The "F" word - AVS Forum | Home Theater Discussions And Reviews
Old 03-07-2013, 05:21 PM - Thread Starter
bduncan118's Avatar
No, not quite what you're thinking. . . . . . FRAMING. What a learning experience. I've built the Same wall 3 times over and finally got it right. The number one thing I've learned: if the area your framing on isn't level all hell breaks loose. End rant.
bduncan118 is offline
Old 03-07-2013, 07:41 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
"I've cut that board three times, and it's still too short!"
HopefulFred is offline
Old 03-07-2013, 07:56 PM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
The Plains Theater Has Begun
J_P_A is offline
Old 03-07-2013, 11:27 PM
warrenP's Avatar
Liked: 60
Squaring off the room is a big deal. Being off by a minor amount here and there easily adds up to a big problem later. I spent forever squaring up the last deck I built...
Any pics of the wall framed x3?
Every man dies. Not every man really lives.
warrenP is offline
Old 03-08-2013, 12:35 AM
domz777's Avatar
Quoted: 76 Post(s)
Liked: 76
They say it's better to just walk away for a few minutes from a job that's just not going right, for some reason or other. That may be true, but I say it's far more satisfying to just beat the ***** out of it with a hammer.
domz777 is offline
Old 03-08-2013, 05:27 AM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
^^^^^^ A BFH (really big hammer) comes to mind!
RTROSE
RTROSE is offline
Old 03-08-2013, 05:50 AM
Quoted: 3258 Post(s)
Liked: 2744
If you attach the top plate with IB3 clips leaving the wall decoupled you have a pretty large margin for error. Measure the wall in several locations, subtract one inch from the smallest measurement, cut your studs all at the same length, build the wall and tip it up.
Old 03-08-2013, 01:19 PM
Helheim's Avatar
So your top plate should be about 1" from the joists? That picture makes it look like they are touching.
Helheim is offline
Old 03-08-2013, 01:55 PM
Quoted: 490 Post(s)
Liked: 422
The picture looks little like an m. c. escher drawing. Look at the bushing. There is the space for the bushing below the horizontal portion of the clip, then the clip bends. Look closely and you'll see the bend in the clip is just below the bottom edge of the joist.
Old 03-08-2013, 08:23 PM
Liked: 2744
1/2 is fine but when you try to make it too close you often miss your mark. If you are decoupling the wall that means you will be using clips and channel on the ceiling and the drywall will be hanging down starting at 1 inch below the joists.
