double door with cove for the move posters. The issue I see with this is that it messes up rear speaker placement. My thought is that entrance should be in rear more towards the center, or side between the rear and side surrounds. Will have a rear riser but this shouldn't complicate things, but actually is simpler if the entrance is from the rear or side vs. corner.
Does anyone have any opinions to share before I make this decision?
Johnnymenudo is offline
post #2 of 3 Old 02-20-2013, 08:20 AM
jautor's Avatar
Quoted: 1322 Post(s)
Liked: 845
Double doors always pose a problem for sound containment... "Near" the corner would be good, but keep it a foot or two away as you'll probably want to place acoustic treatments (bass traps) in the rear corners.
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
post #3 of 3 Old 02-21-2013, 02:45 PM
warrenP's Avatar
Liked: 60
Can you post a floorplan we can look at? Most architects don't understand theater design/acoustics so their recommendations are often just based on the visual. Double doors do tend to be very hard to deal with, both with sound isolation and vibration. The plan view would help greatly.
Every man dies. Not every man really lives.
warrenP is offline
